Old 02-17-2003, 11:27 PM   #1
no1ukn0w
Member#: 25778
2007 LGT blizack.
eh?
Default newb Tranny Fluid question
I've been having some problems getting into first lately, so I decided to check my tranny fluid and its showing up RIGHT on the L.
Sooooooo my three questions.
1. Will chaging/adding fluid help in changing grears more smoothly?
2. If I just need to add some how do I know which to add and how much? I read the manual and it just says "use the same wieght" well I don't know what came with the car.
3. I'm guessing that you add fluid in the same place that the dipstick is located? Any easy way to flush the fluid?
Thanks for any/all help (and yes.. I feel like a idiot)
no1ukn0w is offline   Reply With Quote
Old 02-18-2003, 02:31 AM   #2
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
If you are running low on trans fluid, adding more will help make shift smoother and more accurate. It should tell you in the owners manual what type of trans fluid is currently in their. You do pour the fluid is in where the dipstick hole is. Is this on your WRX? If so, why are you running low on trans fluid, on a pretty new car?
-Wes
RebelINS is offline   Reply With Quote
Old 02-18-2003, 10:03 AM   #3
no1ukn0w
Member#: 25778
2007 LGT blizack.
eh?
I don't know why its low. I bought the car used at 5k miles and it now has 14k miles on it. The last time I checked the tranny fluid was at about 10k miles at the last oil change.
I looked in the manual and didn't see what wieght was already in there.. maybe I'm missing it. Does anyone know what comes from the factory?
Old 02-19-2003, 03:31 AM   #4
HomerJay
Member#: 1135
2005 WRX WAGON
Don't worry about it. All subaru's came w/ the minimum amount of tranny fluid in it from the factory. I bought mine new and it was a hair above the L mark. I would just do a tranny fluid swap instead. Put in some Motul or Royal Purple.
HomerJay is offline   Reply With Quote
Old 02-19-2003, 10:42 AM   #5
no1ukn0w
Member#: 25778
2007 LGT blizack.
eh?
does anyone have any reccommendations on wieght? Or does that just not matter? I've looked everywhere to try to find out and can find nothing
Old 02-19-2003, 11:55 AM   #6
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
75W90 GL-5 tranny fluid will do the trick and is what is specified by Subaru.
-Dave
drees is offline   Reply With Quote
Synthetic Tranny fluid question NRTmotorsports Transmission (AT/MT) & Driveline 2 12-03-2003 09:53 AM
Another Tranny fluid question lil WRXer 760 Transmission (AT/MT) & Driveline 3 11-13-2003 05:35 PM
tranny fluid question savka Transmission (AT/MT) & Driveline 3 04-15-2003 10:42 PM
Tranny Fluid Question SJwrx Service & Maintenance 2 01-20-2003 09:43 PM
tranny fluid question! ellinopedo182 Transmission (AT/MT) & Driveline 1 02-08-2002 04:14 PM
