Old 02-18-2003, 02:41 PM   #1
crimedog
Member#: 20881
2000 2.5RS
Angry Damn car is stalling and hard to start sometimes!
Since I've had my 95 Impreza L series 1.8l it has been giving me problems. I try to take suggestions from everyone and I have changed a lot of parts (listed below) which were recommended to fix the prob. Here are the parts I've changed:
Plugs (bosch Plat +4)
Plug Wires
Belts
Coil
Fuel Filter
Air Filter
I took the car to Precision Tune to have them Diagnose the prob they told me to replace the coil, plug wires, and plugs (hence the new parts in list). Now $90 poorer not including the parts (I was going to get them anyway) I'm still having problems. Starter sounds strong, I seem to have decent voltage. Car dies while idling and is really moody when starting while warm (not all the way warmed up, just a little warm). Any suggestions of what the problem could be would be much appreciated, I'm baffled
Thanks, George
crimedog is offline   Reply With Quote
Old 02-18-2003, 03:22 PM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
just a quick check on your charging systems....if you have a voltmeter, go measure the voltage w/the car idling.....it should be in the mid 14's....also, check for any slack on all your belts, esp. the alternator belt......
this is just to eliminate some basic obvious......btw, your belts should not have more then a 1 in. play
vile is offline   Reply With Quote
Old 02-18-2003, 04:50 PM   #3
subaruwrxparts.com
Member#: 26010
2006 STi
If your car is dying while idling and you've already replaced all of that, try replacing the idle air control valve.
Brian
http://www.subaruwrxparts.com
http://www.wrxstiparts.com
http://www.subarubajaparts.com
subaruwrxparts.com is offline   Reply With Quote
Old 02-18-2003, 08:01 PM   #4
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default vacuum leak
First of all, Bosch is wrong for this car. Use NGK.
It really sounds like you have a vacuum leak. Check for worn, damaged or missing vacuum hoses. Check that everything past the air mass meter is tight and has no cracks. Check the intake manifold gasket. Does your check engine light illuminate?
vvk is offline   Reply With Quote
Old 02-19-2003, 01:55 PM   #5
crimedog
Member#: 20881
2000 2.5RS
Thanks all for the help, I'll give those suggestions a shot this weekend. I would have gotten NGK Platinums but the Pep Boys I went to didn't have any, and I didn't think it was a big deal.
Once again thanks,
George
Old 02-20-2003, 12:13 AM   #6
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default NGK copper
You can use NGK copper plugs in your engine. They are the best plugs in the world. Use platinums only if you need extended change intervals. Otherwise coppers are better. And much cheaper. Call around. Some local stores carry them, some don't. Ask for specific model.
However, since your Bosch plugs are new, they should be fine for about 10k miles. Your problem probably has nothing to do with plugs. Make sure your ignition wires are seated all the way -- they are tough to seat properly on these cars.
Old 02-20-2003, 01:48 AM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
You must use NGK copper plugs in your engine. They are the best plugs in the world.
(I changed "can" to "must")
Explain when the car is stalling. Is it at high speed on the highway or when at a stop light or? Does it just cut out suddenly or is it jerking and sputtering?
Old 02-20-2003, 11:33 AM   #8
crimedog
Member#: 20881
2000 2.5RS
vvk-
My car is stalling suddenly and while idling or at low RPM <1000. Thanks for the heads up on the NGK Copper.
George
Old 02-21-2003, 03:34 PM   #9
harowerksxcr
Member#: 25751
. 94 Impreza L
97 Outback Sport
Default same problems
I have a 1994 L 1.8 AWD as well and My car does the same thing. I have only replaced the plugs so far(ngk's). I'll try some plug wires and see what happens. All my belts seem fine as far as tension. The car has never died but it comes close especially when I first start it up. Just thought I'd let you know your not alone with your problems. I forgot to mention that I did the fuel filter as well. This morning was the coldest so far this winter and my car barely started and sounded abolutely horrible, I thought it was going to die for sure.
harowerksxcr is offline   Reply With Quote
Old 02-21-2003, 04:53 PM   #10
Subaru of Santa Cruz
Vendor
Member#: 8665
Cool
The symptoms you are describing indicate the cam and crank position sensors need replacement. You may have a code stored in the control unit that would confirm this. It was a common problem for mid 90's Impreza's. Subaru has a replacement kit with both sensors-I believe the kit costs about $43.00. The symptoms usually include stalling at idle, and difficult starting after the engine is warmed up,then shut off for 20 minutes or so.
This is an easy repair, and has always cured this condition.
Good Luck-
Bruce(Subaru of Santa Cruz)
Subaru of Santa Cruz is offline   Reply With Quote
Old 02-25-2003, 12:31 PM   #11
harowerksxcr
Member#: 25751
. 94 Impreza L
97 Outback Sport
Default part number?
Would you happen to have the part number for that cam and crank position sensor kit? Or let me know where I can find one. I have been all over the net and can't find it. Last night the car wouldn't start, maybe it's because it was so friggin cold but I'm going to try anything I can this weekend to fix my poor little car.
Old 02-26-2003, 02:05 PM   #12
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default dealer
Have you tried the dealer?!
Or you can order online from a number of places:
www.subaruparts.com
www.1stsubaruparts.com
www.newsubaru.com
etc.
Old 04-19-2003, 02:23 PM   #13
95IMPREZAWD
Member#: 35516
1995 Impreza
Unhappy How do I install this sensor kit?
I had the exact same problem you were talking about on this board, so I finally ordered the cam and crankshaft sensor kit from SubaruParts.com. However, I could definitely use some guidance in how to install these sensors. If anyone can help, it would be very appreciated (and sorely needed)!
95IMPREZAWD is offline   Reply With Quote
Old 04-21-2003, 11:43 AM   #14
crimedog
Member#: 20881
2000 2.5RS
I got my problem fixed but all I ordered was a cam shaft position sensor. It is actually quite easy to fix, being a mechanical newbie I had no problems. To replace the Cam shaft sensor open the hood and look down directly in front of you on the right (your right, not the engines) of the engine, just behind the fans & radiator. You will see a small part held in with a bolt and with wiring connected to it (the bolt and part are facing the engine). All you have to do is remove the negative terminal on the battery, remove the wiring on the bad sensor, unbolt and take out. Then to replace the sensor just reverse the order of removing it. If you need anymore help a Chiltons manual helped me out a lot, I just wish they made a Haynes manual for Imprezas.
Crimedog
Old 04-21-2003, 01:07 PM   #15
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Brian
I second this opinion or at least clean the valve and the chamber it goes in with throttle body cleaner. also, clean the throttle body where the butterfy meets the body. there is probably a nice raised ring of carbo built up. Be sure to use throttle body/plate cleaner. Carb & Choke cleaner doesn't cut it.
cavymeister is offline   Reply With Quote
Car is having a hard time starting... aveera Electrical & Lighting 4 12-17-2008 09:56 PM
Engine problems force Honda recall, 165,000 U.S. cars may stall or fail to start NYCshopper Non-Subaru News & Rumors 4 03-20-2007 12:02 PM
What makes my car hard to start sometimes? nos Service & Maintenance 7 03-15-2005 12:57 PM
Black tailpipe and hard to start 95 impreza 95IMPREZAWD Service & Maintenance 22 10-18-2003 07:00 PM
Car is loaded and ready to go........... Snowman South East Region Forum 4 08-29-2002 10:07 PM
