Old 03-22-2006, 11:57 PM   #201
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Thumbs up
Originally Posted by markmc
05 wagon
Sti struts and 1" drop springs
18" x 7.5 subzeros
Maybe our paths will cross someday! I am in Medford and plan on running the same rims and drop as you just soon as Mt. Ashland closes (my wagon is the 'snowboard kid shuttle' right now).
Sent PM about the 18's.
NW OBS is offline   Reply With Quote
Old 04-11-2006, 05:37 PM   #202
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
1) The lowered suspension set-up you chose (actual drop if available)s
F: JDM pinks on 02 wagon takeoffs + koni insert + RCE plate. 1.5" drop
R: Same except GrN mounts. ~1.5" drop
2) The wheels you chose (size & offset).
SSR comp 17x7.5 50mm offset
3) Your Tire brand and model (confirm that they are 225/45-17).
225/45-17 S-03
4) Any modifications made to prevent rubbing?
Planning to roll rear fenders
5) Are you rubbing??? (yes or no)
Did not rub until i reset post-lowering camber from -2 to -1. Now I am rubbing. Will report back after fenders are rolled.
PJC1909 is offline   Reply With Quote
Old 04-11-2006, 05:58 PM   #203
BigMikeLV
Member#: 99301
2010 2006 B9 Tribeca
Stock Springs and struts
Rota Torques 17x8 48mm offset
Falken Azenas ST115 235/40ZR-17
Nope
Nope
BigMikeLV is offline   Reply With Quote
Old 04-11-2006, 11:13 PM   #204
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
STi wagon spec's
UK Stock 17's (17x7)
Toyo Proxes 4 224/45/17
None
No
Bishop is offline   Reply With Quote
Old 04-12-2006, 01:21 AM   #205
Titanium
Member#: 10749
2006 WRX Wagon SGM
2006 BMW E85 3.0si
Swift wagon spec
Rota Action 17X7.5 48mm
Michelin Pilot Sport 225/45-17
None
No
Titanium is offline   Reply With Quote
Old 04-14-2006, 06:30 PM   #206
XWRATED
Member#: 111454
2003 WRX Sedan
WRB, 86' Buick GN 500 HP
I too am having difficulty deciding on a size. I cant decide between 17 or 18's. Tirerack helps you choose the correct tire that matches the diameter of your stock wheels. Therefore, If I go 17, they recommend 45's and with 18 they recommend 40's. My car will have the tokico performance spring and strut kit which will drop the front and back 1.25" each. I am worried about rough roads. Will 18's be ok, or should I be safe and go with 17's??? I really like the look of the 18's but worry about railroad track damage, potholes etc with just a 40 size tire. Anyone got 2 to throw in?
Scooby
XWRATED is offline   Reply With Quote
Old 04-16-2006, 11:07 AM   #207
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
I do not have an experience with 40s. However, the 225/45-17s are a major improvement in performance vs. 205/55-16. They are harsh enough on the street. 18s will result in a greater rotational mass, thus may adversely affect performance.
My 0.02
Old 06-14-2006, 06:06 PM   #208
kite_tmr
Member#: 83912
1998 BD STi
10cm DOM3
Default My wagon
My wagon has:
lowered on SPT springs with stock struts (its real low in back)
Michelin Pilot Sports 225/45/17's
rota GForce 48 offset 17x8's
Looks like it rubbed a couple of times on the rubber insert in the wheel well on the drivers side - but not bad enough for me to be concerned...
EDIT>>>
OK when i get sidways it rubs. It didnt really rub till i went 17x8 (instead of 17x7.5) I'm gonna get the fenders rolled next week and will post about here when i'm done...
EDIT>>>
Rolled the fenders (just a little) and now i have no rubbing at all, even with people in the back!!
kite_tmr is offline   Reply With Quote
Old 06-15-2006, 02:31 AM   #209
drf
Member#: 72873
2008 Evo X GSR
2002 M3
Okay, so I've been waiting for the SSR Type-C. However, now that it's available, I'm reconsidering.
Looking through this thread, I saw that 7 people ran SSR's with 225's, and 3 of them had rubbing. I don't want to roll my fenders. Also, since the entire reason for my wanting to get new wheels is so that I can run 225's, as much as I love the Type-C, I'm not willing to go down to a 215 just to run them.
So I was wondering if running a 17x7 +50 rim like the Kosei K1 TS would make the difference between possible rubbing and very, very probably not rubbing.
Because the Kosei is 7" wide, a 225 tire will be .2 inches narrower than on a 7.5" rim like the SSR. I'm hoping that .1" on each side is enough to clear the fender. (.1" = 2.54mm, and we since know that a 225 tire will fit w/o rubbing on a +53 offset rim, this .1" might make the difference on a +50 rim like the Kosei and SSR.)
Anyone have any first hand experience with a 225 tire on a 17x7 +50 rim behind unrolled fenders?
drf is offline   Reply With Quote
Old 06-15-2006, 04:25 AM   #210
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
so far, im runnning 235/40/18 on 18x8.
i cut the fenders in the rear, the front fenders are stock, they rub a little under hard cornering, ill probably get those rolled too.
kenny08 is offline   Reply With Quote
Old 06-15-2006, 09:50 AM   #211
bcristea
Member#: 11343
2008 STi
Why are you really low in the back?
Originally Posted by kite_tmr
My wagon has:
bcristea is offline   Reply With Quote
Old 06-15-2006, 01:16 PM   #212
NW OBS
Member#: 101361
05 OBS
Default SPT Springs are NOT wagon specific!
Classic sagging butt look... The wagon is 80-100 lbs heavier then a sedan. If you want your car level use a spring like SWIFT that has wagon specific models.
Hint: If you have a sedan with a ton of stereo equipment in the trunk, you may use wagon specific springs to lift the butt back to being level with the front.
Old 06-15-2006, 01:56 PM   #213
Mach V Dan
Member#: 12029
Uh...it'll be narrower at the WHEEL, but it'll be the SAME WIDTH at the tread. The tread width never changes no matter what wheel you run. And your fenders aren't going to run into the tire at the point where it meets the wheel -- they're going to run into the tire shoulder, next to the tread.
Using a narrower wheel will make the sidewalls of the tire pinch in. Using a wider one will make them spread out. But your most likely point of interference with the fender is the tire shoulder, and that's going to change only the slightest bit with wheel width changes.
\____/ vs. /_____\
Note that the tread width is the same in both cases, and the shoulder exposure will be about the same. (Okay, it doesn't look like it because of my ASCII art.)
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 06-15-2006, 02:24 PM   #214
horf
Member#: 35971
2002 WRX wagon
I'm on KYB AGX and Ground Control sleeves. I'm not sure how low. I can
fit 2 fingers between the tire and fender.
Rota slipstream 17 x 8. I forget the offset.
Hankook RS2. yup, 225/45-17
Quite a bit of negative camber on the rear, but no rubbing
No rubbing after negative camber in rear.
horf is offline   Reply With Quote
Old 06-15-2006, 07:28 PM   #215
drf
Member#: 72873
2008 Evo X GSR
2002 M3
Good point Dan. Wheel width affects section width , but probably won't make a difference as to whether or not the tire will rub.
In your opinion, do you think a 225 tire on a 7" wide wheel is less likely to rub than on a 7.5"?
Old 06-16-2006, 12:57 AM   #216
kite_tmr
Member#: 83912
1998 BD STi
10cm DOM3
Cause i'm lowered on sedan specific SPT springs (and i have a wagon). It looks awsome but its lower in the back than it should be...
Old 06-16-2006, 01:00 AM   #217
kite_tmr
Member#: 83912
1998 BD STi
10cm DOM3
plus i'm using sedan springs...all of my Subie friends like the way it looks
Old 06-16-2006, 02:03 AM   #218
NW OBS
Member#: 101361
05 OBS
Exclamation
Whatever. Sagging butts don't look good on Suby's OR women! Butt if your friends like the look, who am I to argue! Just need a firm rear end to peak my interest!
Old 06-16-2006, 05:59 PM   #219
kite_tmr
Member#: 83912
1998 BD STi
10cm DOM3
Actually they do look good on wagons but your rigth about women Wish i could figure out how to post pics on this damn site...
Old 06-17-2006, 06:35 AM   #220
WTypeRogerX
Member#: 20968
2005 WRX Sportwagon
World Rally Blue
Originally Posted by tegnwrx
lowered on prodrives
rota 17x7.5 48et
hankook r-s2 225/45/17
no mods to body to prevent rubbing yet (rear camber is -1.5)
just got the tires today....went for quick test drive...no rubbing. I had one person sit on pass rear seat, one on the pass side of trunk area. and i stood on the doorsill with the door open and jumped up and down while keeping a hand in the fender area....Doesn't look like I'd have rubbing issues. I'm going to the auto-x sun and will find out then if it rubs
check this post of pics comparing 225 712's, 225 rs-2, and 215/45 lm-22
http://forums.nasioc.com/forums/showthread.php?t=743928
What's the drop on Prodrives?
I just bought a set of Rota SDRs 17x7.5 48 offset and am considering buying Hankook r-s2 225/45r17 tires. Will be on stock springs and struts until next summer at least (when I hopefully wil have money for coilovers), and haven't decided on what spring/strut or coilovers.
WTypeRogerX is offline   Reply With Quote
Old 07-06-2006, 04:15 PM   #221
backdrop
Member#: 118581
Time for OMOP Op's
again...
STi wagon struts and Prodrive P1 springs
V7 STi golds (sedan 7.5")
BFGoodrich g-Force Sport
none.
Not none nary a bit
backdrop is offline   Reply With Quote
Old 08-29-2006, 06:07 PM   #222
Stovepipe
Member#: 28696
2003 WRX wagon
World Rally Blue
1) suspension: Prodrive springs, KYB AGX struts
2) Wheels: Rota Actions, 7.5" wide, +48mm offset
3) Tires: Falken Azenis RT-615, 225/45/17
4) Mods to prevent rubbing: none yet
5) Are you rubbing? Yes.
Daily driving, on ramps, etc. no problems. But auto-x with quick transitions or bumps in mid-corner induces rubbing. Pretty much as expected. Time to roll the fenders.
Stovepipe is offline   Reply With Quote
Old 08-30-2006, 01:41 AM   #223
scottjua
Member#: 2937
2013 BMW 335i
2006 STi Aspen White
2002 WRX Wagon
1) The lowered suspension set-up you chose (actual drop if available): Prodrive Springs, Koni Inserts (stock wagon strut housings), Noltec Camber/Caster Plates, 02/03Sedan Rear Sway
2) The wheels you chose (size & offset): 17x7" Subaru OEM (JDM V7 Legacy B4) wheels.
3) Your Tire brand and model (confirm that they are 225/45-17): 225/45/17 Advan Neova AD07.
4) Any modifications made to prevent rubbing?: Nope
5) Are you rubbing??? (yes or no): Nope ^_^
Track and street no rubbing ever
scottjua is offline   Reply With Quote
Old 09-08-2006, 11:47 AM   #224
littlewhitewagon
Member#: 103068
11 STI sedan
S-tech 04 WRX spec
17x8 +45
RE070, only come in 225/45R17
Roll fender and neg camber
Yes stock, a little with a roll, no with neg camber
littlewhitewagon is offline   Reply With Quote
Old 09-10-2006, 05:42 PM   #225
wrxnkc
Member#: 120978
2006 WRX Wagon
Blue 4-sale
Originally Posted by littlewhitewagon View Post
Damn, it looks like i'm going to have to look into rolling my fenders. I didn't think the wagons could do that because of how the rear fender and door meet but i'm wrong which is good. I'm pretty sure the Cobb STG II i will be installing will rub from what i've read on this thread, but maybe not with the stock wheels and tires.
wrxnkc is offline   Reply With Quote
Confirmed 18x8 rims that fit lowered WRX Wagon Drew888 Tire & Wheel 10 05-13-2007 01:37 PM
Cheap Falken 225/45/17 tires that I found DashboardCon Tire & Wheel 11 12-05-2006 05:10 PM
4 Blizzak LM22s 225/45-17" Tires 02DaWeRXs Private 'For Sale' Classifieds 5 04-05-2006 08:21 PM
Who makes front lips that fit 2002 WRX wagon? Leandro Interior & Exterior Modification 10 08-02-2004 10:57 AM
225/45-17 tire size fits ok? newsman Brakes, Steering & Suspension 17 02-10-2003 11:58 AM
