Old 10-28-2011, 07:36 AM   #426
04ts
Member#: 57517
2010 Impreza WRX Ltd
Satin white Pearl
wondering if 225 45 tires on 17 x 8 wheels with 46mm offset would rub on my 2004 impreza wagon. the wagon is lowered on prodrives on stock struts. my fenders are not rolled.
thanks in advanced.
04ts is offline   Reply With Quote
Old 10-29-2011, 09:55 PM   #427
b5trooper
Member#: 99543
2015 STi Launch Ed.
2002 WRX Wagon (222k mi!)
Running 225/45s on rota 17x7.5s on an '02 wagon with good clearence. Only close spot is btw the strut and inside of the tire.
b5trooper is offline   Reply With Quote
Old 02-06-2012, 08:06 PM   #428
MindBlowin03
Member#: 11973
2005 Saab 9-2x
Sorry to bring this back but couldnt find what I was looking for.
I plan on installing 17x7 +40 with 225/45/17 and Im wondering if you see any issues with rubbing?
MindBlowin03 is offline   Reply With Quote
Old 02-06-2012, 10:13 PM   #429
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Here's some info I have. Id suggest rolling the fenders. Id be upset if I was rubbing with 225s. Previous owner fit 245s on 18x8.5s and it looked awesome. I've fit 17x8 46et with 235/45s no rubbing at all. Not agressive enough i want 18x8.5 or 17x9s
mrxr250rider is offline   Reply With Quote
Old 02-07-2012, 06:36 AM   #430
MindBlowin03
Member#: 11973
2005 Saab 9-2x
I should also mention I will be running just MachV springs(w/saggy butt spacers) and GR-2 struts so the drop wont be much at all.
Old 04-02-2012, 01:00 PM   #431
ChopstickHero
Member#: 191525
2003 WRX Wagon
1) Swift Sport wagon springs, KYB GR2 wagon struts, GroupN top hats, Whiteline front and rear swaybars with Whiteline endlinks, Whiteline rear wagon strut bar
2) Enkei RPF1 17x8 +45 offset
3) Continental Extreme DW 225/45/17
4) No modifications to prevent rubbing!
5) No rubbing!
Finally, after MUCH research, talking to others, decision making, etc... I finally installed everything and was glad to see that everything fit well and how they should be.
Thanks to this thread and others on NASIOC for answering my questions.
ChopstickHero is offline   Reply With Quote
Old 04-24-2012, 01:49 AM   #432
jege41
Member#: 280754
Default 2011 WRX Wagon with H&R Sport
I have been using the H&R Sport springs with the Koni Sports without any negative results. The Koni's alone probably would of done the trick but the amount of lowering the H&R's added gives the car a much more aggressive look for sure. If I was to do it over though I would probably skip lowering springs on a WRX, but would highly recommend the Koni's any day of the week. For 600 bucks the Koni's are the best single upgrade that I know of for a WRX. Having the quick and easy adjustability is so nice, from a stock feel to like riding on rails in less than 5 minutes.
http://www.hrsprings.com/
http://www.koni-na.com/
jege41 is offline   Reply With Quote
Old 05-09-2012, 08:45 PM   #433
tstirm42
Member#: 315212
2003 WRX Sedan
Subaru Banner
I have an 2002 WRX Wagon
1) The suspension set-up you choose (actual drop if available)
Tein S-Tech with stock struts
2) The wheels you choose (size & offset).
Rota Sub Zero 17" x 7.5" +48
3) Your Tire brand and model (confirm that they are 225/45-17).
Hankook Ventus V12 Evo 225/45ZR17
4) Any modifications made to prevent rubbing?
None
5) Are you rubbing??? (yes or no)
None
tstirm42 is offline   Reply With Quote
Old 05-09-2012, 08:54 PM   #434
fuelMuncher
Member#: 301554
2002 WRX Wagon
I appreciate the info in this thread. A must for anyone with a waggie.
fuelMuncher is offline   Reply With Quote
Old 07-08-2012, 01:22 PM   #435
Tinywagon
Member#: 157566
2002 WRX wagon
02 Bugeye Wagon
1) Suspension Setup
Swift Sport wagon springs (1.2" Front, .6" Rear), KYB GR2 wagon struts, GroupN top hats, Whiteline front and Cobb rear swaybars with Kartboy endlinks, Whiteline rear wagon strut bar, Perrin ALK, Whiteline Steering rack bushings.
2) Wheels
3)Tires
BF Goodrich Sport Comp 2 225/45/17
4) Modifications to prevent rubbing
No modification
5) Are you Rubbing?
No rubbing
Observe!
I even have no rubbing on lock to lock steering, I'm pretty sure I could get away with 235's.
Tinywagon is offline   Reply With Quote
Old 08-30-2012, 11:16 PM   #436
Pking5717
Member#: 305078
2006 WRX Wagon
Default 06 WRX Wagon
Hey guys, I am thinking about lowering my wagon but I am new to this so I figured I would ask before I go and mess up my new baby. I have 215/45/17 tires with Motegi mr118 17in with 45 offset. The suspension is stock right now. I was wondering if I would be alright to put a set of lowering springs on it with out any ill effects. Any help I can get would be greatly appreciated. Thanks in advance.
-Pat
Pking5717 is offline   Reply With Quote
Old 09-11-2012, 09:05 PM   #437
DVDAero
Member#: 247981
2005 9-2x
Tinywagon, nice write up. I was going to ask if anyone has had good luck with the Swift Sport springs. I just got new Excel-gs and Swift springs, so essentially the same drop/set up. They are going on my 9-2x. How do you like the set up on the street/ daily drive?
DVDAero is offline   Reply With Quote
Old 09-13-2012, 10:12 AM   #438
ChopstickHero
Member#: 191525
2003 WRX Wagon
I have this setup and it is a great for a daily driver. The springs rates are stiffer than stock but not as stiff as some of the other brands. The replacement KYB struts are slightly stiffer than stock as well. It is not a punishing ride by any means. If you haven't yet, get a rear sway bar to reduce some body roll.
Here's my car on the setup mentioned a few posts up.
Old 09-13-2012, 10:27 AM   #439
draco159
Member#: 204121
2005 WRX Wagon
CGM
^Those are 17's right? What tire size?
draco159 is offline   Reply With Quote
Old 09-13-2012, 11:24 AM   #440
ChopstickHero
Member#: 191525
2003 WRX Wagon
Yup, see below.
5) No rubbing!
Old 09-13-2012, 11:26 AM   #441
draco159
Member#: 204121
2005 WRX Wagon
CGM
Yup, see below.
Whoops, thank. Should have scrolled up a few more posts.
Old 09-17-2012, 09:43 PM   #442
my name is joe
Member#: 171412
Anyone rocking 17x9 +35 with 245/40/17? Not going hella flush. That's the biggest tire size I can use in STU. Im lowered on kw's with a finger gap all around. Not looking to lower anymore. This will be going on a 06 wrx wagon. I know I'll have to roll the fenders. Any other problems I should be running into?
my name is joe is offline   Reply With Quote
Old 09-17-2012, 10:02 PM   #443
sc00by4life
Member#: 97135
that much tire at that offset will require a pull on a wagon. for sure.
+35 is too low of an offset to fit that much tire. with a +42-45ish you could fit them with aggressive camber an a roll all around.
Old 11-30-2012, 03:24 PM   #444
Boostingwrx89
Member#: 279634
2002 wrx
silver psm
same goes for me! just ordered 17x9 dr31 et38..tire 255/40/17.im on a sedan though.and im going to get the fenders done anyway.cant wait to see how it looks though.im not to low right now either only on tein spring with tokico blues. what ya'll think.
Boostingwrx89 is offline   Reply With Quote
Old 01-27-2013, 12:44 PM   #445
Nor Nor
Member#: 342750
I recently purchased a 2002 WRX wagon completely stock on continental DWS tires.
I ordered Tokico D spec adjustable Struts and springs and I will be installing them soon.
I was wondering if anyone has used this setup before and I you can please provide some feed back.
Thank you.
Nor Nor is offline   Reply With Quote
Old 01-28-2013, 07:14 PM   #446
wagon_war
Member#: 320092
02 WRX WAGON
Originally Posted by cfluty View Post
I did the opposite, i ordered them, and im going to make them fit.
What was done to achieve fitment
wagon_war is offline   Reply With Quote
Old 03-31-2013, 03:14 PM   #447
dirrrtywagon
Member#: 292357
2004 WRX WAGON
will 225/45/17 04 sti wheels rub with the wagon fenders if i drop it a couple inches on coilovers?
dirrrtywagon is offline   Reply With Quote
Old 07-07-2013, 07:03 PM   #448
suby-blue
Member#: 330750
2007 Impreza SE
newport blue pearl
Default I am getting fender rub, but I am under the impression I shouldn't.
Hey! Could any one here help me with this question I posted.
http://forums.nasioc.com/forums/show....php?t=2525615
Thanks.
suby-blue is offline   Reply With Quote
Old 07-11-2013, 08:46 AM   #449
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
I run 235/45/17 on enkei rpf1 17x8 45+ on my 2002 wrx wagon dropped on usdm pink front springs and stock sti take off rear springs. Kyb excel g struts, no fender modifications, no rubbing, alignment is stock except the front camber been 1 degree negative in order to keep the front tire wear good and even.
On my 2005 Saab 92x aero, which is the same as a wrx wagon, hence the saabaru nickname, I also run 235/45/17 continental DWS. Wheels are also 17x8 but 48+ offset oz ultraleggera, usdm wagon specific pinks all around, koni inserts, stock fenders, stock alignment except for the 1 degree negative front camber, no rubbing issues.
Moral of the story is 235 tires will fit a wagon without having to modify fenders as long as the wheel offset is within 45+ to 48+ on a 17x8 wheel.
D-Rodman is online now   Reply With Quote
Old 07-11-2013, 12:40 PM   #450
loveNWlife
Member#: 353053
2003 WRX Wagon
Platinum Silver Metallic
Do you have pictures? Think of running a similar set up, just swift wagon springs though.
loveNWlife is offline   Reply With Quote
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 01:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 05:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 08:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 11:58 AM
