Old 02-16-2003, 11:10 PM   #1
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Question Looking for Comparison Compression For MY99 RS-T
MY99 Impreza RS-T with 78,000 miles
Last 10,000 miles on boost
Compression
1 - 155
2 - 150
3 - 155
4 - 170
Anyone have any numbers for a MY99 for a comparison?
edit: (These are engine cold numbers.. I guess I should redo the test with the engine hot...)
Revision is offline   Reply With Quote
Old 02-17-2003, 10:38 AM   #2
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default I would suggest doing them hot...
Here's Nick's thread when he had his Minnam Turbo kit with the TEC-II:
http://forums.nasioc.com/forums/show...hreadid=103731
Hope this helps.
Kevin
latinskllz is offline   Reply With Quote
Old 02-17-2003, 12:08 PM   #3
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
The more compression test numbers I see the more worried I get. My 99 with 72,000 stock n/a miles tested below 155psi on every cylinder while the engine was still quite hot. With n/a people seeing 190+ and even nick with his turbo having higher compression than me, I am a bit worried. Time for a leakdown test I guess. Maybe I will have a bulit engine before I get the turbo in.
Surb00 is offline   Reply With Quote
Old 02-17-2003, 12:27 PM   #4
tulit
Member#: 338
09 STi
Actual compression numbers are pointless because so many variables will effect them (temp, alt, starter rpm, etc)
Whats more important is that the compression numbers are consistant across the cylinders.
The service manual spec says the spread shouldn't be any more than 49kPA (7PSI)
tulit is offline   Reply With Quote
Old 02-17-2003, 08:28 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Wink
Dear Andrew -
You're paranoid.
Sincerely -
- Nick
Old 02-18-2003, 03:16 AM   #6
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I agree!
LVSUBARU is offline   Reply With Quote
looking for a fuel map for comparison bonestockrex UTEC 0 06-11-2007 04:57 PM
MY99 RS the way she's supposed to look ;) 2pt5RS Member's Car Gallery 19 08-16-2005 06:17 PM
('93-'01) what is the best power mod to do first for a MY99 RS? aarneson Impreza Forum 2 05-21-2001 07:37 PM
MY99 RS Wheels & Tires for sale Surf Bay Area Impreza Club Forum -- BAIC 0 07-14-2000 07:42 AM
RS sighting: MY99 RS coupe (white) and MY00 RS coupe (blue) 5 Zigen Vancouver Impreza Club Forum -- VIC 1 04-10-2000 10:23 PM
