Old 02-13-2003, 08:06 AM   #1
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Question Does removing the snorkus lean the fuel mixture?
Now I did a bunch of reading on this subject and I can see how a CAI that moves the MAF would create turbulance and could change readings but does just removing the snorkus and keeping the stock airbox with a ITG type filter lean the fuel mixture.I mean real af ratio proof not he said she said.
Thanks Bill
Camperguy is offline   Reply With Quote
Old 02-13-2003, 09:59 AM   #2
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
good question- never thought of it.
anyone?
I'm sure someone has a a/f gauge and can do a little experiment- though that may also be negated by engine mgt, but only time will see I guess.
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 02-13-2003, 10:01 AM   #3
Bolster
Member#: 22290
2002 WRB WRX Wagon
I'm not seeing anything weird with mine removed. Since air still travels the same direction from the box to the airflow meter, I would say that it won't cause a lean condition. The airflow meter still gets accurate readings. -Bolster
Bolster is offline   Reply With Quote
Old 02-13-2003, 12:01 PM   #4
kenchan
Member#: 15106
i think the ODBII adjusts that after a while.
kenchan is offline   Reply With Quote
Old 02-13-2003, 03:16 PM   #5
Chunky_Chicken
Member#: 9782
2002 E46 M3
Laguna Seca Blue
No change in mixture with the silencer/snokle removal.
The MAF is still in its proper housing, and any flow patterns that exist because of the silencer/snorkle are wiped out by the filter anyway.
Some CAI's cause a lean condition because they put the MAF sensor in a different housing, in a different flow path. If the intake tube diameter isn't exactly the same shape, the MAF can't determine volume, since all it knows is air velocity.
-Pete
Chunky_Chicken is offline   Reply With Quote
Old 02-13-2003, 03:22 PM   #6
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
There shouldn't be a difference with it removed/installed.
I don't think moving the MAF is the problem. The problem is the tubing diameter.
Need4Boost is offline   Reply With Quote
Old 02-13-2003, 03:24 PM   #7
RalliTek
Guest
Member#:
Chunky , you hit the perverbial nail right on the head.
sean
Old 02-13-2003, 03:25 PM   #8
TheMadScientist
Member#: 23717
2005 Big red
The car idles at 14.2-14.9:1 acording to the Utec without the silencer/snorkle.
TheMadScientist is offline   Reply With Quote
CAI and lean A/F mixture... turbinepwr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-12-2003 06:59 AM
Removing the snorkus (intake silencer) QAScooter Forester Forum 11 08-15-2002 08:09 PM
What can I expect from the snorkus removal, and... gtguy Normally Aspirated Powertrain 8 04-18-2001 09:08 AM
Legacy folks...describe the snorkus removal procedure. gtguy Legacy Forum 7 04-03-2001 05:16 PM
o2 sensor problems, lean A/F mixture. Help me! Quart2000 Normally Aspirated Powertrain 0 02-07-2001 07:29 PM
