Old 02-20-2003, 09:07 PM   #1
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
Default Injen cai with txs stage 4 yes or no?
should i run the stock intake or my injen cai with the txs stage 4? would it really be worth it to run a stage 4 map tweaked for the injen intake or are the gains not really worth all the trouble? right now either i sell the intake or keep it, trying to decide.
datdudedennis is offline   Reply With Quote
Old 02-20-2003, 09:44 PM   #2
hiwrx
Member#: 28021
Second that. I'd also like to know if I can run my injen cai with a utec. Heard somewhere that it wouldn't be too bad. Not like the aem cai. I really don't want to go back to stock.
hiwrx is offline   Reply With Quote
Old 02-20-2003, 09:49 PM   #3
blitz01
Member#: 28566
WR BLUE
This seems to be the question of the month, but most of us asking this question have no choice but to run out intakes because our stock box doesnt fit because we have FMIC. I say if you dont have a FMIC then you should run your stock box because according to 85% of the people here its better or equal without the problem of the MAF uncertainties.
blitz01 is offline   Reply With Quote
Old 02-20-2003, 09:55 PM   #4
TurboRex
Member#: 8635
04 STI, 07 FXT
I used to have an injen and I swear it helped. However, all the tuners say no. I went back to the stock air box but lately decided to buy another one and test it once and for all. Give me a pm in a couple of weeks and I should be through with my testing by then.
I have the dd dyno software so I was going to do logs before and after and dyno runs before and after. Hopefully, whatever difference there is will show up. I honestly don't expect a difference but curiosity has the best of me.
Greg
TurboRex is offline   Reply With Quote
Old 02-20-2003, 10:06 PM   #5
Heeven
Member#: 20566
2002 wrx
aspen white
Default Cold air intakes
Are you gouys talking about the higher egt's from the cold air intakes or is there another problem with them? If it is a matter of higher egt's then I recomend the Perrin short ram or cold air intakes. I had the aem on my car and was seeing half throttle egt's of almost 1600. I put the perrin short ram and dropped my egt to 1400. the Aem and the injen cai's trick your maf so you run leaner (I think that is how it works?). I hope this is on topic.
Steve J
Heeven is offline   Reply With Quote
Old 02-20-2003, 11:19 PM   #6
datdudedennis
Member#: 3928
2002 WRX sedan
WRB use to be MBP
the problem i was addressing is if it was really worth it to do extra tweaking for an aftermarket intake when you can just use the stock airbox. the aem leans it out more than the injen i'm told. the injen is actually very good at not changing maf that much, but any intake but stock will change the maf reading i guess. i just wanted to know if it was worth it to keep the intake or not.
Old 02-21-2003, 12:31 AM   #7
alltractionWRX
Member#: 14819
WR Blue
Doesn't the Turboxs car that ran 11's have an intake, because I have their wrx catalog and they showed a pic of the motor and it had an short ram intake but they didn't say anything about it.
alltractionWRX is offline   Reply With Quote
Old 02-21-2003, 12:41 AM   #8
mlambert
Member#: 13831
properly designed intakes with proper tuning are fine. people harp on cai's because SOOOO many newbies bolt on a cai and a bov and a few weeks later start a thread like "HELP!! my car runs like crap! I have the following high performance mods: cai, bov, and under car neon kit".
the key is an intake that doesnt mess up the maf, proper tuning and not worrying about it until youre forced to because you cant use the stock airbox.
mlambert is offline   Reply With Quote
wrx with txs stage 4 yayitzian Bay Area Impreza Club Forum -- BAIC 3 08-29-2003 04:52 PM
Fuel Rail with TXS Stage 4 BassMan097 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-03-2003 09:12 AM
Injen CAI with Vishnu Stage Zero? yellow5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-22-2003 05:21 AM
Anyone with TXS Stage 4 and their new TMIC roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-22-2002 12:24 PM
CELs with Vishnu Stage Zero yes or no? xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 08-15-2002 09:40 PM
