Old 03-07-2009, 12:13 AM   #351
JawKnee
Member#: 16105
04 WRX Wagon |
05 S2000 | 08 G35S Sedan
Originally Posted by jma_1000 View Post
The more I search, the more confusing it gets. So I am going to ask: will 17x7.5 +48 offset clear the 06/07 brakes? Pretty sure everyone has said the tire wont rub the strut or fender, which is good - but I just want to make sure it wont wreak havoc on the brakes. Im sitting on Prodrive springs.
It will ultimately come down to the wheel itself. FWIW, I had a set of 17x8 et 48 OZ Ultraleggeras that cleared the STI Brembos w/o the need for spacers on the front of my wagon.
JawKnee is offline   Reply With Quote
Old 03-07-2009, 12:37 AM   #352
ralli-tart
Member#: 106125
06 OZ aw wagon
1) The lowered suspension set-up you chose (actual drop if available)
STI takeoffs on stock struts
2) The wheels you chose (size & offset).
OZ racing superleggeras 17" +48 offset
3) Your Tire brand and model (confirm that they are 225/45-17).
Pirelli Pzero all seasons in 225/45/17 - now i'm on toyo proxes 4 215/45/17
4) Any modifications made to prevent rubbing?
none, maybe paranoid fabrications 1/4" saggy butt spacer
5) Are you rubbing??? (yes or no)
Nope, never rubbed at all even with the p-zeroes rear or front with the sti takeoffs. although i switched over to 215s on toyo proxes 4 now.
ralli-tart is offline   Reply With Quote
Old 03-07-2009, 12:52 AM   #353
jma_1000
Member#: 151694
^ how do the 215s look on your OZ's? thats an 8" wheel, isnt it?
jma_1000 is offline   Reply With Quote
Old 03-07-2009, 10:16 PM   #354
ralli-tart
Member#: 106125
06 OZ aw wagon
oops, sorry i forgot to specify. actually, i'm not too sure about it, i never really checked. i bought it 2nd hand with the 225 p-zeros on it
i think it might be 17x7.5?
Old 03-22-2009, 04:23 AM   #355
S&S_IS
Member#: 152871
I've got a pretty aggressive ( insane for a wagon ) setup, one which will require a few mods but it's allot closer to working then i thought it would be.
limited black RPF1 17x8 +35, Falken 451 F 452R 235/45 R17 setup at the moment is OEM struts with pro kits.
initial observations. Setup is maxed OEM camber, 2 people in the car ( ~ 530lbs ), for initial 8km drive: fronts do fit well, no rubbing at all on so-so roads. rear end is horrid, with the weight that was in the car it wouldn't accelerate at a crawl without rubbing, result is a 22mm notch in the rear outside block pattern of the rubber.
next mod , ( today ) I will try coilovers on oem struts with ~ 1.2" drop F & R 400lb F 350lb R and a simple rear lip roll. I believe those two mods will solve the rear issues.
next mod beyond that is Koni yellows ( no real impact on setup in question in this case).
Front does give the impression of projecting past the fender, on compression though the arc path passes the tyre inside the wheel well. Pictures to follow.
Wheels were bought with the intention of adding WRC +20 fenders to the wagon which should happen before summer.
S&S_IS is offline   Reply With Quote
Old 03-22-2009, 11:35 AM   #356
tacomaprime
Member#: 70572
2005 Tacoma
I'll be reporting back in a few weeks on whether 225 invo's fit on a wagon lowered with h techs with 3/8" saggy butt shims. Mine come in wednesday, then just gotta wait for decent weather.
tacomaprime is offline   Reply With Quote
Old 03-22-2009, 09:10 PM   #357
S&S_IS
Member#: 152871
update, found that my struts were blown, so built my own coilovers WITH AGX cut a strut inserts. 350ft/lb (6.1kg/mm ) 2.5" ERS springs, with 1/2" of preload. fender lip is rolled and there is ample clearance. My only issue is the body roll with OEM sway bars I do get some rub under corners at speed.
I would have to say that +38 to +40 would be perfect flush fitment for a 17x8" with 235's
Old 03-23-2009, 01:58 AM   #358
rakeshmp
Member#: 162315
2007 wrx wagon ltd
black
thinking about michelin pilot a/s plus, 225/45/17, on stock rims and spt pinks. any issues?
rakeshmp is offline   Reply With Quote
Old 03-23-2009, 05:32 PM   #359
draco159
Member#: 204121
2005 WRX Wagon
CGM
Holy crap I am so confused. I plan to run RCE wagon springs with Tokico D-spec's. The wheels I'm looking at are the Rota DPT's (17x9 +42). What would be the best fit with or without fender rolling. I read somewhere that someone had 17x9 +42 with a 245/40/17 and didn't rub...but im pretty sure it was an Sti.
draco159 is offline   Reply With Quote
Old 04-15-2009, 05:31 PM   #360
bmxnwrx
Member#: 168611
2004 wrx wagon
grandpa silver
rota g-force 17x8 +48 215/50/17 on swift wagon springs? 04 wrx wagon
bmxnwrx is offline   Reply With Quote
Old 04-15-2009, 09:42 PM   #361
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I have calculated the 17x9 +43 a zillion ways, and then started all over and re-calculated it. I asked for a few other opinions and ran the figures by a couple of people that I trust to analyze my findings. I have concluded that the 17x9 +43 will fit, with fender roll and at the most may need 2-3mm worth of spacers.
What I have that is relevant to the topic:
2007 WRX Wagon
RCE Wagon springs
Koni yellows
Group N top hats front and rear
-1.8 front camber
-1.3 rear camber
225-45-17 OHTSU Zexius 427xi all seasons (for Portland winters)
Mounted on stock 17x7 +55
No rubbage, No issues.
UFOpilot is offline   Reply With Quote
Old 04-19-2009, 12:11 PM   #362
tacomaprime
Member#: 70572
2005 Tacoma
Tein H tech Springs, STock struts, Rear struts have 3/8" saggy butt shims installed.
Rota Torques, 17x7.5 +48 offset
Nitto invo's in 225/45/17
None, yet. Plan on rolling the fenders in the future to accomodate 235's
Nope, not 1 bit. With just myself in the car, which is who is usually in it, I took it to an abandoned building parking lot, and did a lot of hard turns. No rubbing at all.
Old 04-28-2009, 09:05 AM   #363
car54
Member#: 188677
2006 WRX Wagon
I was wondering since I installed pink USDM STI springs, stick struts, on my 06 wagon will 225/45-17 fit without rubbing with 17 x7 rims?. Can I go to 17 x 7.5 and still not rub? Camber front and back is -1.1. Looking to buy Dunlop Direzza Sport Z1 Star Spec
car54 is offline   Reply With Quote
Old 04-28-2009, 11:37 AM   #364
udelslayer
Member#: 117214
2003 WRX Wag'n Wagon
You can have.
I just test fit rota torques 1780s (17x8.0, +48)on my wagon and they dont look like they'd rub internally at all. outer may, but i'll roll the fenders if i have to. Inside, i've got at least 7mm of clear space between the lip of the "rim protector" on the 215 tire. i'm sure with normal tires at 225/45 it should be just right so long as the sidewall doesnt bulge too much. I'm trying to keep the tire square on the rim.You've also got to consider the max bulge will be at the bottom of the wheel where the weight is..... The fronts had 10+mm of internal clearance.
koni inserts, sti ping wagon springs.
udelslayer is offline   Reply With Quote
Old 05-06-2009, 11:14 AM   #365
bigsur1997
Member#: 125475
2005 WRX Sport Wagon
Anyone in here running Work Emotions KAI's 17x8 5x100? Any rubbing on stock suspention/.
bigsur1997 is offline   Reply With Quote
Old 05-06-2009, 03:04 PM   #366
udelslayer
Member#: 117214
You can have.
I test fitted Rota Torque 17x8 5x100, there was 5-7mm clear in the rear but no rubbing should happen.
They're similar wheels.
Old 05-06-2009, 03:30 PM   #367
turbocat
Member#: 120151
13 BRZ, 07 WRX
Wagon, 94 Land Cruiser
never mind....
turbocat is offline   Reply With Quote
Old 05-07-2009, 11:44 AM   #368
Zeker555
Member#: 72823
I've scoured this thread, but can't find a specific answer:
Will USDM STi Wagon Pink springs, on stock struts rub with a 225/45-17 on a 17x7 +48 wheel? Tires are RE960s, wheels MB Weapon / A-Tech Erasers. Car is an 03 wagon, running an 07 wagon stock suspension (struts/springs/tophats).
Zeker555 is offline   Reply With Quote
Old 05-07-2009, 12:37 PM   #369
littlewhitewagon
Member#: 103068
11 STI sedan
Highly doubt you will rub.
littlewhitewagon is offline   Reply With Quote
Old 05-07-2009, 03:06 PM   #370
udelslayer
Member#: 117214
You can have.
I doubt you will rub also. The fronts will have plenty-nuff clearance and the rears will have 5-7mm clearance. What you have to be cautious of is the bulge of the tire tread-sidewall. I am going to be running 17x8 et48 this weekend on sti pinks and it looks pretty clear!
Old 05-18-2009, 11:20 AM   #371
apsdsmracer
Member#: 139131
2003 WRX Wagon
Hi all,
I need to buy my coilovers today to get them here for the long weekend.
2003 WRX Wagon
'04 STi BBS's / 53 offset? 225-45-17 RE070's
Thinking about Megan coilovers.
Will I rub?
apsdsmracer is offline   Reply With Quote
Old 05-18-2009, 03:16 PM   #372
littlewhitewagon
Member#: 103068
11 STI sedan
Originally Posted by apsdsmracer View Post
Hi all,
2003 WRX Wagon
Will I rub?
Stock STI wheels with stock STI tires= no rub.
Old 05-18-2009, 06:25 PM   #373
plmrass
Member#: 94109
2006 WRX Wagon
VF 43 307 hp 360 tq
So I should have no problem fitting a 225/45/17 Michelin a/s plus on stock 06 rims, and wagon on d specs and rce springs with rear fender rolling then correct?? Thanks Jeff
plmrass is offline   Reply With Quote
Old 05-19-2009, 04:29 PM   #374
grinch77
Member#: 198758
2004 STi
'04 WRX Wagon
Swift Wagon springs on stock struts
MB Wepon 17x8 +46
Dunlop Direzza Star Spec Z1 225/45/17
The front is fine no rubbing the rears suck ass as of right now no one but my seven month old son can ride back there.I'm thinking it's time for new struts and a swaybar/endlink set in the rear.
grinch77 is offline   Reply With Quote
Old 06-01-2009, 08:32 PM   #375
PTam
Member#: 211814
2008 Impreza 2.5i
<-- Per my profile, this is for a 2008 2.5i Wagon (sport package, not that it makes a difference for this)
1) The lowered suspension set-up you chose - spt pinks with stock struts
2) The wheels you chose (size & offset) - Konig Zero 17x8 +48
3) Your Tire brand and model (confirm that they are 225/45-17) - 225/14/17 Goodyear Eagle F1 Asymmetric
4) Any modifications made to prevent rubbing - none
5) Are you rubbing??? No rubbing!
PTam is offline   Reply With Quote
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 01:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 05:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 08:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 11:58 AM
