Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 04-14-2001, 12:59 AM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post high performance wheel bearings
Is there such a thing for our car?
if so:
were?
and how much?
thanx!
WRXwannbe is offline   Reply With Quote
Old 04-14-2001, 11:16 AM   #2
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
come on!!!!!!!!
Old 04-14-2001, 11:21 AM   #3
eastbaysubaru
Member#: 4110
04 FXT
Post
I would also like to know about this. I have had wheel bearings blow out and have had to have them repacked $$$$$. It would be an especially important topic if your car sees a lot of dirt. Any Ideas, I would expect some sort of answer from the rally people (SubieGal, etc.)
-Brian
eastbaysubaru is offline   Reply With Quote
Old 04-15-2001, 12:19 AM   #4
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
bump
Old 04-15-2001, 05:43 AM   #5
63Alpine
Member#: 865
2003 BMW M3
Phoenix Yellow
Post
I will ask Lance at Vermont Sports Car when I talk to him on Monday. This is of interest to me also as I will be putting on spacers and 8.5" rims soon.
Kurt
63Alpine is offline   Reply With Quote
Old 04-15-2001, 07:49 AM   #6
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
All,
The folks at Prototype Technology Group (PTG) that campaigns a BMW M3 take new bearings and pack them with synthetic grease instead of the standard stuff. The higher "stress" capabilities of the grease help them last longer. Simple as that!
Mike Gayle
gaylemd is offline   Reply With Quote
Old 04-15-2001, 06:30 PM   #7
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Post
Unfortunately it's not as simple as that. Subaru released a set of bad bearings to the public and then had to come up with a process for measuring the defective parts. Ask any of your Subaru technicians and they'll take you through the measuring process. I'm not saying the synthetic grease won't help, because it will, but just be aware that these bearings are defective and will fail on a regular basis.
Fitz
Fitz is offline   Reply With Quote
Old 04-15-2001, 06:40 PM   #8
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
My point exactly. It's not like bearings are rare, and it's not like companies that make wheel bearings are rare. But what is a good company to go with to make some custom reeel fast wheel bearings.
I have two bearings on the right side of my car in which I just destroyed. I've been forced to drive with them for some time. It's anyoning and I can't drive faster than 45(max speed is going down.)
Old 04-15-2001, 10:09 PM   #9
stever
Member#: 1512
99 2.5RS
Rally Blue and Black
Post
I might be wrong, but the Subaru bearings probably aren't made by Subaru. I say "might be wrong" because FHI might own a bearing company.
Anyway, Timken, NHBB, etc. are good bearing companies and might have a bearing with the same physical dimensions. If anyone has the dimensions of the bearings, I'd be glad to cross reference. There are stacks of bearing catalogs at work. If there's a part number (not Subaru's, the bearing manufacturer's), that would be even better.
-Steve
Stephen.Ramm@aerosim-research.com
stever is offline   Reply With Quote
Old 04-15-2001, 10:23 PM   #10
WillReckXhop
Member#: 4866
Post
what do wheel bearings do and were are they located? at the axle shaft? near the diff? thanks
peace
WillReckXhop is offline   Reply With Quote
Old 04-15-2001, 11:29 PM   #11
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
hey stever,
can you get F1 bearings
I won't know what the number is or if it is even recognizable, because it's been so long since I replaced the brocken ones (still on my car).
There are like 4-6 bearings on the subaru per axle (including the cvjoint axle bearings and diff-to-axle bearings) the ones I want are in between the hub and knuckle.
if that doesn't work, I'll have hell to pay (litterally).
Old 04-16-2001, 01:24 PM   #12
63Alpine
Member#: 865
2003 BMW M3
Phoenix Yellow
Post
I talked to Lance at VT Sports Car today and he said that they just use stock WRX hubs for their rally cars. They are rebuilt after every race and they use neo bearing grease. I don't know what that grease is.
Kurt
Old 04-16-2001, 06:55 PM   #13
gumby647
Member#: 2532
2001 2.5RS-T
BRP
Post
We recently put some ceramic wheel bearings in a drag race bike at work. They were $100 each so $500 for front and rear wheels. They are suposed to give 1-2 mph in the 1/4.
gumby647 is offline   Reply With Quote
Old 04-16-2001, 09:43 PM   #14
Godmal
Member#: 4934
2007 White STI LTD
Grey Mazda 5
Post
BMW bearings are made my ***, a bearing company called ***. Seriously though, a high performance wheel bearing? Come on, use the stock ones how can a "performance bearing" help anything? If you drive hard they wear out faster, that's just the cost of racing. As long as they aren't defective as was said before, you should be fine for a long time.
Godmal is offline   Reply With Quote
Old 04-17-2001, 03:19 AM   #15
MichiganRS
Member#: 3069
Post
Hey man you got **** behind your wheels?
You know its funny!
MichiganRS is offline   Reply With Quote
Old 04-17-2001, 08:35 PM   #16
stever
Member#: 1512
99 2.5RS
Post
There are differences in bearings. Typically, you'll find a few bearings in exactly the same size, but with different load capacities. It all depends on the alloys used, heat treatment, tolerances, etc. Rod ends are the same way. You can get cheap ones for less than $20 each, but the same size in a decent bearing will be over $50. The load capacity will be way higher and there won't be nearly as much slop.
Anybody know if Schumacher's Ferrari had Subaru wheel bearings
-Steve
Old 04-18-2001, 05:59 PM   #17
Joe Hogan
Member#: 699
2002 golf TDI
Post
NEO bearing grease is a brand of synthetic grease available from Baker Enterprises, Signal Hill CA
Joe Hogan is offline   Reply With Quote
Old 08-19-2004, 09:36 PM   #18
WagonGL
Member#: 58882
Originally Posted by gaylemd
All,
the use of sythetic grease is for its higher temperature capability compared with conventional automotive bearing greases. grease has no impact on reducing contact stresses within a bearing.
nhbb does not make automotive wheel bearings. timken does make automotive wheel bearings. check out http://www.timkeninfo.com for a bearing part number cross reference and an application database.
the rolling elements within bearings are called just that... rolling elements. the bearing, be it ceramic or wood, is the rings, rolling elements, and separator. caveat - not all bearings have separators nor two raceways. ceramic rolling rolling elements do provide bearings with less running torque, but the contact stresses are higher. higher stresses = less life. there are techniques to bring the stresses back down, but your torque will go up. let me know (pm) if you need bicycle wheel bearings with ceramic elements. you got shafted on the price... even for 2002 prices.
my oem bmw wheel bearings were made by skf. i recently had my front wheel bearings replaced with timken bearings.
if you take two bearing catalogs and compare two bearings of equal chassis size and design, they may have different load ratings. this is due to differences in ball size and complement from manufacturer to manufacturer. it is true different alloys and hardnesses will have different load ratings, but each bearing manufacturer uses the same steel spec. and similar ht procedures yielding the same hardness for bearings. tolerances do not impact load ratings.
WagonGL is offline   Reply With Quote
Please Explain High Performance vs Ultra High Performance Tires. andyfish Tire & Wheel 10 02-04-2005 12:52 AM
Enkei High Performance Wheel Groupbuy importhookup Vendor 'Group Buy' Classifieds 9 07-09-2004 03:55 PM
Enkei High Performance wheels!! NinosAutoAccesories Wheels/Tires 40 04-20-2004 10:56 AM
High pitched squeal and excessive heat from right rear - wheel bearing? TimStevens Brakes, Steering & Suspension 6 08-04-2003 01:15 PM
High performance Low Weight Wheels Jimmer Motorsports 7 12-07-2001 02:42 PM
