Old 02-17-2003, 02:15 AM   #1
B-Kerr
Member#: 14841
2002 Impreza WRX
WRB, VF22, Cusco, Unichip
Question Anyone with conclusive data on wheel/tire weight effects on 1/8 or 1/4 mile times?
I was just curious if anyone had any data on the effects of tire/wheel combination weight on acceleration, i.e., 1/8 or 1/4 mile times. For all practical purposes, I would prefer 1/8 mile time effects because acceleration and looks is more important on the street; If I want to run good at the track in the 1/4, an ugly set of drag lights and hoosiers would be the way to go.
I'm asking becuase I want to get a good looking set of wheels for daily driving, but 18's seem to weigh so much unless you buy expensive forged wheels. For the few times I would go to the track, I could always revert to stocks. I just thought someone would have a comparison.
Please give some input.
Thanks,
B-Kerr
B-Kerr is offline   Reply With Quote
Old 02-25-2003, 07:27 PM   #2
psalm
Member#: 24404
2003 WRX Sedan
Black Pearl
Don't know about times, but no matter how light your wheel, your 18's will weigh a lot because of the rubber.
psalm is offline   Reply With Quote
Old 02-25-2003, 11:05 PM   #3
brembo
Member#: 33295
2003 WRX Wagon
World Rally Blue
A dramatic example would be going from the +/- 50 lb. 17" runflat tire/OE wheel (that's 200 total) to a 15" SSR Competition (8.6 lbs.) with a light tire like a 195/55/15 Toyo T1-S (16.5 lbs.)for a total of 100 lbs.-- that would save 100 pounds off your vehicle weight (roughly like adding 10 extra horsepower) and would have the same effect on A.B.C. vehicle dynmaics as saving a whopping 1,000 pounds of sprung weight.
Hmmm. That seems to good to be true; might have to consult the aforementioned friends to see if those relationships (5:1 wt/hp, 1:10 unsprung/sprung) hold true when one's car goes on a dramatic diet-- I was originally talking about taking only a few pounds off each corner...
From here....
Linkage
brembo is offline   Reply With Quote
Old 02-25-2003, 11:44 PM   #4
apwrx
Member#: 13957
02 Wrx sold
mbp
well not totally conclusive but my experience at the track.
best with stock wheel/tires 13.6
best with 18's and 225 13.9
same day same launch etc.
apwrx is offline   Reply With Quote
Old 02-26-2003, 07:36 PM   #5
B-Kerr
Member#: 14841
2002 Impreza WRX
Talking MORE INPUT!!!! Johnny 5 Alive!
AP, just out of curiousity, do you have weights for the 18s w/wo tires? It would be greatly appreciated if you do!
Thanks for the input!
B-Kerr
Old 02-26-2003, 08:04 PM   #6
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I think grass roots did a whole art on that. I have it somewhere.
Peaty is offline   Reply With Quote
Old 03-03-2003, 05:02 PM   #7
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
I found this a while back.
http://www.siscom.net/~welter/racing/rotation.html
And here's a list of wheel weights from wheelweights.com.
http://wrx.heavyplasma.com/wheels.pdf
kenshiro is offline   Reply With Quote
Old 03-06-2003, 11:10 PM   #8
apwrx
Member#: 13957
02 Wrx sold
mbp
i forget exaxtly but i am almost pos.its 21lbs without tire
Old 03-06-2003, 11:57 PM   #9
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Articles
B-Kerr,
A really great article for you to read on this would be Sport Compact Car, January 2001 issue (Power, Weight, Grip). They tested 12 wheel/tire combos on 3 cars, on two race tracks and tested 1/4 mile times. Here is one of the test results.
Tire/Wheel info: "Enkei Wheels and BFGoodrich Comp T/A ZRs
225/50-16,
225/45-17,
225/40-18
Enkei 16" RF1 (16's NT03s N/A during test) @44.5lbs wheel/tire weight total
Enkei 17" NT03 @47lbs wheel/tire weight total
Enkei 18" NT03 @46lbs wheel/tire weight total
2000 Mitsubishi Eclipse GT (weight (3050lbs)
Wheel:
16" [email protected]
17" [email protected]
18" [email protected]
Other tests where done as well but this hopefully helps with the 1/4 mile aspect anyway. I figured that most people here would be at or around 3050lbs driving their Impreza. Sorry, no 1/8th info available.
Also, you may be able to somewhat 'offset' the gain in rotational mass of the wheel/tire combo by reducing it somewhere else. For instance, reducing the rotating mass in your flywheel, pulley, pistons, crankshaft, etc. Good luck!
Kevin Thomas is offline   Reply With Quote
Old 05-29-2003, 10:26 PM   #10
TripleOne
Member#: 37388
2002 Impreza WRX JDM
Red
My 0-100kmh time was 0.7s worse. Stock was 16" with Advan 205/50, now 18" with Firenza 225/40.
TripleOne is offline   Reply With Quote
Old 05-29-2003, 10:41 PM   #11
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
my best 1/4 with 18" rota sub zeros with nitto nt555 extremes is 13.064 with a 1.89 60'
best with stockers... 12.64 w/ 1.75 60'
-mike
MJU1983 is offline   Reply With Quote
Old 05-30-2003, 07:42 PM   #12
B-Kerr
Member#: 14841
2002 Impreza WRX
Default Cool..
Appreciate all the help!
B-Kerr
Old 05-30-2003, 08:44 PM   #13
makofoto
Member#: 25243
2006 Legacy Outback
look for the current Grassroots Motorsports magazine ... they do a short autoX course test ... the lighter combination was something like a good .1 seconds faster ... maybe a bit more.
I just went from 13 lb. 17 X 7.5 SSR's w/ 225 S-03's at 25 lbs each to 215 Toyo T1S's at 20 lbs each ... and the car feels spunkier ... but don't forget that the T1s's in 215 are also a little shorter ... so that is going to help acceleration ...
makofoto is offline   Reply With Quote
Old 06-01-2003, 02:47 AM   #14
iflybyu
Member#: 20292
2002 Impreza WRX
Platinum Silver
Default One other thing to consider
.. now I may be wrong on this, but also in cosideration of the weight issue is how far out the weight is. For example, a 15" rim has it's total mass closer to the center - and a 18" rim has it's mass even farther out. I don't remember the physics of it, but it seems to me that the farther the weight is outward of the center, the harder it is to start it spinning - therein loss of power. The reasons for the weight being farther out are somewhat obvious too .. since the rim itself is farther out from the center than a 15" rim - and the tire on a larger rim has all it's mass farther out plus the extra material that's needed to reinforce it's sidewall etc.
I know for instance on my car that the first set of rims I bought (Motegi MR7) made a substantial taxing on the performace of the car. I returned them immediately and ordered Rota Attacks - which had no noticeable difference in performance over stock. The 16" stockers weighed 12lbs a piece lighter than the MR7's w/ 225/45/17 for instance.
Someone may have to correct my physics here..
iflybyu is offline   Reply With Quote
Feeler: Lubro-Moly and Motul oils 07WRXwgn Vancouver Impreza Club Forum -- VIC 11 12-11-2012 02:21 PM
AT&T to data users: [Nelson] HA HA! [/Nelson] cucamelsmd15 Off-Topic 142 06-11-2010 01:08 PM
So how was your last test drive? dome24 Alaskan Impreza Club Forum -- AKIC 8 06-04-2010 06:47 PM
Nitro Circus Live Highlights lummer shawn Vancouver Impreza Club Forum -- VIC 6 06-02-2010 03:23 PM
what other options do i have for rear view camera? 06D Car Audio, Video & Security 1 06-02-2010 12:04 PM
