Old 02-23-2003, 02:24 PM   #1
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
Default suspension that lowers car more than 1.25" ?
I am looking for some setup that is really affordable to lower my caar more than just 1.25" I have eibachs and kyb agx's right now, but I want something that will drop it another 1.25"
So I am looking for some adjustable springs so I dont have to replace the struts, something that will give me a 2.5" drop from stock hieght would be great.
Thanks
-Eric
erice1984 is offline   Reply With Quote
Old 02-23-2003, 02:36 PM   #2
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Not coilovers but cheap and you'll get the car low
5zigen R-rated spring if you can find them, its says 1.6 front, 1.5 rear but on the 2.5 rs it looks really low
found an article on these springs
jdmimpreza is offline   Reply With Quote
Old 02-23-2003, 02:45 PM   #3
Siper2
Member#: 1134
2010 Legacy GT Ltd.
Hmmm... 2.5" sounds awfully low... Might be worried about ill-effected handling, at that point...
Maybe someone can correct me, but I'm not sure what an "adjustable spring" would be, whereas you say you want to use stock struts.
I'd say that if you're going for the showroom thing, just pick up any old set of drop springs out of some import showcar magazine.
Won't cost too much, I bet. But if you want to still hang on to some handling, jeez I don't know, to me that sounds like a big drop. Maybe not though?
-S2-
Siper2 is offline   Reply With Quote
Old 02-23-2003, 03:06 PM   #4
erice1984
Member#: 11778
w/AAZ Swap
sorry, I want the "look" so it may actually only drop it another 3/4" to get the "look" and they will be riding on kyb agx's.
Thanks
Old 02-23-2003, 03:11 PM   #5
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Thanks
If thats the case I would go with the 5zigen springs if you can find them. It made my 2.5rs look really low especially if you have 17" rims
Old pic
Old 02-23-2003, 03:22 PM   #6
Fred
Member#: 3560
06 STi, 02 STi
06 FXT, 94 rally car
If you're really going to do this, can you go ahead and send me your AGXes? I'd like to have an extra set (just in case), and if you leave them on the car when you lower it 2.5" they'll be destroyed shortly anyway. Plus, the warranty will be void once the car is lowered more than 1.5 inches. I can give you my stock struts - they're shot, too, but with the ride you'll have, you shouldn't be able to notice.
sorry about the sarcasm, but I just wanted to point out a few things you might not be thinking about...
Fred is offline   Reply With Quote
Old 02-23-2003, 03:33 PM   #7
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Does it really void the kyb agx if its lowered that much?
Old 02-23-2003, 04:05 PM   #8
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
rub-rub... rub-rub
I think I hear a frog...
dookiebob is offline   Reply With Quote
Old 02-23-2003, 04:15 PM   #9
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Originally posted by dookiebob
rub-rub... rub-rub
When I was running 215/45/17's it was ok as long as you remove the rear wheelwell rubber trim on the fender. I'm now running Azenis 225/45/17s had to roll the fender a little bit but its fine now.
sorry for posting so many pics, it just makes explaining things a bit easier if you see it as well.
Old 02-23-2003, 05:40 PM   #10
erice1984
Member#: 11778
w/AAZ Swap
I like your car jdmimpreza, looks good.
Old 02-23-2003, 05:44 PM   #11
Fred
Member#: 3560
06 STi, 02 STi
yes.
Old 02-23-2003, 05:49 PM   #12
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
Thanks, I'm sure yours is just as nice, I'd love to see a picture of of it(true GC8 lover). Is this about the height you were looking for?
Old 02-23-2003, 06:32 PM   #13
erice1984
Member#: 11778
w/AAZ Swap
Yes, I am lowered about 1.25" on all corners right now, and just want something to lower it alittle more, and get some stiff sway bars to get rid of this body roll i get on long high speed corners.
Here is my clearance with eibach prokit springs and kyb agx's
-Eric
Old 02-23-2003, 06:38 PM   #14
erice1984
Member#: 11778
w/AAZ Swap
btw, jdmimpreza what struts are you using in combination with the 5zigen springs?
Old 02-23-2003, 06:48 PM   #15
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
PM'd you Eric
garface is offline   Reply With Quote
Old 02-23-2003, 07:20 PM   #16
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
I was running apex dampers but I bent one. So for right now I'm on the stocks. Its fine, feels like a caddy on the freeway but it turns like a champ.
I'll be changing them shortly once I get my tax return.
I like your set up though, How are the AGX, My friend Sean used to run the Frankenstien set up with the AGX and ground controll Coilovers. He used to Launch that car into jumping over speed bumps and catching full air all 4 tires off the ground.
Old 02-24-2003, 12:33 AM   #17
erice1984
Member#: 11778
w/AAZ Swap
hahaha.. thats great, gettin air over speed bumps..
Mine ride great, not bouncy at all, stiff responsive.. Except, my car is light, and I still have a bit of body roll, and believe it or not, a Honda Odessey can almost out perform me on the on/off ramps on a highway. My friend drives the Honda Odyssey, got it to like 55-65 on this one ramp, and I started sliding (maybe the tires not gripping enough, or just not sticky enough period) I am on Pirelli P6000 Sport Veloce, those maybe why he keeps up with me, his tires screech real bad too, so I figure, lower my car a little bit, get sway bars, and some sticky tires on 17" rims.... he wont stand a chance. That and my friends honda civic out performs me in the corners. not speed wise, but manuverability.
You wouldn't believe how fast a honda odyssey is on 93 octane, and a crazy driver, it can beat any stock civic. it's crazy. They are probably one of the best performing minivans I have ever driven (my mom has one too).
-Eric
Old 02-24-2003, 02:43 AM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ground Control coilover springs with adjustable perches. I have them on AGX's, but I ride near stock height as to not destroy the struts... I can drop down to about 2" bellow stock height if I wanted to, and its stiff as bajesus.
Dont ask "where can I get them?" because I dont know, as I got the set up used. Instead try a search as there were several topics created about them already.
Old 02-24-2003, 10:22 AM   #19
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
-Eric
I hear you on the odyssey, When I drove one in felt like a car but wait its a minivan.
When I went to a car show this was the craziest thing I've every seen. A tricked out odyssey, own by Turbo Mom of ArtnMotion
Back on topic I hear you on the whole body roll, car feels to light situation. I was thinking about getting a roll cage to stiffen it up, but everyone tells me to try coilovers first before I go on the extreme end.
I have 2 friends, one with a WRX Wagon with JIC's and his is the re-valved one which come with a soft setting, And man the wagon is a heavy beast, but the JIC coilover suspension helps tap the inner potential of the car. If felt like the car was on tracks and the body felt so stable and solid.
My other friend has a JIC set up on his 2.5rs and his is the really stiff one. When I try to keep up with him it looks like he can turn so hard around low speed corners, The JIC's allow him to get the rear tires to really follow what the front are doing(I know it sounds wierd but you have to see it or you just have to try it). Coilovers really make the car feel very solid and responsive.
Suspension that will ride more comfortable than stock! GoneSingle Brakes, Steering & Suspension 10 06-02-2010 12:28 PM
Dog toys that will last more than 6minutes? SQ3.0dotJP Off-Topic 77 06-29-2009 02:03 PM
Organic Chemists: Help (Or people that just know more than me) BhamRoadrunner Off-Topic 35 12-07-2007 03:44 PM
Bands that Never lasted More than One CD.... Oh Canada Off-Topic 114 08-04-2005 03:08 AM
"You love that car more than me!" Quick WRX Off-Topic 32 11-11-2002 11:11 AM
