Old 02-17-2003, 06:02 AM   #1
spiralsmurf
Member#: 16085
2005 STi
Default gauging interest on titanium internals and flywheel
I'm gauging interest as to how many people would consider titanium pistons? My cousin owns a machine shop with multiple CNC machines, vertical mills, and well basically has all the tools to make pistons, rods, and even flywheels for that matter. He's considering doing work in titanium and was wondering if there would be a market for these or any other products you can suggest.
Let me know,
thanks danny.
spiralsmurf is offline   Reply With Quote
Old 02-17-2003, 06:06 AM   #2
tdxflex
Member#: 13634
i'm assuming cast design, would these be stronger than forged aluminum?
tdxflex is offline   Reply With Quote
Old 02-17-2003, 06:38 AM   #3
spiralsmurf
Member#: 16085
2005 STi
not sure. can titanium be forged? titanium is generally stronger than aluminum and much lighter.
Old 02-17-2003, 10:42 AM   #4
N/A
Member#: 133
TBA TBA
TBA
Is titanium safe to run with so much pressure and heat? It would also expand at a different rate then the aluminum block so would that be an issue?
N/A is offline   Reply With Quote
Old 02-17-2003, 11:13 AM   #5
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
ill only be interested if its the strongest avalible (hmm, now what would dom toretto get )
YaZahX is offline   Reply With Quote
Old 02-17-2003, 01:15 PM   #6
Chuck H
Member#: 20442
I've heard of people getting titanium rods, but never titanium pistons. I'd think a lot of R&D would have to go into that to make sure that the design works with the differing expansion rates of the pistons and block, as well as the pistons and rings, etc. It's not going to be a simple undertaking to design titanium pistons.
Chuck H is offline   Reply With Quote
Old 02-17-2003, 01:44 PM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
FYI:
strength to weight ratio, from light to heavy:
Titanium
Aluminum
Steel
Ultimate Tensile Strength from strongest to weakest:
Steel
Titanium
Aluminum
Mass per volume from lightest to heaviest:
Aluminum
Titanium
Steel
Basically, since you're limited to a certain dimension, you want to stick with steel for strength and durability.
nhluhr is offline   Reply With Quote
Old 02-17-2003, 01:45 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I wouldn;t run titanium pistons on the street but that is just my opinion. SO no, I would not be interested.
And as far as internals and flywheel, are rotating assymbalies are light enough because of the boxer design. you really don;t want any less rotating mass. You will run into bearing problems and other various problems in the long run
Eric
Eric SS is offline   Reply With Quote
Old 02-17-2003, 01:50 PM   #9
Gerry
Member#: 1829
You can't use titanium for pistons...Ti dosn't work well with heat.
The tolerences will be too tight. Meaning piston to wall..they won't expand.Ti dosn't like to be heat cycled..Rods on the other hand..If you could do a set for under 1g i am in...Gerry
Gerry is offline   Reply With Quote
Old 02-17-2003, 02:11 PM   #10
spiralsmurf
Member#: 16085
2005 STi
ok. so the general consensus is that titanium is not good for pistons. he could definitly make rods, but he doesn't want to just make one part at a time. he wants to make a bunch. he's not a store, he'd rather do volume than mark up. so if you know people who'd buy numerous sets, then we could work it out.
Old 02-17-2003, 02:16 PM   #11
WRXcellerate
Member#: 26654
2003 Impreza WRX
Actually rods would be a very good Idea and I stil think it would be a good Idea to try and make a lightweight Flywheel outta Ti
WRXcellerate is offline   Reply With Quote
Old 02-17-2003, 03:27 PM   #12
spiralsmurf
Member#: 16085
2005 STi
Ti would be way too light for a flywheel. it wouldn't even be a flywheel at that point, more like a paper plate. if we could work out a group buy of 10 sets, i could work out some pricing details.
Old 02-17-2003, 03:30 PM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
ummm... they make aluminum flywheels, which is lighter than ti.
all aluminum flywheels have a steel insert for the clutch
Old 02-17-2003, 06:41 PM   #14
N/A
Member#: 133
TBA TBA
TBA
Wouldn't a titanium rod require a special bearing since the metallurgy involved in titanium. Titanium is supposed to grab onto other metals so it might damage the crank unless designed carefully. At least thats what the guys at RPS used to say.
Old 02-17-2003, 08:33 PM   #15
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Eric
You are kidding right? Boxer design has nothing to do with rotating mass. You are still accelerating and stopping the rod and piston as the crank spins. Lighter weight, while retaining tensile strength will always help.
wawazat is offline   Reply With Quote
Old 02-17-2003, 08:47 PM   #16
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
The design of the boxer makes for a very short crank. That decreases rotating mass.
Old 02-17-2003, 08:49 PM   #17
spiralsmurf
Member#: 16085
2005 STi
pauter makes titanium rods for $548 per piece. i can guarantee that my price will be around $500 cheaper for the set of 4. i need to get a couple people who are interested so we can do a run of maybe like 10 sets.
Old 02-18-2003, 12:21 PM   #18
Gerry
Member#: 1829
That's not that great of a price considering there hasn;t been any R&D on it. I'm sorry but I can't trust someone who just made a set of rods on a CNC and slap them in a 20 grand engine.I'm sure he may be a good machinest but that's a chance some people are not willing to take.Ti rods can be bought from C&V in australia for $1,100..Also what kind of rod is he going to copy? H-bean, X-beam..ect....
Old 02-18-2003, 05:27 PM   #19
spiralsmurf
Member#: 16085
2005 STi
this is true gerry. he does not build car parts and we were planning to design the rods based off other designs and have someone test it out for us.
Old 02-18-2003, 06:11 PM   #20
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i need valve spring retainers made, see what he can do for those.
jeremy
Old 02-18-2003, 06:24 PM   #21
N/A
Member#: 133
TBA TBA
TBA
Too bad we can't use parts from other designs like using the Pulsar N1's stock titanium valve spring retainers in a SR20DET motor.
Old 02-18-2003, 06:40 PM   #22
spiralsmurf
Member#: 16085
2005 STi
no problem with the retainers, but my cousin isnt going to make one set, theres no reason for him to do it. so if you can find like 5-10 people interested then we can run a set.
Old 02-18-2003, 07:02 PM   #23
tcs007
Member#: 4103
2016 Mazda6
Red
You've got a second taker on valve spring retainers.
tcs007 is offline   Reply With Quote
Old 02-18-2003, 07:44 PM   #24
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i'll find you 20-30 buyers but i need an idea on a price
jeremy
Old 02-18-2003, 08:23 PM   #25
spiralsmurf
Member#: 16085
2005 STi
who currently makes Ti retainer. i need to find out how much it weighs to guide price.
CT: Gauging Interest on TXS Stealthback and Prodrive Oval tip Fitz12444 Private 'For Sale' Classifieds 12 03-29-2006 11:10 AM
Socal: Gauging Interest on trans,rims, and other stuff silversoobie121 Private 'For Sale' Classifieds 44 06-20-2005 11:48 PM
Gauging interest on springs.... SPT and Ver5 KevinHeist Private 'For Sale' Classifieds 5 03-22-2005 07:11 PM
gauging interest on titanium internals and flywheel spiralsmurf Normally Aspirated Powertrain 0 02-17-2003 06:05 AM
gauging interest on titanium internals and flywheel spiralsmurf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-17-2003 06:02 AM
