Old 07-02-2008, 02:17 AM   #326
SubyLoooon
Member#: 168150
2002 wrx wagon
quick question... have anyone seen 17x8.5 on a wagon?? is that tooo much??
SubyLoooon is offline   Reply With Quote
Old 07-09-2008, 09:36 AM   #327
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Quite a few have. It usually requires fender rolling. Stiffer suspension is a plus as well. It'll depend on the tires. Here's my 17x8.5 Slipstreams with 245/40/17 RE01R's:
This thread has a lot of good information - http://forums.nasioc.com/forums/showthread.php?t=791216
bluescoobywagon is offline   Reply With Quote
Old 07-10-2008, 03:05 AM   #328
lord8track
Member#: 154114
07 WRX Wagon LTD
1) The lowered suspension set-up you chose (actual drop if available)
STI takeoffs and Koni inserts
2) The wheels you chose (size & offset).
Advan RS 17x8 +48
3) Your Tire brand and model (confirm that they are 225/45-17).
Falken FK452s in 225/45/17
4) Any modifications made to prevent rubbing?
Rear fenders rolled
5) Are you rubbing??? (yes or no)
No
Am switching to 235/45s on Friday, praying not to rub...
lord8track is offline   Reply With Quote
Old 07-10-2008, 07:08 AM   #329
xennon
Member#: 141085
2002 EJ25 6spd Wagon
Quick question:
17x8 +42 on '02 wagon? Is it possible? Thanks.
xennon is offline   Reply With Quote
Old 07-10-2008, 09:45 AM   #330
bluescoobywagon
Member#: 14911
Not A Wagon!
Originally Posted by xennon View Post
Quick question:
According to the tire calculator, 17x8 +42 will stick out 0.013" less than my 17x8.5 +48's above ^^^^
http://www.geocities.com/gmfwd/pages/tirecalc.html
225's should fit fine with some fender rolling.
Old 07-11-2008, 03:11 AM   #331
xennon
Member#: 141085
What your suspension setup? My car is lowered and I think these will rub :/ Now I have STi bbs, everything ok.
P.S. In front I have STi aluminium c. arms.
Old 07-17-2008, 05:13 PM   #332
ruinthechurch
Member#: 135102
2006 WRX Wagon
KYB AGX Struts
Prodrive springs
225/45ZR17 Goodyear Eagle F1 All-Season
05 LGT wheels
I don't have this set up installed yet, (getting struts and springs today) but I was curious if I'm going to rub. my concern is that I'm running too narrow a wheel for my tires and that I will rub with the new springs and struts.
Update: after install, tires rubbed severely on struts. Camber bolts and an hour on the alignment rack fixed this. Currently no rubbing issues other than my mudflaps rubbing on driveways.
ruinthechurch is offline   Reply With Quote
Old 07-18-2008, 09:32 AM   #333
bluescoobywagon
Member#: 14911
Not A Wagon!
What are you lowered on? If it's S-techs, you'll rub...
Old 07-18-2008, 10:07 AM   #334
UnFocuzed
Member#: 136133
07 WRX Wagon LTD
Urban Grey Metallic
Originally Posted by ruinthechurch View Post
KYB AGX Struts
Prodrive springs
05 LGT wheels
I think you should be fine. I'm running stock wheels 17x7 with 225/45/17 dropped on prodrive springs.
UnFocuzed is offline   Reply With Quote
Old 07-18-2008, 01:12 PM   #335
mattminer
Member#: 90642
WKD Everything
Koni inserts and RCE wagon
BBS STi OEM
RT615 in 235/40/17
no
No
close to rubbing my strut housing htough.
-M@
mattminer is offline   Reply With Quote
Old 07-18-2008, 09:27 PM   #336
devilfluff
Member#: 90036
2002 WRX Wagon
1. H&R coilovers
2. 04 STi BBS
3. Dunlop Direzza Z1 Star Specs right now, and previously Fuzion ZRi
4. None
5. No
devilfluff is offline   Reply With Quote
Old 08-10-2008, 02:57 AM   #337
jackfrog
Member#: 158501
2013 STI Sedan
1. tokico d-specs + rear spacers, usdm pinks wagon spec, about 12-15mm front and no change rear
2. rota torque 17x8 48mm, 225/45/17
3. yokohama w4s
4. none
5. no rubbing at all even 4 ppl in car
jackfrog is offline   Reply With Quote
Old 08-11-2008, 02:52 AM   #338
NutBucket
Member#: 90804
'15 SJ, '05 GG
Dirty
1. Koni inserts + Tein H-Tech (-1.45/-1.50 rear camber)
2. Volk TE-37 18x7.5 +48mm
3. 225/40R18 Yoko Advan S.4
4. Removed rear liner
5. it rubs. needs to be rolled
NutBucket is offline   Reply With Quote
Old 08-11-2008, 02:48 PM   #339
wrxn wagn
Member#: 184196
02 10 sti
Wagon Specific Swift Springs with Tokico D-specs, 24mm rear sway+endlinks (1'' front - 3/4'' rear)
Rota SDR 17x7.5 48mm offset - Slight Camber -.4 all around.
Toyo Proxes 4 (soon to be replaced) 225/45/17
No
NO, never @ track/lugging stuff/5people/etc.
wrxn wagn is offline   Reply With Quote
Old 08-28-2008, 03:09 PM   #340
tacomaprime
Member#: 70572
2005 Tacoma
Quick question.
I have an 05 wagon lowered on tein h techs, but with 3/8" saggy butt shims installed. The ride height in the rear with the spacers, APPEARS almost stock, but not quite.
I am purchasing some 17x7.5 ROTA torques next week, and am thinking about a 225 wide tire. Think I will have rubbing issues? Fenders are not currently rolled, but if I get rubbing, they will be.
tacomaprime is offline   Reply With Quote
Old 08-28-2008, 04:11 PM   #341
lord8track
Member#: 154114
07 WRX Wagon LTD
Updated...
Advan RS 17x8.5 +48 (misread the size)
Falken FK452s in 225/45/17 (currently at 235/45)
Rear fenders rolled
No
Neither set o' tires rub!!!
Old 08-29-2008, 05:02 PM   #342
tacomaprime
Member#: 70572
2005 Tacoma
Originally Posted by ADIDAS View Post
Quick question.
Bump. I'm looking at this tire in particular
BF Goodrich g-Force T/A KDW NT
Old 09-23-2008, 11:07 PM   #343
tacomaprime
Member#: 70572
2005 Tacoma
Anyone on here running the 225/45/17 Nitto Invo? I believe this is the tire I am going to go with, rather then the bfgoodrich.
Old 11-04-2008, 06:41 PM   #344
Praet0rian
Member#: 175172
2006 STI
AW
Bringing this back...
I'm currently on Tokico D-Specs with RCE Wagon Springs + Scooby Spacer in the rear.
Drop rates are 25mm front, 22mm rear for the springs.
I just purchased OEM MY06 WRX 17x7 wheels, and am looking at 225/45 17 Falken RT-615 tires.
Should I expect a rubbing issue, or any other problems? I'm on stock camber plates.
Thanks!
Praet0rian is offline   Reply With Quote
Old 11-05-2008, 07:54 PM   #345
Praet0rian
Member#: 175172
2006 STI
AW
Anyone?
Old 01-04-2009, 04:21 PM   #346
RickDC
Member#: 199171
2004 WRX Wagon
Default Any rub with moderate lowering and 235/45/17 tires?
I am looking at lowering (1.2" front, 1" rear) springs for my stock '04 wrx wagon. I also have a brand new pair of 235/45/17s from another car and was wondering if i could put them on a 17x7.5 wheel and not have rubbing. I spoke with someone already he didn't think it would be a problem... was wondering if anyone else had experience/advice about this. Thanks for any tips.
RickDC is offline   Reply With Quote
Old 01-18-2009, 11:37 AM   #347
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
I just installed the following wheel/tire package from TireRack on my 2002 WRX Wagon:
17x7.5 ET48 wheel
225/45-17 Kumho XS tires
Mods:
RCE wagon springs
Koni Inserts
I have not experienced any rubbing yet hitting speed humps, driveway entrances, dips, etc. around town. The clearance looks fine to the eye. I have to see how it does at HPDE this spring.
Pics here:
http://www.clubwrx.net/forums/2414094-post7.html
mmiller2002 is offline   Reply With Quote
Old 02-15-2009, 05:37 PM   #348
tacomaprime
Member#: 70572
2005 Tacoma
ANyone on here have some +48 rotas with dunlop direzza sport z1 star spec's in 225/45/17and tein h techs on their wagon. If so, rubbing or no?
Old 02-18-2009, 03:12 AM   #349
WTypeRogerX
Member#: 20968
2005 WRX Sportwagon
World Rally Blue
Default Enkei RPF1
2005 WRX wagon:
Before:
1) Stock height (20mm rear sway)
2) Rota SDRs 17x7.5 et48
3) Hankook Ventus R-S2 Z212 225/45r17
4) No rolling
5) No rubbing
This summer:
1) Stock height, but would like to lower
2) Enkei RPF1 17x8 et45
3) Bridgestone Potenza RE070 225/45r17 (almost to wear bars)
4) No rolling
5) No rubbing (I think - only swapped out my snow tires / stock wheels for a few days during a warm spell in Jan.)
Originally Posted by abaxter34 View Post
the rpf1's and hankook 235/40/17's fit without rubbing. you must have rolled fenders to fit them though. between the inside of the tire and the strut there is plenty of room, more than a fingures width.
I think the poster above said he had Ground Control coilovers. Anybody else here have the Enkei RPF1s?
The SDR + RS2s never rubbed on very aggressive street driving and one track day, even while my Rally Armour mudflaps would scrape like hell on drainage dips at driveway and parking lot entrances.
The RE070s are about an inch wider than the RS2s and there was less than a finger (plus thin driving gloves) width between them and the rear struts. The worn RE070s are smaller in diameter than the SDR+RS2 and there is huge wheel gap with stock suspension. I'm going to mount an almost new set of RE070s after cording these. I'd guess the struts would be more problematic than the fender with lowering. I'm just starting research on struts & springs or coilovers, but Tokiko D-Spec or Koni inserts and Prodrive springs for more drop in front than back seems like the way to go. The strut clearance seems very tight even on stock suspension and I don't want to roll.
WTypeRogerX is offline   Reply With Quote
Old 03-06-2009, 11:33 PM   #350
jma_1000
Member#: 151694
The more I search, the more confusing it gets. So I am going to ask: will 17x7.5 +48 offset clear the 06/07 brakes? Pretty sure everyone has said the tire wont rub the strut or fender, which is good - but I just want to make sure it wont wreak havoc on the brakes. Im sitting on Prodrive springs.
jma_1000 is offline   Reply With Quote
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 02:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 06:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 09:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 11:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 12:58 PM
