Old 02-21-2003, 04:58 AM   #1
squeeks
Member#: 22899
01 GM6 i think
BRP
Default reverse cowl with stock RS scoop?
Hey Im sure a lot of you have seen pics of Rs's with reverse cowl scoops that look exactly lke the stock scoop turned backwards, like the Do-Luck RS?
Well, my question is, has anyone actually just turned around the stock scoop backwards?
Is it possible?
Does it fit the same backwards?
I think it looks awesome like this and I want to do it, but don't want to spend a couple hundy for it. Kinda a waste of money mod if its gonna cost that much.
Thanks!
squeeks is offline   Reply With Quote
Old 02-21-2003, 05:41 AM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
It is possible, but its not a direct fit. There'll be gaps in some spots, and not all the screws will go back in.
Keiho is offline   Reply With Quote
Old 02-21-2003, 03:40 PM   #3
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
It will bolt on backwards, but its not a perfect fit there are some gaps.
Anthony C
Bobalouy is offline   Reply With Quote
04-05 Do-Luck OEM-style, Kaminari Reverse Cowl, and Seibon RS-style WorldOne Exterior/Styling 27 09-05-2007 02:31 PM
Will it be fine to do KYB AGXs with stock RS springs? rites Brakes, Steering & Suspension 1 09-10-2005 06:56 PM
Larger TMIC with stock hood scoop, Worth it? jbfoco Factory 2.0L Turbo Powertrain 5 02-02-2003 10:25 PM
Anyone using the 5ZIGEN springs with stock RS struts? Need Info!! wrxman555 Brakes, Steering & Suspension 6 11-26-2000 02:18 PM
Will 4 Pot brakes fit with stock RS Wheels Greg 99 Brakes, Steering & Suspension 2 11-19-2000 06:33 PM
Message Board Statistics All times are GMT -4. The time now is 02:43 AM.
