Old 05-17-2001, 09:29 PM   #1
Suladed
Member#: 5588
2006 Legacy wagon
Post odd brake noises
I just had a set of legacy/RS front brakes installed on my 97 OBS. I purchased the parts used, and as far as I know they were in fine shape. When I got the car back from the mechanic, I had a new sound to entertain myself with. It was not consistent, but in certain situations, I can hear a cross between a clunk and a rattle. It is as if (let us say) the caliper could rotate a few degrees with the disc before catching on its mounting hardware. I know this is not it, but if you can imagine what that might soundlike from inside the car, then maybe you are still with me. The noise occurs on some bumps (without any braking) and then when I use the brakes in some situations.
I took the car back to the shop and they could not find anything and the sound was gone when I got the car again, until yesterday. It does not occur as often, but it is still there.
Anyone haveany ideas what this might be?
Thanks
Suladed is offline   Reply With Quote
Old 05-17-2001, 11:06 PM   #2
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
OHhhhhhhkayyyy take 2! I lost my 1st attempt at posting....
I had a similar sound happen to me. I had changed out my pads,rotors,lines. About 2 months afterwards I began to hear a clunking noise only braking above 45mph. I checked my caliper,found it loose. So I tighted the loose bolt but it snaps! Subaru is known to use easily breakable bolts. Still I get the clunking.
This time I bring the car into the dealer. He sez the noise was caused by a loose/unseated pad ( well they only fit one way!?!?) But he fixes it.
so the moral of the story is: 1st- check for a loose caliper & or broken caliper bolt. 2nd- check your pads.
"Here endeth the lesson" -J.C.
-chrisC
silverSurfer is offline   Reply With Quote
Old 05-18-2001, 06:43 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
i had that on my 99 GT...
indeed it was a loose and worn pad...
check em really well..
j. www.subiegal.com
Odd brake noise. TFW Brakes, Steering & Suspension 2 11-25-2008 03:02 PM
Odd engine noise... ScubaruImpreza05 Normally Aspirated Powertrain 0 01-22-2005 09:28 AM
05 WRX with ODD tranny noise - need info about driveline Craig02WRX Transmission (AT/MT) & Driveline 2 10-16-2004 02:37 AM
odd boost noises ituner Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-23-2004 07:58 PM
More odd suspension noises Bionic Brakes, Steering & Suspension 4 03-18-2003 11:05 PM
