Old 02-24-2003, 12:14 PM   #1
Otaku64
Member#: 2971
Default is the abc for the utec necassary?
i have been seeing various people controlling their boost with their sbc-id while having the utec installed. i've got an avc-r installed and would like to know if i need to install the boost controller which comes with the utec or i can leave it out and adjust boost with my apex unit...
thanks,
-soon to be utec-equipped salvatore
Otaku64 is offline   Reply With Quote
Old 02-24-2003, 01:16 PM   #2
codean
Member#: 10186
Why do you want to keep the AVC-r when the utec can do the same kind of boost control? I would sell the AVC-r and use the utec to control boost.
codean is offline   Reply With Quote
Old 02-24-2003, 01:22 PM   #3
Otaku64
Member#: 2971
well, besides the fact that i don't want to always be on boost everyday and i would have to adjust the utec controller all the time where i could easily adjust boost with the apex unit right in front of me. i installed the avc already and don't want to remove it and have to sell it.
i am asking if it is necassary to install the utec abc and can i just have the avc-r manage boost since i know it pretty well.
thanks,
-salvatore
Old 02-24-2003, 01:58 PM   #4
codean
Member#: 10186
The ABC is not what controls boost with the Utec. It uses the factory boost controller. You can use your AVC-r with the utec but your going to have to work around the load sites.
Old 02-24-2003, 04:00 PM   #5
Otaku64
Member#: 2971
hmm...i was reading that the abc is dialed in with an allen key to adjust boost. what is the abc then?
Old 02-24-2003, 04:13 PM   #6
codean
Member#: 10186
The abc is used to help out the stock boost controller reach higher boost levels and fine tune peak boost.
Lets say that I that I am a retard and wanted to run 19 psi on the stock turbo. The factory boost controller would not be able to do this so you go a few turns out on the ABC and now you can reach that high.
Lets say that I am running 15 psi and don't want to bother using a computer to tune the utec to get 16 psi. Instead I can use the abc to reach a max 16 psi.
The abc has also been claimed to smooth out the boost curve too.
Old 02-24-2003, 09:42 PM   #7
kenchan
Member#: 15106
its also a good thing to use to change peak boost to match altitude and temperatures.
on the utec, you can go back to stock parameters on the
fly if you get a remote switch.
kenchan is offline   Reply With Quote
Old 02-24-2003, 10:25 PM   #8
Otaku64
Member#: 2971
k, but i could go over 15psi with the avc and since it's rpm adjustable, i could smooth the boost curve as well...
i really don't want to lose the avc since i have it already and trust it very much since i have been tuning for a while.
thanks for the help!
-salvatore
Old 02-25-2003, 02:35 AM   #9
kenchan
Member#: 15106
you can go into 18psi+ range by just adjusting the ABC if you wanted (not recommended on factory turbo though).
i kinda think having 2 programmable boost controllers is kinda overkill, but that's just me. i guess the benefit would be that you can control ABC parameters from inside the car....
What is the difference between the Greddy EVO 2 for the STI and the one for the WRX? Moshpit552 General Community 6 10-27-2005 01:08 PM
Where is the wire for the dimming control located for STi? BGPKR Car Audio, Video & Security 11 01-11-2005 12:18 AM
okay so the MR is out, the STi is in trouble, are they gonna make the S202 for the v8 03boxer4 General Community 47 11-04-2004 04:43 PM
is it time for a UTEC people?? wrx2nv[erc] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-12-2003 10:09 PM
The ABC on the Utec...a question? Jduke Engine Management & Tuning 1 03-25-2003 11:23 PM
