Old 03-05-2001, 10:55 AM   #1
Puckaveli
Member#: 1518
00 2.5RS
Post Sway bar install : suspension - to compress or not compress?
I did a search on sway bar installs and counldn't find anything. A while back I remeber seeing something on a rear sway bar install that dealt with the issue of suspension compression during the the install.
Is it easier to install the bar if the car is jacked up by the wheels or by the frame with the wheels hanging?
I got a 20mm bar from Sugar and she does super fast service. Kudos to Sugar!
Puckaveli is offline   Reply With Quote
Old 03-05-2001, 10:58 AM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Thumbs up
Do it on level ground.
Edit: (with the car sitting on its own feet)
[This message has been edited by RidinLow (edited March 05, 2001).]
RidinLow is offline   Reply With Quote
Old 03-05-2001, 11:12 AM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I did mine jacked up. What a mistake. Hurt my hand trying to line up the endlink bolts. It was my second mod.... what can I say? *shrug*
Old 03-05-2001, 11:17 AM   #4
Skobie
Member#: 3307
Post
The sway bar is not active when the car is on level ground, bearring its own weight (there is no pre-load on the bar). In this condition, the bar (therefore the bolt holes) will not be feeling any strain forces, so alignment is the easiest here.
Skobie is offline   Reply With Quote
Old 03-05-2001, 11:21 AM   #5
Puckaveli
Member#: 1518
00 2.5RS
Post
Thanks! I'll be sure and put in on the ramps then.
Old 03-05-2001, 11:31 AM   #6
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Dont even use ramps, just slide under it and do it. Ramps will compress the suspension a bit and put load on it. Do it on the ground. it should take you 30-45min to get it done. Getting the stock bar OUT was the toughest part, lots of twisting and turning.
STiShawn is offline   Reply With Quote
Old 03-05-2001, 02:43 PM   #7
pooreman
Member#: 3209
Post
I just installed a whiteline adj bar today took about hour--maybe. My car was on ramps without trouble. You can lower and check to lose screws/bolts afterward if your worried about compression.
pooreman is offline   Reply With Quote
Old 03-05-2001, 03:56 PM   #8
Richard A.
Member#: 79
1999 2.5 RS
RBP
Post
I did mine on ramps also, with no problem.
I did have to push up or pull down on one end to get the pin in the end link. That's puting a preload on the suspension, not a good thing unless you're going in circles. After puting coilovers on and corner weighting the preload on the rear bar was gone but now I've got a preload on the front bar. I'm getting Rallispec to make me a adj. length front sway bar end link to take care of the problem. Looks to me that if you corner wt. with the bars attached it shouldn't be a problem but all the pros say to do it detached. Check GRM's web site on corner weighting to confirm this.
Richard A. is offline   Reply With Quote
Old 03-05-2001, 07:09 PM   #9
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Post
Ok now im confused,,i understand the preloaded bar thing,but how would that hurt if both sides are preloaded just a snick?The car handles very well ,,no surprises,,,yet lol
jagcars26 is offline   Reply With Quote
Old 03-05-2001, 07:15 PM   #10
BongMan
Member#: 2399
2001 Impreza RS
Post
I put mine on while it was on the ground, anything else would be uncivilized. if you put it on jack stands you need to drive it up and down them, which heats up the exhaust. when the exhaust heats up it sucks, no fun for your arms and hands.
BongMan is offline   Reply With Quote
Old 03-05-2001, 07:28 PM   #11
Richard A.
Member#: 79
1999 2.5 RS
RBP
Post
What happens with the sway bar preload is that when you pull down on one end to get it connected you are in affect stretching the other side. So when you've finished your install the side you pulled down on has more tension on that spring than if ther was no pre load and the other side has less. This is putting wedge in the car!
Old 03-06-2001, 12:02 AM   #12
jagcars26
Member#: 2394
2009 Forester X
Smile
I did mine on the ground ,heres my question.Did any of you guys have to flex or push the bar up slightly to line up the holes?? I did ,and it compressed the springs just slighty which in turn lowered the car slighty. The bar is a 20mm fuji from Dale.It was my 1st mod back in sept and i havent had any probs,if ya got jack stands its easier.
Thanks Rudy
Old 03-06-2001, 12:43 AM   #13
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Arrow
I did mine on jack stands. I'd do it again but on ramps.
You're not gonna compress the suspension that much on ramp and it's a heck of alot easier with more room to move around.
I too got mine from [email protected] I love doing business with her...fair prices, quick service!!!
-myk
mykrrrr is offline   Reply With Quote
Old 03-06-2001, 12:54 AM   #14
bobski
Member#: 413
2006 VF-39 WRX Wagon
Post
Did mine on ramps with no problems. Gave me lots of room to work with.
bobski is offline   Reply With Quote
Old 03-06-2001, 06:31 AM   #15
Puckaveli
Member#: 1518
00 2.5RS
Post
I did the install last night in 20 minutes. I used the ramps with no ill effects. Gives you lots of room to work. Although I only drove it around the block real quick. There was a couple inches of snow on the ground so the full benifits weren't available, but the car did feel a lot more solid. Thanks for all the replies.
Old 03-06-2001, 08:20 AM   #16
jagcars26
Member#: 2394
2009 Forester X
Post
Richard..Ihad to pull both sides down just slightly,,the car sits level,im assuming i have the same preload on each side ,,is that right??
Thanks Rudy
downside to 22mm rear sway bar with stock suspension setup? bnr34rb26dett Brakes, Steering & Suspension 13 11-25-2008 03:31 PM
Sway bar install for beer or food ? dukenukem Texas Impreza Club Forum -- TXIC 19 11-05-2007 10:14 PM
Sti Cusco reas sway bar install + huge thanks to RaceComp Engineering modaddict Brakes, Steering & Suspension 2 06-02-2006 01:53 AM
sway bar install, self or garage? makofoto Brakes, Steering & Suspension 6 11-21-2002 01:20 PM
Would it be OK to run an MRT rear sway bar with stock suspension? Schleppy Brakes, Steering & Suspension 7 04-22-2002 10:32 AM
