Old 04-26-2001, 11:40 PM   #1
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
Post Weapon R coil over kit with stock suspension
is it bad to use the stock suspension with the coilover kit? im not a well financed person but i want to lower my car a little, so i need to find the cheapest yet effective way to adjust the suspension.
KillerTHC is offline   Reply With Quote
Old 04-26-2001, 11:46 PM   #2
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
fast n furious pt III
Post
stay away from weaponR stuff. the quality of their products are ..err.. you know what im going to say. if you want decent suspension, at least get drop coil springs and new shocks.
RimRockaz is offline   Reply With Quote
Old 04-27-2001, 12:30 AM   #3
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
i cant afford that kind of stuff! im 17, my school doesn't allow for jobs being that every teacher makes good use of the 1 hr. a night of hw per subject everyday. so when i do get a little money, its just enough to get small things like and intake or if i wait an exhaust. so therefore, i can afford like 2 struts or the Weapon R or i guess Ground Control is better.
Old 04-27-2001, 03:02 AM   #4
subieboy
Member#: 3611
Post
how did you get a 2001 RS then out of curiousity
subieboy is offline   Reply With Quote
Old 04-27-2001, 06:29 AM   #5
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
Wepon R............makers of fine license plate frames......
Josh
scoobiejosh is offline   Reply With Quote
Old 04-27-2001, 07:07 AM   #6
Damon
Member#: 2902
Post
i wouldnt waste my money on weapon*r trash. i'd save my money and get some real suspension. i good spring/strut combo would be a lot better than anything w/ the name weapon*r on it.
Damon is offline   Reply With Quote
Old 04-27-2001, 08:46 AM   #7
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
stop flaming Weapon R! sure they are crap and what not but i just want to know if i can use the Ground Control threaded bodies with the stock struts.
my car was a gift (i guess) from my very loving parents.
Old 04-28-2001, 06:36 PM   #8
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
anyone?
Old 04-28-2001, 08:23 PM   #9
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
so what should i do since im on a limited budget?
Old 04-28-2001, 08:42 PM   #10
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
really? but can i use the springs if i decide to get some new struts later on?
Old 04-28-2001, 10:38 PM   #11
DaveK
Member#: 2338
1988 323 GTX
black
Post
Yup. The springs should work with the KYB AGXs for example. I started out with the KYB and spring combo, but now I'm getting the Tein HA coilovers. The Ground controls are probably your best bet as they'll work with KYBs if you decide to upgrade to those later.
DaveK is offline   Reply With Quote
Old 04-28-2001, 10:54 PM   #12
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
i thought that the GC's came in a size for stock and another for KYB's. will i be able to change the struts and keep what i already own or should i go with the 5zingen?
Old 04-29-2001, 08:52 AM   #13
Dustin
Member#: 1188
2007 FJ Cruiser
Post
I see where your confusion is. The KYB strut is designed as a replacement strut to work with a stock type spring. It has a spring perch/seat that is desinged to hold a stock type spring. The strut body(the tube part) may be larger diameter as long as the perch is still sized to hold the large diameter stock type spring.
The GC coilover units use an adjustable perch that slides over the strut body(tube). They may make different kits due to the fact the the diameter of the strut bodie vary from mfr. to mfr.
Stock springs and aftermarket lowering springs have the same measurements(inside diameter/outside diameter) and thus fit on stock struts as well as KYB AGX struts.
Hope this helps some.
db
Dustin is offline   Reply With Quote
Old 04-29-2001, 11:29 AM   #14
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Post
so i should go with the 5zigen if i dont want to buy new springs/GC kit if i were to get a GC kit for the stock struts?
DBA Rotors + Ferodo Pads Combo / BC Racing Coil Over / Zeal Coil Over Kit RavSpec Suspension/Brakes/Handling 52 06-04-2014 12:21 AM
Need Weapon R Coil Over part# dacrazy Brakes, Steering & Suspension 2 06-05-2002 08:04 PM
Ground Control Coil Overs Vs. Cobb Tuning Suspension Stage I JRC 666 Brakes, Steering & Suspension 0 11-06-2001 02:36 PM
Who sells Ground Control Coil Over Kits? Swivel1000 Brakes, Steering & Suspension 3 04-29-2001 11:36 AM
Anybody familiar w/ 'Ground Control' coil-over kit? jdOgg3355 Brakes, Steering & Suspension 29 04-24-2001 06:18 PM
