![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 6531
I was wondering if I sould pick up these SSR rims from my friend but not sure how they'll fit. They're 17x8 up front and 17x8.5 out back. Need guidence!
Thanks in advance, Ralph
#2 |
Member#: 2213
South East
Vehicle:1995 Impreza w/EJ257 Brilliant Red |
You are going to need the off set of the rims in order to get an answer. Also this is an AWD car so you don't want differant width rims front and back.
Joshua Subaru Salesman |
#3 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 05 Legacy GT 06 Armada |
Even with the offset numbers thats still going to be too wide of a wheel, right? I agree with people when they say "when using a 7" wide wheel you will need a +50 to +53 offset". But what I don't understand is when they say that when using a 7.5" wide wheel a +45 offsett is good. Are they only considering the inside of the wheel with rub issues? Because when you get a wider wheel then drop the offsett which effectively extends the wheel even further out won't run an even greater risk for fender rub?
Thanks Brad |
#4 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
A staggered wheel set for an all-wheel drive vehicle is a bad idea
#5 |
Member#: 2440
I had always heard this before, but why isn't this followed on the Porsche Carrera 4?
The back wheels are much wider than the fronts. Anyone know? Stacey |
#6 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
The big rear tires on the 911's balance its extreme rear-heavy weight distribution. On an Impreza, which understeers naturally anyway, the big rear tires would just exacerbate that trait even further.
#7 |
Member#: 6531
Ok thanks for the help but I got another question. How wide can I go with out defeating the purpose of the AWD and fender rub (inside and out)?
#8 |
Member#: 5999
Vehicle:'02 wrx spt wagon silver |
I have 17x7.5" SSRs with 225/45/17 PP S -03s on order from Tire Rack. I am still NOT 100% convinced they'll fit the wagon, but the contact patch width varies greatly from one manufacturer to another, and indeed, some 215s may have wider patches than some 225s (i.e. the 225 PP S 02s are 6.8", the S 03s 8.4" if I recall Luke's #s correctly). Mike
| Thread Tools | |
| Display Modes | |
| 02-3 seats in a 04, will they fit? are they lower? | soulbazz | Interior & Exterior Modification | 4 | 06-04-2008 02:15 PM |
| If 8" Rims fit a STi will they fit a RS? | fluxwl | Tire & Wheel | 3 | 08-12-2004 02:58 PM |
| 18" wheels, will they fit? | The Wraith | Brakes, Steering & Suspension | 12 | 06-14-2001 07:57 AM |
| Diamond Audio components. Will they fit in a WRX? | Code-7 | Car Audio, Video & Security | 0 | 04-13-2001 02:32 AM |
| BFG VR-4 tires, will they fit? | jlyttle | Brakes, Steering & Suspension | 10 | 02-03-2001 03:20 PM |
