Old 02-21-2003, 09:56 PM   #1
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Default A/F gauge installed now car runs like doo doo
Like I said.Hooked up the purple wire to front a/f sensor wire(B134A, thick white wire in center of loom) Power and ground off of cigar lighter,Car idled like the a/f sensor had gone bad.( erratic idle) and was semi hesitant when accelerating,Disconnected the gauge and re-programmed the ecm (its kind of nic to have one at your disposal) and the car runs fine now.
Soooooo what did I do wrong?
Ben,
Old 02-22-2003, 11:30 AM   #2
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Tap into the rear sensor, i'm pretty sure it's b-17.
www.northursalia.com/modifications/misc/wiring/wrxpin.html
scrappydoo is offline   Reply With Quote
Old 02-22-2003, 01:02 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
ben you of all people should know better, the front sensor reads in mA not volts, your guage is screwing with the readings, pull it out.
jeremy
Old 02-22-2003, 01:12 PM   #4
Hondaslayer
Member#: 4562
1995 Legacy LSi
The gauge is out right now (well disconnected at least) I'll try the rear sensor on monday.
Thank god for the select monitor!
Old 02-22-2003, 01:45 PM   #5
momoney627
Guest
Member#:
Tapped the wrong sensor. You need B17 which is the sensor reading go to scoobymods.com if you need the ecu pin diagram. Also there are somewhat detailed instructions on how to hook it up there..
MO$
Old 02-22-2003, 02:55 PM   #6
Hondaslayer
Member#: 4562
1995 Legacy LSi
Believe me I have all the pinouts
Anyway. I got the directoins from scoobymods now,funny thing I have seen the site just never went to it.:shrug: If it quits snowing I'll give it another shot.
Kind of wish I could use my garage but I just bought a new project to mod. Mid thirties Chris Craft!!! huh huh I've got wood boat that is.
Car runs like crap now, rich, smelly, no boost? plz help xtremsiege2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-30-2010 05:49 PM
APS inlet installed now car isn't running properly albie1kanobi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 01-21-2008 08:21 PM
disconnected battery, reflashed ecu, now car runs like **** [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-23-2007 11:54 AM
Car runs like junk after AVC-R install Sjerzey05sti Engine Management & Tuning 12 12-07-2006 07:38 AM
Injector install - now won't run (argg) TheWoRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-21-2004 11:47 PM
