Old 02-20-2006, 06:33 PM   #176
Swanny07
Member#: 86493
2013 WRX 5-door
Well.... I did it... and i don't rub. I took it around some pretty nasty corners too. I didn't roll my fenders either, but i plan too. Im gonna post pics later of how close it is.
Swanny07 is offline   Reply With Quote
Old 02-21-2006, 05:14 PM   #177
04ts
Member#: 57517
2010 Impreza WRX Ltd
Satin white Pearl
swanny, how about some pics
04ts is offline   Reply With Quote
Old 02-21-2006, 09:43 PM   #178
Swanny07
Member#: 86493
2013 WRX 5-door
Your wish is my command.
(sorry for the bad pics, i took these with my cell)
Old 02-25-2006, 02:55 PM   #179
bcristea
Member#: 11343
2008 STi
Anyone know if the following will rub?
06 WRX
STi/SPT wagon specific springs (Drop: 0.5 to .75")
Rota Torque: 17x7.5 48 offset
225/45/17 RE070's
Thanks,
Brian
bcristea is offline   Reply With Quote
Old 02-26-2006, 03:14 AM   #180
kurohyou
Member#: 81266
05 wrx wagon
OPB
rotas(48 offset) usually rub with wide 225 on stock height. your choices are using higher offset wheels or rolling fenders (which imho is better in a long run allowing you to go for 17x8 and wider tires)
you may check this(spt wagon springs + sti bbs + re070s):
http://forums.nasioc.com/forums/showthread.php?t=762685
06 WRX
225/45/17 RE070's
Thanks,
Brian
kurohyou is offline   Reply With Quote
Old 02-26-2006, 11:57 AM   #181
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
Why are so many people posting stock suspension setups?
btw, Swanny07, car looks good! Good info.
hikeeba is offline   Reply With Quote
Old 02-26-2006, 08:18 PM   #182
bcristea
Member#: 11343
2008 STi
I didn't think non OE springs were still considered a Stock setup?
Old 03-12-2006, 11:36 PM   #183
BlackfeetVI
Member#: 40567
RIP Worcester 6
St Florian protect us all
Alright, I've been reading this whole thread and I'll ask the rest of you since I can't find a simliar setup at this point.
I'll be running 17x7 BBS RK wheels (+48mm offset) on an 02 WRX wagon and I'm looking at either a set of used 225/45/17 RE070 or a new set of Hankook RS2 Z212 in the same size. As far as my suspension goes, I will be stock for the next two months, and then I'll be switching over to the SPT wagon specific springs and stock struts. The RE070 and the Z212 both have a 8.9 inch width, but I read an earlier post that mentioned a 7 inch wide rim will take about .2 inches off the section width. I really don't plan on running any wider as far as wheels or tires, so if I don't have to roll my fenders I'd rather not. Does anyone have any idea on whether or not this will rub? Thanks!
BlackfeetVI is offline   Reply With Quote
Old 03-13-2006, 03:35 AM   #184
SLIGHTLY
Member#: 47909
2004 PSM WRX Wagon
awd+corner, WEEEEEE!
1) Tein Flex, Set at a Mild drop (VERY VERY mild) 24mm cusco rear swaybar
2) ssr gt7's +50mm 17/7.5
3) Bridgestone RE070
4) none
5) Slight slight in the rear on the inner lip on the top, but doesn't ever compress that much with this setup to rub
SLIGHTLY is offline   Reply With Quote
Old 03-17-2006, 06:17 PM   #185
Junip
Member#: 110232
- 02 outback sports wagon
- 215/40/18
- 18x7.5 +48mm
which brand of spring tht i should use..so that i wont rub my rear fender??
Junip is offline   Reply With Quote
Old 03-18-2006, 08:19 PM   #186
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
so after looking thru thread this i assume i will be ok with 17x7.5 rims and 225/45's with my tiens s techs ? or should i be scared of possible rubbage
99subi is offline   Reply With Quote
Old 03-18-2006, 09:39 PM   #187
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
depends on the offset. seems that < 48mm -ive offset is very likely to rub.
PJC1909 is offline   Reply With Quote
Old 03-18-2006, 09:53 PM   #188
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
darn, maybe i will have to go 17x7 then
Old 03-18-2006, 10:15 PM   #189
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
OK, don't give up. It depends on tires too. Some 225s are more "blocky" than others. unless you have like 35 offset wheels or something crazy like that, I'd try it. 7.5 is a good size for 225s.
Old 03-21-2006, 10:44 PM   #190
Stovepipe
Member#: 28696
2003 WRX wagon
World Rally Blue
Based on reading this thread, I'm going to guess this setup will rub. Can anyone confirm?
2003 wrx wagon
-sedan rear sway bar
-KYB AGX struts
-ProDrive springs
-225/45/17 Hankook RS-2s
-17" Rota Actions +48 offset, 7.5" rim
I'm currently running on 215s but I'm due for new tires, and I want to make the leap to 225s.
Thanks.
Stovepipe is offline   Reply With Quote
Old 03-21-2006, 11:08 PM   #191
ripvw
Member#: 27790
Originally Posted by Stovepipe
...Can anyone confirm?
2003 wrx wagon 2002
-sedan rear sway bar ditto
-KYB AGX struts running Koni inserts
-ProDrive springs ditto
-225/45/17 Hankook RS-2s 225/45x17 Falken FK451's - 1mm narrower in section width than your RS2's
-17" Rota Actions +48 offset, 7.5" rim running Attacks - same width and offset
what you need to make it work is a proper alignment - so you need to find a great alignment tech and give him the proper tools to work with - camber plates or another set of camber bolts up front in addition to the OEM camber bolts, and camber plates, camber bolts or adjustable lateral links in the rear. I'm using plates up front, bolts in the rear and I'm running -2F/-1.5R. The rubbing will be on the rear fender, so rear bolts are mandatory, but IMO you want .5 degrees less rear camber than the front for better handling so that's why using an additional method of camber control up front is what I recommend
or get the rear fenders rolled and run whatever you want...
ripvw is offline   Reply With Quote
Old 03-22-2006, 12:24 AM   #192
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
So, I'm getting some 17x7 +48 wheels for my wagon on Prodrive springs.
I don't want to roll my fenders, will I have rubbing issues?
WagonMonster is offline   Reply With Quote
Old 03-22-2006, 12:39 AM   #193
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Not unless you put tires on those rims!
NW OBS is offline   Reply With Quote
Old 03-22-2006, 12:40 AM   #194
WagonMonster
Member#: 3781
Yeah, what I meant was should I go 215 or 225.
I've always run 215's, so I just ordered some more.
Old 03-22-2006, 12:43 AM   #195
ripvw
Member#: 27790
you're going to run 215/45x17, right? no problem.
the beauty of the Prodrive springs is the minimal drop in the rear, right where the wagon has fender rubbing problems. lots of people running 17x7.5 ET48 Rotas with 215/45x17 tires and the Prodrive springs - no problems at all. It's when you go up to 225/45x17 that it gets interesting
Old 03-22-2006, 12:45 AM   #196
WagonMonster
Member#: 3781
Yeah, I decided to go with 215's, as usual.
I can't wait
Old 03-22-2006, 11:33 AM   #197
markmc
Member#: 87858
05 wrx wgn
cgm
05 wagon
Sti struts and 1" drop springs
18" x 7.5 subzeros
markmc is offline   Reply With Quote
Old 03-22-2006, 11:37 AM   #198
markmc
Member#: 87858
05 wrx wgn
cgm
05 wagon
18" x 7.5 subzeros
235/40/18 yokohamas
had to trim rear wheel well lip, slight camber in rear
no rubbing with 4 passengers, aggressive driving
Old 03-22-2006, 05:41 PM   #199
tegnwrx
Member#: 8589
2003 wrx wagon
-KYB AGX struts
-ProDrive springs
Thanks.
hmm you must have missed my posts on page 6 and 7
i had posted that I'm running 2254/45/17 Rs-2's w/o any rubbing loaded, at the track, auto-x etc..
I'm running prodrive springs as well, with noltec camber plates up front
tegnwrx is offline   Reply With Quote
Old 03-22-2006, 11:46 PM   #200
NW OBS
Member#: 101361
05 OBS
^^^^^^^^^ What he said. NO issues!
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 01:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 05:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 08:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 11:58 AM
