Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 02-14-2003, 09:36 PM   #1
RisingSun
Member#: 32053
Question Does "lightweight rear window glass" mean "thin and will break easily"?
According to the Subaru press release, the STi has "Other weight reduction measures include the use of lightweight rear window glass, aluminum control arms and forged aluminum wheels." I've never seen anything like that on a car, so I have no idea if it's going to be fragile and expensive to replace.
RisingSun is offline
Old 02-14-2003, 09:47 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Does "lightweight rear window glass" mean "thin and will break easily"?
It will be more fragile than the rear windscreen of a 2002-2003 WRX. I think it might have the radio antenna imbedded in it and, if so, it'll be more expensive to replace. Of course, there's not been a single report of rear windscreen failure in any 2002-3 US WRX.
Jon [in CT] is offline
Old 02-15-2003, 12:03 PM   #3
Brahmzy
Member#: 3293
'14 FXT-T
135i..gone > '15 STi?
Yeah, gimme a break! Since when does rear glass break ?!?!
Now if the windshield was a lot thinner, then we can worry. Who cares if it's thinner. The thinner the better.
Brahmzy is offline
Old 02-15-2003, 01:52 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Your jokeing right??
First off this isnt FORD were talking about here....
2nd... hahhahah
Third....With all the testing the car has to go threw before the DOT will aprove it.....
totoherbs is offline
Old 02-15-2003, 02:35 PM   #5
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Thinner glass will mean less soundproofing (more road & wind noise) and also when it's cold outside your windows won't be as much insulation as usual. In summer I don't know if it will be cooler (less magnification of heat) or warmer (less blockage of heat)?
The major difference will probably be road noise & replacement cost.
-s-
scotty305 is offline
What do the #s on rear window mean? 03 Black R3x Southern California Impreza Club Forum -- SCIC 4 01-26-2005 07:38 PM
Does the rear window washer nozzle spray or stream? Airboy General Community 13 01-19-2005 09:33 AM
04 rear window does not close completely e8w117 Interior & Exterior Modification 0 01-07-2005 08:12 AM
Does anyone else's rear window rattle? Spoolin16PSI Impreza Forum 19 03-23-2004 08:01 PM
does this mean the US will be getting cooler cars from now on? RaceCarRiot News & Rumors 28 01-08-2003 03:39 PM
Message Board Statistics All times are GMT -4. The time now is 02:45 AM.
