Old 06-03-2001, 05:23 PM   #1
iBlueVirus
Member#: 4679
Post If you Autocross, What do you have?
If you Autocross, what do you have?
Tire brand, model, and size?
Suspension/Handling setup?
Thanks!
iBlueVirus is offline   Reply With Quote
Old 06-03-2001, 06:00 PM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Post
Stock RE92's, feathered and wasted! Going to be changing soon to Kuhmo 217's.
Stock struts/springs
Whiteline 18-22mm RSB (currently set at 20mm)
Whiteline endlinks.
Stock alignment settings -- whatever that is from the factory. Probably will get that checked out/changed when I get my new tires.
I'll probably go the poor-man's coil over setup with AGX's and Ground Controls/Eibach springs, but that'll be for when my stock suspension is worn out!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 06-03-2001, 09:39 PM   #3
AutoXr
Member#: 2047
'04 Audi S4
Red
Post
AutoXr is offline   Reply With Quote
Old 06-03-2001, 10:05 PM   #4
iBlueVirus
Member#: 4679
Post
Thanks autoxr! Just what I was looking for... Seems like most of the people uses Kumho and some BFG. Thanks!
Old 06-03-2001, 10:20 PM   #5
Tuning Factory Inc.
Vendor
Member#: 3600
Post
17 inch Volks with 225/45R17 AVS Sports.
Tuning Factory Inc. is offline   Reply With Quote
Old 06-03-2001, 10:27 PM   #6
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
I have a belly button...
Imprezer is offline   Reply With Quote
Old 06-04-2001, 05:56 AM   #7
KoKo
Guest
Member#:
Post
...But I can wipe my own ass!...
"Big Daddy"
Old 06-04-2001, 07:03 AM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Kumho 712's at 42psi front 45psi rear
20mm FHi rear sway bar
OMP front Strut bar, STi rear strut bar
VER 5 suspension (springs & dampers)
Brembo Rotors and Metal Master pads (front)
Rear brakes are stock
Cobb short shifter
OMP harness belts
Stromung 2 1/4 cat back SS dual tip exhaust
ISR intake with custom heat shield
Sparco pedal set
Its a pretty neutral setup, I prefer quick rotation hence the pressure differential in my tires. Its fun and I also drive it this way on the street...
STiShawn is offline   Reply With Quote
Old 06-04-2001, 07:10 AM   #9
JJTheSubeDriver
Member#: 391
2004 STi Blue/Gold
2000 RS BRP
Post
Stuff that matters for autox:
Kumho V700 R-compounds
Strut Tower Bars: Front and Rear
Stock Struts/Springs (Soon to be STi V6)
20MM FHI rear swaybar
Stuff that Doesn't really (catch my drift?)
Exhuast
Intake
JJ
JJTheSubeDriver is offline   Reply With Quote
Old 06-04-2001, 08:31 AM   #10
zzyzx
Member#: 815
2013 Boss 302 White
2000 2.5 RS Coupe Silver
Post
What JJ described is classed as 'STR'. What Shawn has is 'STS'. You can also go for 'GS' - the stock class. Figure out where you want to compete first, then ask more directed questions about legal setups.
I suggest STS. STR is fairly dead in most places. GS is also good, but limits to a great extent what you can mod on your car. Of course, there's also 'S-Mod' is you have boost.
Take yer pick.
- Steve
zzyzx is offline   Reply With Quote
Old 06-04-2001, 10:20 AM   #11
iBlueVirus
Member#: 4679
Post
Thanks guys! I think I am going with kumho. I guess setup is different for everybody depending how the person drives. I am going to have my own setup for suspension/handling, but I also got few good tips from you all, thanks!
How Old Are You & What Do You Drive? Poll for Imprezas Only boostinscooby Impreza Forum 2967 Yesterday 10:17 AM
Someone calls you argumentative, what do you do? 24 Off-Topic 70 04-12-2012 08:57 AM
Since I dont know you - Who are you and what do you do for work / school STEALTH-WRX Southern California Impreza Club Forum -- SCIC 120 10-19-2008 04:34 AM
what do you do if a cop pulls you over and you have illegal window tint? inpreza kid Canada Region Forum 21 04-12-2001 08:36 PM
Message Board Statistics All times are GMT -4. The time now is 01:40 AM.
