Old 02-20-2003, 05:08 PM   #1
alex_umn
Member#: 11874
1992 SVX 6MT
Claret
Default R180 diff uses what type of axels?
I'm pretty close to getting an STi six-speed for my 92 SVX. Rather than spend a ton to get R180 3.90 ring and pinion gears and then put them in my present differential, I think that I will just buy an STi rear diff instead.
If it works, that is. Does anyone know if these axles are held in with circlips like the SVX uses, and more importantly if they have the same spline, etc count?
Thanks for any info...
alex_umn is offline   Reply With Quote
Old 02-20-2003, 11:48 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
The R180 uses a larger diameter shaft and larger inner/outter joints. The splines are different to that of the R160 diff and shafts. The R180 normally has a vicous LSD(not sure about certain Sti models) and both shafts splines are the same length left and right. The snap rings are inside the diff itself.
Ver.III is offline   Reply With Quote
Old 02-22-2003, 07:55 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i was under the impression that the svx came with r180 diffs already
What type of axels are on a 03 JDM forster turbo? AFBeefcake Transmission (AT/MT) & Driveline 0 06-03-2005 06:45 PM
20lbs of boost daily what type of axels? 2.5rsDOHC Pre-2002 Factory Turbo Powertrain 3 06-01-2005 09:51 AM
What type of differentials does the WRC impreza use? Gambit Motorsports 2 03-19-2001 06:40 PM
What type of alloy wheels does Subaru use? Ovaltine General Forum Archive 6 07-07-2000 09:16 PM
What type of gas do u use on your lovely RS? gerardchau General Forum Archive 8 06-04-2000 02:46 PM
