Old 10-18-2007, 10:35 AM   #301
littlewhitewagon
Member#: 103068
11 STI sedan
Originally Posted by lord8track View Post
How much is it to do?
A whopping 70 bux.
littlewhitewagon is offline   Reply With Quote
Old 10-18-2007, 05:25 PM   #302
lord8track
Member#: 154114
07 WRX Wagon LTD
Originally Posted by littlewhitewagon View Post
A whopping 70 bux.
Do they offer financing? J/K SOLD! I may yet have money and fender room for Work wheels somewhere down the line...
lord8track is offline   Reply With Quote
Old 10-26-2007, 01:33 PM   #303
UnFocuzed
Member#: 136133
07 WRX Wagon LTD
Urban Grey Metallic
I'm looking at buying new wheels/tires/springs for my wagon and it will all be on by next spring. I am definitely going to do prodrive springs with stock struts for now.
I want to buy Rota Torques in 17x8 +48 with a 235/40/17 Kumho Ecsta SPT. Do you think i'd be rubbing/cutting it close? Would i need to fender roll or should i just look into 17x7.5 +48 with 225/45?
I'd also plan on getting it aligned at the specs prodrive suggests
Front
Camber 1 15"
Tracking 0 02" (0.2mm) toe in each wheel
Rear
Tracking 0 01" (0.1mm) toe in each wheel
Thanks!
UnFocuzed is offline   Reply With Quote
Old 11-01-2007, 12:34 PM   #304
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
Hello.
Simple question, can I use 17x7 ET45 wheels with my 225/45/17 tyres in my 2002 (bugeye) WRX Wagon? Reason for not to buy 17x7.5 ET?? wheels is that this specific model is just something I would like to have.. Please help.
Thanks!
imppu2001wrx is offline   Reply With Quote
Old 11-06-2007, 02:48 AM   #305
littlewhitewagon
Member#: 103068
11 STI sedan
Front
Camber 1 15"
Rear
Thanks!
Need fender roll in the back to be safe. Can not further answer without rear camber angle. Your front camber is POSITIVE??? I hope you are -1.1.
Old 11-06-2007, 02:52 AM   #306
littlewhitewagon
Member#: 103068
11 STI sedan
Originally Posted by imppu2001wrx View Post
Hello.
Thanks!
Impossible to answer without a specific tire, but most likely for most standard street tires, you are ok.
Old 11-06-2007, 05:33 AM   #307
rubrduk
Member#: 126587
06 wagback...now
with more child seat!
Originally Posted by Swanny07 View Post
alright, so i'm getting really really worried about this fitment. But i'll be able to report back tomorrow and say if they fit or not... I have
-MY02 WRX Wagon
-Tien S-tech's
-18x7.5 with a 45 offset (i think that's gonna be my downfall)
-215/40/18
If somebody could report back and tell me that i won't rub i'll feel a helluva lot better. I'm going to be prepared to put the stock springs back on until i get prodrive.
i'm running a similar set up...only difference is springs and i have more rubber
06 wagon
- Prodrive springs
- 18x7.5 et45
- 225/40/18 Falken Ziex 512
- no fender mods
no rubbing with 4 people in the car
rubrduk is offline   Reply With Quote
Old 11-07-2007, 01:18 AM   #308
JP Penna
Member#: 162991
2002 WRX Wagon
Default 2002 WRX Wagon
I have 18" SSR Competition's with 225's. Car is lowered 1.5" with Eibach pro springs and KYB adj. shocks. No rubbing at all.
JP Penna is offline   Reply With Quote
Old 11-10-2007, 10:49 AM   #309
2.5wagon
Member#: 79299
1) 18" Dronell D-power 18x7.5 45+ offset
2) Tein Flex coilover and drop 1.75" all 4 corners with corner weight
3) cusco 22-24 rear sway bar with white line endlinks
i have no problem running 225/40/18 on my wagon...no rub or whatsoever even with 4 ppl in cars
2.5wagon is offline   Reply With Quote
Old 11-10-2007, 10:50 AM   #310
2.5wagon
Member#: 79299
1) 18" Dronell D-power 18x7.5 45+ offset, with Toyo T1-S
Old 03-03-2008, 11:32 PM   #311
MS88
Member#: 161344
2006 Impreza
I'm going to install my H-techs (aproxx 1.2"front and 0.9"rear) and while that going to put on my 215/45/17 falken 512s with Rota Torques +48offset 17x8. Do you guys think i should get 22545/17s instead? Will i rub? Thanks.
MS88 is offline   Reply With Quote
Old 03-05-2008, 11:17 AM   #312
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Sometimes you can get away with removing the rear fender trim strip. Sometimes you need to do a little fender rolling.
bluescoobywagon is offline   Reply With Quote
Old 03-20-2008, 12:56 AM   #313
skanave
Member#: 133716
2005 Legacy GT Wagon
Atlantic Blue Pearl
blah, I have done as much research as I could and I dont think I will have a problem, BUT it is time to ask the experts!
I am getting a great deal on a set of 17x8 Ultraleggeras.
My setup:
2005 WRX Wagon
All stock except the Swift Sport Springs on stock struts
wheels I can get
OZ Ultraleggera 17x8 +48 with 225 45 17 tiresIf i dont roll im sure it will rub, what if I do roll?
I test fit them and it look like the front was gunna be an issue
What do you experts say?
skanave is offline   Reply With Quote
Old 03-20-2008, 01:06 AM   #314
jackfrog
Member#: 158501
2013 STI Sedan
07 wagon, 17x8 48 rota, 225/45/17 w4s, f/r cusco sway, max out camber.
putting lowering springs soon. will sti pinks or gf210 rub?
jackfrog is offline   Reply With Quote
Old 03-20-2008, 10:34 AM   #315
littlewhitewagon
Member#: 103068
11 STI sedan
My setup:
2005 WRX Wagon
wheels I can get
The front is never an issue. It's the back. What tire will you use? The back rubber liner needs to be removed. Usually with a 8" wheel, you need to roll the back.
Old 03-20-2008, 10:35 AM   #316
littlewhitewagon
Member#: 103068
11 STI sedan
Your rear has almost no camber adjustment. What is a W4S?
Old 03-20-2008, 11:56 AM   #317
skanave
Member#: 133716
Atlantic Blue Pearl
but it will fit? the front just looked like it was sticking out a lil too far
i cant remember the tire, i wanna say BFG of bridgestone
Old 03-20-2008, 06:02 PM   #318
littlewhitewagon
Member#: 103068
11 STI sedan
The front looks like it sticks out. But once you put it on the ground, it is pretty flush. Also, you will want to crank in some negative camber to help with handling. I run 17x8 +45 RPF-1 with 235/40R17 Toyo R888 and I have no clearance problems... I jump my car over anything I can find. I am lowered on JIC coilovers. My next tires will be 245/35R17 and by my measurements, they should fit with no problems.
Old 03-20-2008, 10:12 PM   #319
skanave
Member#: 133716
Atlantic Blue Pearl
when it was sticking out, it was on the ground... I guess ill pull the trigger!
Old 03-21-2008, 09:20 AM   #320
littlewhitewagon
Member#: 103068
11 STI sedan
Go drive it around the block. If they are still sticking out, you need more negative camber.
Old 03-31-2008, 04:46 PM   #321
gold rush
Member#: 90110
2004 wrx wagon
1) The lowered suspension set-up you chose (actual drop if available)
Praxis Air Sudpension; up to 2 in drop.
2) The wheels you chose (size & offset).
Enkei RPF-1 17x8 45 ET
3) Your Tire brand and model (confirm that they are 225/45-17).
Bridgestone RE01-R's 245/45/17
4) Any modifications made to prevent rubbing?
Rolled rear fenders.
5) Are you rubbing??? (yes or no)
no
gold rush is offline   Reply With Quote
Old 04-06-2008, 11:38 PM   #322
MS88
Member#: 161344
2006 Impreza
TEIN H-Techs
Rota Torque 17x8 +48
Falken 912s 215/45/17
None
No
Old 04-07-2008, 12:39 AM   #323
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
UsVERSUSThem WFC #197
with the 225, 45, 17 falkens where is the rubbing? the fender or the strut?
i have
225/45/17 hankook HRII's
Rota Torque 17x7.5
BC Racing coilovers
No rubbing at all.
SubIELove is offline   Reply With Quote
Old 04-07-2008, 10:31 PM   #324
R-E-X
Member#: 131970
2004 WRX Wagon
Question 225/45/17
Does anyone have a set up with 225/45/17 with a 45 offset and does it rub?
R-E-X is offline   Reply With Quote
Old 04-26-2008, 12:11 PM   #325
Gatorbait
Member#: 139983
2006 WRX Sport Wagon
Autox only, but no rubbing. I don't have rolled fenders.
06 Wagon
Koni inserts w/ RCE Wagon Springs
Stock Top Hat, soon to be GroupN
235/40 - 17 Falken RT615 Azenis
Black Racing ProN1 17x7.5 +48
before these tires I had 225/45 - 17 Cooper Zeon 2XS, which on the car were without a doubt wider and taller than the Azenis and I had no rubbing issues. The Azenis clear the rear strut with a gap 2 mm wider than the Coopers on the same wheels.
I'm sure with lots of weight and big woops on the highway I would get some rubbing, but they aren't used there so no worries.
Gatorbait is offline   Reply With Quote
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 01:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 05:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 08:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 11:58 AM
