Old 02-16-2003, 11:24 AM   #1
Blue02WRX
Member#: 5841
Default questions about DIY 5-wire WB sensors
ok, is the bosch sensor in some way better than the napa echlin sensor. i can find the echlin sensors all day long and they are cheaper. i was wondering if they are just cheaper in price or cheaper in quality. another question...i was planning on putting the sensor in the bung in my vishnu uppipe, would there be any downsides to this.. some people have said to put it in the downpipe...if this is the best place i will put it there butcan someone tell me where...2 inches from turbo, 4 inches...? thanks, Brian
Blue02WRX is offline   Reply With Quote
Old 02-16-2003, 02:24 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
You have to be careful about the part number. If you buy any of these:
Honda P/N 36531-P07-003
Echlin P/N OS791
Bosch P/N 13246
you'll receive the same 5-wire wideband sensor manufactured by NTK. So buy whichever is cheapest and available.
Don't mount the sensor in your uppipe. Pressure there is likely twice your boost pressure and will screw up the sensor's readings. Mount it in your downpipe. The sensor's probe inside the pipe must be perpendicular to the exhaust gas flow. And, ideally, the sensor would be positioned so that it is vertical (i.e. sticking straight up in the air). However, you can mount it as much as 30 from vertical and still be OK. So, mount it in your downpipe as far as possible from the turbo while observing the other restrictions.
Jon [in CT] is offline   Reply With Quote
Old 02-16-2003, 03:02 PM   #3
Blue02WRX
Member#: 5841
i have bypassed the rear 02 sensor, can i mount it in that location? it is very close to perpendicular. there is a bolt in there now.
Old 02-16-2003, 04:24 PM   #4
teiva-boy
Member#: 22825
Yes you can do that. Shiv dis it this way with my car.
teiva-boy is offline   Reply With Quote
Old 02-16-2003, 04:29 PM   #5
DocDetroit
Member#: 24977
2003 WRX
How did you bypass your rear O2 sensor? I am just about to install my FJO wideband kit and would prefer to use the bung that's already there if I can.
DocDetroit is offline   Reply With Quote
Old 02-16-2003, 05:28 PM   #6
teiva-boy
Member#: 22825
We unplugged it. It caused a CEL but who cares it was for tuning purposes anyways. I now have two bungs on my downpipe about 6" from the turbo
Old 02-16-2003, 05:37 PM   #7
Blue02WRX
Member#: 5841
i bought an o2 simulator from my friend who does a lot of honda stuff and put the rear o2 in the upipe and am going to put the wideband in the downpipe, the stock o2 is heated so if you unplug it wrap it up with foil or something. if you bypass it you won't get a cel, but if you bypass it and unplug it you will get a cell i think...i may be wrong.
Old 02-16-2003, 11:19 PM   #8
Davenow
Member#: 23676
Default OK when I get the WB o2
What guage do I need to hook it up to? How do I wire it?
Old 02-16-2003, 11:26 PM   #9
DocDetroit
Member#: 24977
2003 WRX
Wideband O2's don't really work the same way. They require a "controller".
Some choices are Labdaboy, FJO, and DYI. They are pretty pricey. The FJO datalogging kit goes for over $750. The Lambdaboy is roughly $500 if I remember correctly but it doesn't datalog. The DIY is something like $300 if you buy it assembled. That doesn't include the sensor though. I beleive the sensors go for $100. I think there is a DYI version that you can datalog with.
For my FJO, the wiring is simply switched 12 volt, ground, tach signal, rs-232 (serial cable for the lap-top), and of-course the wideband O2 sensor. The FJO comes will connectors for everything.
Question about 2.5 STI (2004) and 2000 Legacy Outback 2.5 jrodnj Subaru Conversions 0 03-27-2009 12:25 PM
Question about DIY tilt on TMIC??? 04subyrex Newbies & FAQs 13 10-17-2007 06:42 PM
Difference between 4 & 5 wire O2 sensor Petersubaru Normally Aspirated Powertrain 9 12-14-2006 07:42 PM
5 wire NTK sensor for DIY wideband kit. mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 05-28-2003 04:54 PM
Imprezer: Question about Your PIAA Wiring Instructions Using the Stock Switch. Yotsuya Interior & Exterior Modification 3 03-12-2001 06:30 PM
