Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 02-13-2003, 10:17 PM   #1
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Default Only 8 PSI boost...
I installed a boost guage today, and I'm only getting ~8 PSI boost. The car has not felt quite up to power for the last few days, and I have a definite BOV sound at ~8 PSI in 1st-2nd-3rd gears(haven't run it up any higher, yet) with a hesitation as boost levels off.
I'm getting ~20in VAC at idle, and no 'funny' or unusual sounds or any CEL's.
The car is an '02 MT sedan with the 3/16" restrictor mod, and a hacked silencer as the only mods.
Thanks
Scott
Old 02-13-2003, 10:50 PM   #2
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Lightbulb solinoid response
Sounds to me like your just running wastegate spring pressure ~8psi. Perhaps your stock solinoid isnt bleeding any pressure into the atmosphere. Surprised that your not showing and CEL's. Check the connection into your soliniod, both hoses and electrical connection. If either hose was disconnected though, it would still bleed some and pull more than 8, so im almost 100% positive that the soliniod isnt functioning properly, so try disconnecting it and reconnecting it. Perhaps reset the computer by disconnecting the battery for 5-15mins, just long enough to reflash the computer. See if that works
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 02-13-2003, 11:12 PM   #3
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
Like Jeff said, check the hoses and the solenoid and try resetting the ECU.
Try to switch solenoids with another WRX and see what happens with your boost...if you get full boost, take it to the dealer and bitch at them until they fix the problem.
I had to buy the solenoid myself and it cost like $120
thebusiness999 is offline   Reply With Quote
Old 02-13-2003, 11:34 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
Thanks...
Sorry for the n00b question, but where is the solenoid...?
I did replace the air filter a week or so ago....
Scott
Edit: Got it....BTW, I forgot some nice person posted the shop manual....
Old 02-13-2003, 11:41 PM   #5
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
It lives beneath the plastic plate just in front of the passenger side strut tower. You should be able to hear the solenoid cycle when the car is under enough load to bring it out of vacuum. Listen for a clicking sound. You may need to have someone apply throttle while in gear and left footing, though this is dangerous. Unfortunately I dont know what the stock BCSDC.
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 02-14-2003, 12:53 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
DAMN....Me thinks the solenoid is toast.
Everything is good as far as I can tell vacuum line wise. Did the quickie ECU re-set and NO JOY.
thebusiness999....Were these your symptoms?
Any other ideas, anyone?
Old 02-14-2003, 01:19 AM   #7
Bad Dogg
Member#: 8331
2002 WRX Wagon
Stealthified
Default Same thing happened to me
It was not the solenoid, but something wrong with the turbo itself!! Took it into the dealer, was replaced under warranty.. Now getting 13-15 lb boost like always...
Take it in and have it checked out
bD
Bad Dogg is offline   Reply With Quote
Old 02-14-2003, 02:09 AM   #8
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
yea, the car is basically stock, there's no reason why you shouldn't bring it back to the dealer
and even if you're past 36k, I think turbo is under the power train warranty
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 02-14-2003, 02:32 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
The nearest dealer to me is ~50 miles, and per their website, the earliest I can get in is 0700 19FEB....They better have a cheap rental!
DAMN!!!
Still under 36k mi., soooo....
Thanks again
Scott
Old 02-14-2003, 10:13 AM   #10
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
~50 miles
wow, I'm spoiled here in the NE, there's a Subaru dealership every 10-20. From most places at least/
I still think it'd be worthwhile, but I would check with them about the rental, would really suck to get stuck out there for a bit
speed safely
Brian
Old 02-14-2003, 10:19 AM   #11
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
it might help to know for sure what is wrong.
Get a friend to rev the engine several times to redline (quickly so you build boost). The goal is to build as much boost as you can while sitting in neutral.
Now, while he's doing that, hold your fingers around the solenoid and feel if it's clicking open or not. Nothing will happen if you aren't revving it correctly or if your solenoid is broken.
nhluhr is offline   Reply With Quote
Old 02-14-2003, 10:30 AM   #12
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
my solenoid works fine and I think the highest boost I've ever gotten in neutral was 3psi, and I was thinking that was mainly because of the throttle position and the ebc
speed safely
Brian
Old 02-14-2003, 10:58 AM   #13
agwrx
Member#: 32663
2002 wrx
white
check the hoses i sound like what i did. there is a restrictor i the hose on the one going to the turbo look in the hose and make sure it is there. you might have switch the hose around. after my mbc off i had the hose switch around.
agwrx is offline   Reply With Quote
Old 02-14-2003, 12:01 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
DOH!!
Got it figgured out...I had put the hoses I removed back wrong when I was playing with a MBC idea..... agwrx gave me the hint.
Thanks for all the help.
Scott
Old 02-14-2003, 04:03 PM   #15
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
glad I could help
good to know either way
speed safely
Brian
Old 02-14-2003, 04:46 PM   #16
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
Yup, those were my exact symptoms. And of course that stupid dealer refused to even consider replacing the solenoid, so I had to do it myself They thought it was impossible that it would fail and that a CEL would come on if it did fail
edit: I just read through the thread and see you fixed it. Good stuff
Old 02-14-2003, 07:53 PM   #17
scoop
Member#: 10472
'02 WRX Sedan
'02 Yamaha R6
I did the same thinga couple of weeks ago. I replaced the hose from the turbo inlet to the T fitting. It took me a while to realize that I had removed the restrictor.
scoop is offline   Reply With Quote
Old 02-28-2003, 10:09 PM   #18
VolkWRX
Member#: 15885
2008 Subaru
Legacy GT Spec B
SO basically if you dont have the stock vacuum hoses, a person should order the stock lines from the dealer to alleviate the problem?? PLease let me know, cause i have replaced the vacuum lines and now experience the same problem. Thanks.
Ryan
VolkWRX is offline   Reply With Quote
boost is only 8 psi why Turbospool72505 Newbies & FAQs 31 11-12-2009 10:37 PM
Only 8 PSI? GlennC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-08-2008 02:56 PM
hitting only 8 psi stealth84ct AccessPort 4 08-07-2006 11:12 AM
Need help. Boosting only 8 psi atom945 Engine Management & Tuning 4 11-21-2005 08:56 PM
only 8 psi boost stock? solomrus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-16-2001 03:15 PM
