Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 02-12-2003, 01:49 PM   #1
imprezaf
Member#: 12403
I'm Back inda game
Question How to prevent windshield wipers from freezing?
How do you guys prevent your windshield wipers from freezing? Not freezing to the windshield, but freezing to the point where, when you put them on, only the edges clean, and you are looking through a salt filled windshield, that now has windshield washer fluid sitting in your line of sight.
This happened to me yesterday morning, and I figured that when I drove home from work later that day, they'd be ok. Wrong! They were still like that last night. Running the defroster didn't work.
Any insight?
-Mike
imprezaf is offline   Reply With Quote
Old 02-12-2003, 02:36 PM   #2
18FOREVR
Member#: 23951
I'm a Vivid Victim!
'03 WRX - WITH NO SPOILER
I do two things -
First I use prestones windshield washer fluid because it has a lower freeze temperature than the regular blue stuff and second, I have winter wipers. These prevent snow and/or ice from getting built up around the hinges which effects the pressure the wiper can apply to the windshield.
Can't hurt.
Joe
18FOREVR is offline   Reply With Quote
Old 02-12-2003, 02:38 PM   #3
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Are you using winter windshield washing fluid? The antifreeze in that should stop it from freezing.
or...you can drive slower...slower = less airspeed = not as cold on the windshield.
Edvig is offline   Reply With Quote
Old 02-12-2003, 02:52 PM   #4
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
I take it you park outside. Step one. Raise the wipers off of your windshield. Wipe them off. Do that whenever your car is not being used.
Pinochle is offline   Reply With Quote
Old 02-12-2003, 02:55 PM   #5
imprezaf
Member#: 12403
I'm Back inda game
Yes on the Winter washer fluid. This happens even when parked.
I didn't know there was a such thing as winter wipers, but that's exactly what's happening. Pressure on the ends, and nothing in the middle.
EDIT: I even got out of my car and wiped the wipers with my hands to clear off any ice that may have still been in there.
Old 02-12-2003, 03:00 PM   #6
Edvig
Member#: 16147
no more turbo
I dunno then.
Old 02-12-2003, 03:13 PM   #7
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Did you let Billy touch your car? If so, it's probably BROKEN.
Old 02-12-2003, 03:31 PM   #8
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
This happens to me at times as well. I just pull the blade part out from being frozen in the "compressed" position.
Mike~~
N'CTRL is offline   Reply With Quote
Old 02-12-2003, 04:07 PM   #9
Edvig
Member#: 16147
no more turbo
Old 02-12-2003, 04:15 PM   #10
18FOREVR
Member#: 23951
I'm a Vivid Victim!
Winter Wiper blades have a rubber shell encasing the entire mechanism that holds the blade to the windshield. They are common around here. I've got them on three cars and get them at my local auto parts store.
Old 02-12-2003, 04:22 PM   #11
Cre8ive
Member#: 15617
2007 WRX STi OBP
'02 WRX OBP
You could also get a can of the spray de-icer. If it's really cold and icy I spray the blades and arm to melt the ice off of them.
Cre8ive is offline   Reply With Quote
Old 02-12-2003, 04:57 PM   #12
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
what if your wipers work fine and you filled the windshield washer fluid resovoir (sp?) but no fluid sprays out I have to throw snow on my windshield to get them clean...
Darby is offline   Reply With Quote
Old 02-12-2003, 05:03 PM   #13
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
Spray nozzles freeze up. You need LED Washer Nozzles.
Old 02-12-2003, 05:14 PM   #14
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Yep this is the exact solution. I have the same problem on any car I drive if I don't use winter wipers (with the boot) in the winter.
-mike
Paisan is offline   Reply With Quote
Old 02-12-2003, 06:03 PM   #15
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
no doubt dude!
while i'm at, i'll go out and and buy a whistler for my exhaust, some neon lights for underneath my car and a HUGE aluminum wing
it's all fixed up, i popped the hood and found the problem, my body shop forgot to reconnect the hose to the pump
Old 02-12-2003, 06:08 PM   #16
Edvig
Member#: 16147
no more turbo
Damm...I was looking forward to seeing the Love "L" squirting neon happiness.
Old 02-12-2003, 06:45 PM   #17
Loki
Member#: 4543
2003 WRX
Windshield defroster.
Loki is offline   Reply With Quote
Old 02-12-2003, 06:59 PM   #18
Edvig
Member#: 16147
no more turbo
Hey imprezaf...check out this thread in the NE section.
http://forums.nasioc.com/forums/show...hreadid=314723
Old 02-12-2003, 07:24 PM   #19
DRIVES2FAST
Member#: 31117
2005 INFINITI FX35
SILVER
There are a number of things you can do:
When you park your car lift your blades up and off the windshield. Yes it looks funny but they won't freeze and you have to put them back down when you get in. Cleaning the windshield though is easier without them sitting on it anyway. This is the number one thing you can do in any car and yet very few people know about it.
If you don't want to do that, before you get out of the car, pull your windshield wiper control arm back for a quick second and the wipers will stop in a position that is directly above the defroster vents. When you get in turn he defroster fan on high and the temperature setting to high and it will melt the ice off the blades.
The real secret is that you can't spend enough on really good windshield washer anti freeze. The lower the freezing threshold the better. Rain X's -45 beats anyones -20 and don't forget the wind chill factor, that's why you need the one that goes to the coldest factor.
Why buy a great car, that goes so well in the bad weather, only to cheap out on windshield washer fluid? YOU WANT TO SEE WHAT YOU MISS!
DRIVES2FAST is offline   Reply With Quote
Old 02-13-2003, 12:03 AM   #20
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
that kind of stuff is withheld for the ladies only....
How to prevent break dust from sticking to the rims SchultzE Car Care & Detailing 43 07-16-2008 02:02 AM
How to remove rear wiper from wagon? triguy Southern California Impreza Club Forum -- SCIC 24 01-19-2007 03:18 AM
how to prevent scratches from roof racks? criz Interior & Exterior Modification 1 12-02-2004 08:28 PM
How to remove rear wiper from wagon? triguy Interior & Exterior Modification 0 08-21-2004 02:54 PM
How to remove windshield wiper arms? STIRS General Community 1 03-27-2004 07:11 PM
