Old 02-24-2003, 08:47 PM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Spark Plug recommendations for running N20??
(NX Wet Kit 50 shot)
I remember reading it is highly recommended to change your spark plugs to ones with a colder setting/tolerance. I have no idea. If this is true though, can someone recommend which ones and any places (online would be great) to buy them. Thanks
AustinSTi is offline   Reply With Quote
Old 02-24-2003, 10:33 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
In general, guys that have add-on turbo kits, run really high boost, or extremely high compression ratios will switch to a plug that is one step colder. This is done to combat pre-ignition and detonation.
If you want to go to one step colder.....just go to the parts store and aks them. Tell them what car you have now....they can look the plug up, and give you the next step colder.
The only issue I see with this is your normal daily driving without nitrous will suffer. The plugs will not reach their self cleaning temp, and will not ignite the a/f mix as well.
A better solution would be to get some sort of chip or something that limits timing when you hit the nitrous. This is simply another method to control pre-ignition and detonation.
Legacy777 is offline   Reply With Quote
Old 02-24-2003, 11:15 PM   #3
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Yes with nitrous you have to use colder plugs, almost all people use NGK BKR7E's I think the part # is 6097 try www.summitracing.com please look up the part number before buying
AndyM is offline   Reply With Quote
Old 02-25-2003, 01:27 AM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
So are cooler spark plugs absolutely 100% a necessity, or would I be fine with the stock plugs?How drastically will "performance" suffer driving normally?? If I'm going to order these, should I go ahead and get new wires as well?? I recall people saying GC's don't really show a noticeable difference with new plugs and wires, but is it better off to go ahead and get them?
The ones at summit racing:
NGK-9825 Spark Plug Wires, Custom, 4Cyl. $21.99
yay or nay??
also I browsed through summit racing....did a search for NGK-6097 and all that came up was "spark plug..$1.99"...these the right ones???
Old 02-25-2003, 09:36 AM   #5
Legacy777
Member#: 4800
As Andy said....most people who do nitrous run colder plugs......they do this because of what I mentioned earlier....and it's cheaper then some sort of timing/ignition module.
Just try the plugs and see what they do for your car. If you get serious problems.....you may need to look into some other option.
Old 02-25-2003, 10:21 AM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Get the colder plugs and DEFINETLY GET RID OF PLATINUM!
I use the NGK 7;s as well.
Eric
PS: sorry for not getting back ot you, I accidently deleted your PM. if you still have questions, please pm me
Eric SS is offline   Reply With Quote
Old 02-25-2003, 11:52 AM   #7
AndyM
Member#: 3219
WR Blue Pearl
You just want the plugs, not the wires. I can find the exact part # you need. I'll post later today with the number. These will be the plug you need.
Old 02-26-2003, 11:47 AM   #8
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
so the ones you mentioned above are not the correct ones??.....when i did a manufacturer # search using NGK BKR7E, it came up with the same thing as doing a part number search for 6097...with the spark plug 1.99.
Old 02-26-2003, 03:35 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
NGK 7's should only be $1.99 from Summit... they're copper, not platinum so they'll be noticably cheaper.
Old 02-26-2003, 08:27 PM   #10
Elite421
Member#: 4332
01 Impreza 2.5RS
Blue Ridge Pearl (BRP)
you can also talk to the company your getting the kit from. they should have them or be able to get the plugs you need. Impreawd, Richie, got one degree colder plugs. and i think it has less to do with proformence loss as it does with damage to the engine. depending on how much of a shot your going to be running will be the deciding factor on how much colder you will want to go.
Alex
Elite421 is offline   Reply With Quote
Old 03-01-2003, 01:58 AM   #11
AndyM
Member#: 3219
WR Blue Pearl
yes those are the same ones. Sorry about not replying. Those NGK's are great plugs I suggest buying 8 instead of 4 so you have extras.
Old 03-01-2003, 02:00 AM   #12
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I bought 8 as well.
Old 03-01-2003, 02:34 AM   #13
AndyM
Member#: 3219
WR Blue Pearl
hey guys by the way,
Whats are your sparkplugs gapped at?
Old 03-01-2003, 11:31 AM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I run .038
Old 03-01-2003, 03:54 PM   #15
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
thanks for the help guys....just ordered 8
Spark plug recommendations? Mobius118 Newbies & FAQs 3 10-08-2008 06:47 AM
Spark plug recommendations STL WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-09-2008 01:54 PM
Spark Plug Recommendations...? StiNV76 Newbies & FAQs 5 05-18-2007 05:37 PM
spark plug recommendation attitude Service & Maintenance 8 01-12-2005 09:23 PM
What kind of spark plugs are people running Sparticus Normally Aspirated Powertrain 15 02-08-2002 10:46 PM
