Old 06-18-2007, 10:38 AM   #276
dauss
Member#: 108369
2005 CGM WRX Wagon
68HTA
1) The lowered suspension set-up you chose (actual drop if available)
Koni inserts, STi Pink Wagon Springs, Group N "STi" Strut Mounts(front and rear), 22mm Whiteline FSB, 24mm Whiteline RSB, KB Endlinks(front and rear)
2) The wheels you chose (size & offset).
Kosei K1-TS 17x7 +50mm
3) Your Tire brand and model (confirm that they are 225/45-17).
Goodyear Eagle F1 DS-G3 225/45/17
4) Any modifications made to prevent rubbing?
none
5) Are you rubbing??? (yes or no)
no
dauss is offline   Reply With Quote
Old 06-28-2007, 09:06 PM   #277
Nutz
Member#: 115762
'04 Wagon
Eibach wagon springs
17x7.5 Rota Grids
Falken fk-452
none
not yet
Nutz is offline   Reply With Quote
Old 06-29-2007, 04:28 PM   #278
BadAlex
Member#: 111654
2011 Legacy 3.6R
Steel Silver Metallic
wagon
Tein H-techs now SPT pinks
17x7.5 Rota Subzeros +48
Bridgestone RE-70
none
yes with H-techs and passengers and aggressive turns/ no rubbing with SPT Pinks
BadAlex is offline   Reply With Quote
Old 07-02-2007, 12:13 PM   #279
akoshy
Member#: 20931
09 Subaru
Default 17x8 STI BBS wheels with 225/45-17 Micheline Pilot A/ on wagon
Question for the group.
I have ordered for 17x8 forged prior year JDM STI take-off BBS alloy wheels with +53mm offset and 5x100 bolt pattern for my 07 REX wagon.
The question is, would I rub without rolling the fenders, if I were to put on 225/45-17 Michelin Pilot Sport a/s tires ? Especially since mine is a wagon.
Note: My wagon has the non-lowered stock suspension and note that these are NOT 17x7.5 53mm offset wheels like on the 04 USDM STi but 17x8 with 53mm offset which was unavailable in the US market.
akoshy is offline   Reply With Quote
Old 07-02-2007, 12:49 PM   #280
BlackfeetVI
Member#: 40567
RIP Worcester 6
St Florian protect us all
Akoshy, PM'd you. You should be fine with that setup.
BlackfeetVI is offline   Reply With Quote
Old 07-02-2007, 01:10 PM   #281
akoshy
Member#: 20931
09 Subaru
Thank you. Just PMd back.
Old 07-02-2007, 09:52 PM   #282
EDM
Member#: 82078
2015 VW GTI
Carbon Steel Grey
Do you have any pics of the wheels?
EDM is offline   Reply With Quote
Old 07-02-2007, 10:34 PM   #283
akoshy
Member#: 20931
09 Subaru
I have not received the wheels yet but yes, I did receive emailed pictures of the wheels, prior to the purchase. They look like BBS RE wheels, just that they are 17x8.
Old 07-03-2007, 10:15 AM   #284
EDM
Member#: 82078
2015 VW GTI
Carbon Steel Grey
Post the pics if possible. Hopefully they aren't shipping you a 5 x 114.3 in error.
Old 07-03-2007, 12:32 PM   #285
akoshy
Member#: 20931
09 Subaru
These have been on a 2002 WRX wagon (with rolled rear fenders) for a bit.
Old 10-15-2007, 02:21 PM   #286
LDadrenaline
Member#: 108372
2013 BRZ
Satin White Pearl
1) BC racing inverted coilovers, not sure of the drop, but the rear tires are tucked a little
2) rota subzeros 17x7.5, believe 48 offset, not sure though
3) Toyo Proxes RA-1 235/40/17
4) rolled the lip in on the rear
5) NO rubbing
LDadrenaline is offline   Reply With Quote
Old 10-15-2007, 03:06 PM   #287
lord8track
Member#: 154114
07 WRX Wagon LTD
1) STI Takeoff Springs on stock struts, about -1.5 camber on front and back
2) Enkei RPF-1s, 17x8, ET45
3) Falken Azenis RT-615, 235/40/17
4) No rolling
5) No rubbing
I wanna flesh out the wheel gap with tire, not an 18" wheel + rubber band. So will I be able to have a 225/45 or 235/45 tire without rub when these Falkens wear out?
Wagon Lords of NASIOC, please tell me truths.
lord8track is offline   Reply With Quote
Old 10-16-2007, 03:36 PM   #288
lord8track
Member#: 154114
07 WRX Wagon LTD
Bump for advice?
Old 10-16-2007, 10:27 PM   #289
Rick G
Member#: 3122
4) No rolling
5) No rubbing
Bump for advice?
Maybe this will help with your decision:
http://www.miata.net/garage/tirecalc.html
Your 235/40-17 Sidewall of 3.7" will increase to 4.0 with the 225/40 and 4.2 with the 235/45
And just to compare, my 225/40-18's vs a 225/45-17:
Even though my sidewall of 3.5" vs the 225/45-17's 4.0" is 1/2" less, the radius, diameter, circumference and revs stay almost exactly the same.
So 18" wheels don't "fill" the gap with the correct tire size, as my 18's with "rubber bands" have the same sidewall as yours
Rick G is offline   Reply With Quote
Old 10-16-2007, 11:31 PM   #290
lord8track
Member#: 154114
07 WRX Wagon LTD
http://www.rims-n-tires.com/rt_specs.jsp <---this one's even sweeter, it includes offset data and accounts for wheel width.
So any loss in ride comfort? And my question was whether I'd rub with the "correct size tire" but non-stock wheel width (17x8). I did have 225/40s on a set of 18" Rotas, and gave them up. I can't be sure if it was because of the wheels or the tires or even my suspension setup, but the ride is less caustic on 17s. The 18s were truly bumpy, and California roads are such that I rather have more rubber between me and the malformed road.
Old 10-16-2007, 11:37 PM   #291
littlewhitewagon
Member#: 103068
11 STI sedan
My 235/40R17 Toyo R888 is not bad for ride comfort, even though they are R comps, and I use JIC FLT-A2, they are much better than a 225/40R18 on the same setup. Your wheels will also change your ride comfort, heavier wheels will not be as nice to you compared to a lighter wheel. Your suspension has to be able to move like it is designed to...
I have 17x8 +45 Enkei RPF-1 on my wagon and you will rub if you do not roll the back, this is guaranteed for a tire like the RT-615 or anything bigger than the RE070 225/45R17. You will have 2 possible rub spots, the fender itself, and the bumper attachement point at the rear of the fender. The only way to get around this is LOTS of camber...you will need camber plates as you will rub the strut if you use the camber bolts.
littlewhitewagon is offline   Reply With Quote
Old 10-16-2007, 11:42 PM   #292
Rick G
Member#: 3122
So any loss in ride comfort? And my question was whether I'd rub with the "correct size tire" but non-stock wheel width (17x8).....
My bad... I thought your question was about this:
1)I wanna flesh out the wheel gap with tire, not an 18" wheel + rubber band. So will I be able to have a 225/45 or 235/45 tire without rub when these Falkens wear out?
Just trying to help.
Old 10-16-2007, 11:48 PM   #293
lord8track
Member#: 154114
07 WRX Wagon LTD
Well, yes, it was that too. I added the ride comfort question as an addendum to the original rub concern. I do appreciate the help all the same. I don't hear from the Wagon Lords all that often.
Old 10-16-2007, 11:54 PM   #294
lord8track
Member#: 154114
07 WRX Wagon LTD
Ok, good to know, thanks for replying! No audible or visual evidence of rubbing yet, so I hope that lasts for a while, otherwise it's time to get the baseball bat out and start clobberin' my fender...
Old 10-17-2007, 12:28 PM   #295
littlewhitewagon
Member#: 103068
11 STI sedan
Please don't use a bat on the wagon. Take the car to E Auto and they can completely flatted the lip. If you feel my lips in the back, they are so nice, they feel like they came from the factory like that. You will most likely rub when you turn hard with a load in the rear.
Old 10-17-2007, 02:29 PM   #296
lord8track
Member#: 154114
07 WRX Wagon LTD
How much is it to do?
Old 10-17-2007, 02:32 PM   #297
b_powerfade
Member#: 76118
2013 WRX Hatchback
Plasma Blue Pearl
send eauto a PM.
b_powerfade is offline   Reply With Quote
Old 10-17-2007, 02:45 PM   #298
revnseven
Member#: 72304
2002 02 WRX Wagon
11 VW Jetta TDI 6Speed
02 wagon 17x7.5 Rota subzero 48mm offset, 225/45-17 Bridgestone RE070. Tokico D Spec struts and Tein H Tech springs
Rear does rub when hitting big bumps and quick corners. Will be rolling the inner lip on rear fenders.
Brian
revnseven is offline   Reply With Quote
Old 10-17-2007, 06:11 PM   #299
Somboa
Member#: 156585
2006 WRX LTD Wagon
Can't seem to find the answer to this so does anyone know if 235/40/17 tires on a 17x8.5" wide rims with 50mm offset will fit on an 06 Wagon with stock suspension? Most of the threads I find are with 8" wide rims.. just want to make sure. Thanks!
Somboa is offline   Reply With Quote
Old 10-17-2007, 09:42 PM   #300
Rick G
Member#: 3122
I had pzero nero's in 225 on a 8.5 +45 and there was less than 1 1/2" between the tire and the front strut on a stock suspension/alignment, besides the fact that the wheels stuck out past the front fenders....
I doubt 8.5 +50 will work, since you'll be 5mm"s closer to the strut, specially with 235's
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 01:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 05:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 08:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 11:58 AM
