#1 |
Member#: 8525
Vehicle:2006 Stang GT Black |
I know that the STi comes standard without a radio. But does anyone know if the car is pre-wired for sound. I think it would be a PIA if you had to get the car wired for sound.
Thanks for your help.
#2 |
Member#: 853
Vehicle:2011 STI Sedan Satin White Pearl |
yes,the car does come prewired.
#3 |
Member#: 7852
Vehicle:03 White Lan EVO 8 97 Techno-Violet BMW M3/2 |
It is??
Then how much weight do we saved exactly?? Considering that we only deleting the weight of headunit, speakers and amp (unless using preamp from headunit) from the car??? Is that a lot? |
#4 |
Member#: 32799
not particularly...
I think the no-radio-standard thing is much for for the hardcore image of the STi then it is for any real or tangeble performance increase. a head-unit is 1 lb, maybe... I'm sorry, if you're that anal, then make sure you don't wear your jacket and heavy boots in the car too. I'm also reasonably sure a great majority of STi's will go with the Dealer-Radio option (or I'll probably have a local shop throw and Aftermarket deck+ Focal's all the way around as soon as I get it) -Scott |
#5 | |
Member#: 8221
NESIC
Vehicle:02 WRX Wagon Blue/Gold |
#6 |
Member#: 18713
Vehicle:06 CRV 04 STi |
agreed. this is a cost move, not a weight move. shipping the car without a spare tire, like the BMW M cars, would give much more weight savings. (of course, we still haven't confirmed that it's got a spare
)but, it gets the msrp probably nearly 1k closer to the Evo, while also being a marketing gimmick. And, the dealers can make money installing it, very easily, since it's prewired. The head unit might be 4-5 lbs, and the speakers another 5ish. How much does your spare weigh? How much does the wing weigh? If ten pounds radically transforms the handling or performance of the car, then don't take any passengers or cargo along. and, if the story about meeting an artificial weight limit for fuel economy standard or whatever is true, and this wasn't a cost move, why not make the stereo a No cost port installed option? |
#7 |
Member#: 14117
Vehicle:2005 Nissan Murano Pewter |
The car is built for the track! Why in the blue hell would you want a stereo. The sound of the car's engine, exhaust, turbo....That should be plenty!
#8 | |
Member#: 18713
Let's be honest with ourselves here...the car has been significantly upgraded for performance driving, but it's not intended to be a track only car. The Z06 will own this car on the track, even as equipped with a stereo. |
#9 | |
Member#: 31892
Vehicle:2004 STi Silver |
#10 |
Member#: 32577
Vehicle:2000 Chevy Tahoe Dark Blue |
They are also only going to sell them to people that weigh under 150 lbs so as to not counter act all of the weight minimizing effort they have gone through. Get that mcfatty burger out of your face and start running...
#11 |
Member#: 4190
BAIC
Vehicle:2008 Impreza WRX STi Aspen White |
grap on my tired! 180 pount man!
#12 |
Member#: 2468
South East
Vehicle:08 Audi RS 4 05 AW STi |
The show-lady at the Chicago Auto Show stated the following (however illogical):
[paraphrasing] The STi will have the radio as the only available option. It does not come with a radio in the interest of keeping the car as light as possible. Me: Will it come prewired for sound? Yes, the car will be prewired for sound, including speakers. Me: She was actually not that bad, technically speaking. All of the other chicago area goons must have gotten to her before me. ![]() |
#13 | |
Member#: 7852
with memory, HUD display, electronic traction controls... What GM did is they use various lightweight items to save weight.. Titanium exhausts, lightweight wheels, aluminum sway bar links and thinner windshield for example... but then of course MSRP of the car gone up too.. ![]() Still... I dont see the reason of removing radio... not enough weight benefit to justify it (unless all wires/speakers are removed as well)... |
#14 |
Member#: 8679
Vehicle:2010 The most hated vehicle on the internets |
If weight was the real issue, I think the AC would be the first to go. Personally, I wish Subaru would offer an STi without the AC and spare tire/jack (throw some fix-a-flat in there). That option alone could save me a thousand dollars and a hundred pounds.
#15 | |
Member#: 31411
NWIC
Vehicle:2001 RSTi BRP |
MGB |
#16 | |
Member#: 18713
I can understand your skepticism of the weight argument, but the cost argument? It probably cuts their MSRP by 800-1000 by not putting in the 6-disc in-dash changer. This is significant, with the Evo at $29k. Again, if cost wasn't a factor, it would be a _no cost_ port installed option, just to technically pass whatever test they were trying to pass. Hardcore racing options happen, but they're usually no cost deletes, like A/C and stereo deletes on porsches and ferraris. |
#17 | |
Member#: 31411
NWIC
MGB |
#18 | |
Member#: 7852
I thought the aftermarket players are at around 250... and when manufacturers buying bulk the cost should be even lower... No radio but with all wires & speakers in place... Save weight?.. NO. Save cost?.. Not much More hardcore image?.. Sure, but why and at what cost?? Repels general public?.. Yes A way for dealers to make extra $$ on the car?.. Maybe |
#19 |
Member#: 18713
sure their cost is much less, but the full marked up cost of an indash CD changer with speakers has to be $800. This is what is in the WRX now, BoyRacer!
Look how much it costs to add the "premium" speakers that cost them probably $20. And, it would probably add at least $600 MSRP to upgrade from a single CD to a in dash 6-disc changer in a car that didn't come with a changer. And, I haven't seen any 6-disc in dash changers in the aftermarket yet (like crutchfield, etc.) but sure, an indash CD with decent power is probably $200ish. Add 4-6 speakers for another $200. There's $400 right there. It's the same story for everything on the car, you have to add the markup, if you want to look at the cost perspective. Little changes can have a big impact on MSRP. edit...I think this is a lame place to save weight, but am ok with the saving cost. I'd probably rather take that $$ and put my own system in anyway. Though, the indash changer is nice. ps...if you want to know the MSRP of the changer, wait until it's a dealer installed or port installed option, and you'll see the number. I would guess $800-1000. |
#20 | |
Member#: 7852
for manufacturers to add them... if the wires&speakers are prewired and comes with STi.... then the additional cost to add radio is just the headunit... which I'm sure is less than $150 each for Subaru... It just doesn't make sense to me that Subaru will save $150 or less on each car but risking the fact that it will not appeal to the more general public.. (but then again maybe that's what they want... who knows). |
#21 |
Member#: 18713
the wires and speakers are disposable, and the speakers might not even be preinstalled, if they were really after weight savings, with all of the "heavy" magnets and whatnot.
They probably will install the "optional" stereo at the port on nearly every car, and add the $ back. But, they still get to claim a low starting msrp to compete with the Evo. It's a technicality, like Nissan making the base Altima, which they made like 500 of, just to claim the low starting msrp. It can still be an "option" and nearly every car to come through port can get one installed. If the $150 or so of stereo cost was the only thing stopping them, it would be a no cost port addition, and they would just absorb the $150, and everyone would be happy. As it is, they will probably make it a port installed option, for $800-1000, and have the best of both worlds. So far, the facts are that the stereo is optional. I agree with you that it doesn't make sense to the consumer. And, the weight excuse doesn't fly with me, as long as the car comes with a spare. the water in the water spray unit probably weighs more than the head unit. |
#22 |
Member#: 1908
ok on the price idea it does make a big difference not to us but to SOJ and SOA because 5000 x 800 or what ever deal they get on mass purchase of stereo equipment is still a huge deal and more money they save the more profit they can make so it's probably a 20% weight savings and image
80% profit increase and a way to help out dealers by pulling more money in. think of it in the sense of being a big business and not as a consumer. think they really give a flying flup about us? no way they just want the cash, if they did care about us they would give us mad options on every part and a choice of putting the new STI engine/tranny/diffs in a "new" GC8 platform ![]() |
#23 | |
Member#: 7852
I agree with what robmarch said about claiming the low msrp..
to "sound" competitive with EVO... Quote:
Sure.. 5000x150 will yield a big number... but still not big enough to justify the risk that 150/car might repel the general public from buying the car... If 95% of car come with radio installed.. then it might just be a way for SOA to claim low msrp.. and still make extra $500 or so on the option alone... it's totall possible.. think Leather for BMW and Benz, try to find one w/o it... it's nearly impossible.. Though... I still hope it will be a "true" option from SOA... |
#24 |
Member#: 4418
South East
Vehicle:2008 S2000 Black |
Yea, why spend ~$250 more on the stock headunit, when you can get something so much better for the same price (through aftermarket that is).
-justin |
#25 | |
Member#: 18713
| Thread Tools | |
| Display Modes | |
| Where is the tach wire for a 07 Impreza 2.5i Wagon? | anthonywpg | Car Audio, Video & Security | 11 | 11-18-2007 01:40 PM |
| What is the best axleback for our STIs sound wise? | 1FSTREX | Newbies & FAQs | 5 | 11-25-2006 02:02 AM |
| Is the STi reccommended for a driver new to manual? | StillDeciding | Newbies & FAQs | 40 | 12-27-2003 01:21 AM |
| What is the red wire with the pink fuse for in the HU wiring harness? | Krelkor | Car Audio, Video & Security | 3 | 08-29-2002 11:05 PM |
