Old 03-29-2001, 07:44 AM   #1
Jessie James
Member#: 2072
Post 22b suspension mods to use wider tires
Okay,
What suspension mods does the 22b use to be able to have 235 series tires and not hit the struts? I've heard things like Legacy hubs and custom something else.
Details would be appreciated (or point me to a web page that has the specifics.)
Thanks!
Jessie James is offline   Reply With Quote
Old 03-29-2001, 07:52 AM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
read all about it on 22b.com
ColinL is offline   Reply With Quote
Old 03-29-2001, 08:01 AM   #3
Jessie James
Member#: 2072
Post
All about nothing! There are no specifics there. Some people say they used SVX swing arms and half shafts, others say Legacy hubs. Who is right?
Basically I am trying to determine what needs to be done to get 235 tires on my car (outside of fender clearance issues) and not drastically affect the handling by changing offset.
Aren't we all?
Old 03-29-2001, 10:35 AM   #4
Marco
Member#: 118
Unhappy
The suspension geometry is basically the same. In order to run 235s, you're going to need wider fenders and different offset. The 22B uses a very different offset (+33, I think). Also, it uses 8.5" wheels. There is no way you can run 235s safely without changing the offset and the fenders! If you do, your tires won't move, as they'll be stuck to the strut body and will be rubbing heavily on the fender side.
I used to run 225s and I had to roll the fenders and grind the strut body (not very smart, I know but I know what I was doing) so that it would fit. Even so, I was still able to hear the tire lettering as it rubbed the strut bodies.
Cheers,
Marco
Marco is offline   Reply With Quote
Old 03-29-2001, 06:45 PM   #5
stever
Member#: 1512
99 2.5RS
Rally Blue and Black
Post
22B wheels are 8.5x17 ET48 and 9x17 ET45 will fit too. The front suspension is the same except that it has the aluminum lower arms. The rear has a wider track with longer lower arms and axles. That's as much as I can find out. As to whether the parts are unique to the 22B, I dunno. You can get MRT's adjustable lower arms and custom axles if you really want the wide track rear. Or, you could just get ET33 (or thereabouts) rear wheels which will give you the same track width. Of course you'll need wider fenders to cover the wheels ... I make carbon 22B-style flares for $2500 for the whole set.
-Steve
[email protected]
stever is offline   Reply With Quote
Trying to get wider tires. Replacing 205/55R16 with 225/55R16? bushwahkhan Tire & Wheel 28 01-13-2010 06:07 PM
What mods to do to fit wider tires... FEYNRYR Tire & Wheel 2 06-16-2008 12:12 AM
Question of using wider tires yoshi86 Tire & Wheel 5 08-02-2007 10:59 AM
brand new suspension mods never used + wheels for sale!! QWIKTRBOAWD Private 'For Sale' Classifieds 12 12-05-2005 09:58 PM
Thinking of switching to a wider tire Judsonkg Tire & Wheel 7 11-27-2005 01:16 AM
