Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 02-24-2003, 09:45 PM   #1
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Question Seam welding, how is it done?
I am thinking of picking up a 1996 Impreza L to be used as a track/auto-x car. Over time, and as funds allow, I would upgrade nearly the whole car, starting with safety items, and end with a drivetrain swap. The car has light nose damage, and blown airbags, so I have no problem with taking it down to the bare metal. The goal with the chassis work is to make it safer and stiffer. I was thinking that a nice weld in 4 point roll bar along with some seam welding would do just that. Anyway, from what I understand, seam welding is done by building up little beads about 2" in length, and then skipping 2", and so on. What parts of the car need the most attention? What else can you tell me about this process? Any tips you may have would be great.
Later,
Seth E.
Ru fan is offline   Reply With Quote
Old 02-24-2003, 10:14 PM   #2
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
If it's going to be a track car, the easiest thing to do is probably to get it dipped in acid to take everything off. I'm not exactly sure how you go about finding someone to seamweld the car, but they need it on a roticerie to do it right AFAIK. It's not uncommon to see increases in chassis bending and flexing resistance in the range of 50% by seamwelding from what I've read a few places. Obviously this varies with the starting chassis and technique.
Anyway, if you have the car stripped down and can find a place locally that knows how to do it, I'd go for it!
ellisnc is offline   Reply With Quote
Old 02-25-2003, 08:27 AM   #3
Thug
Choke Artist
Member#: 603
Default Re: Seam welding, how is it done?
Later,
Seth E.
You've pretty much got the idea. It's done in a "stitch" pattern. Id say the most important points would be the strut towers and surrounding areas.
Thug is offline   Reply With Quote
Old 02-25-2003, 10:40 AM   #4
igor
Member#: 8174
2002 WRX Sedan
Thumbs up
Yeah; the principle problem with seam welding, is that if you don't do it right, the metal-expansion can bend your car.
So, here are some tips:
- Do the roll-cage first, which will stiffen the whole thing up.
- Don't do it section-by-section, do it gradually all over the whole car: couple welds here, couple welds there, etc. This will spread out the strain
- The 2" weld, 2" gap pattern is good, as it allows a little bit of flexibility.
Good luck!
-jeff
igor is offline   Reply With Quote
Old 02-25-2003, 12:07 PM   #5
Ru fan
Member#: 1605
1997 1.8L Brighton
Thumbs up
I know a few locals who are decent at welding, so I want to ask them for some assistance. What kind of welding tools are needed? I know very little about the process. How about the areas under the car? Somebody said to pay close attention to the strut towers, but where are the seams on the towers? Are there any websites that show good pictures of this process?
As for the safety side of things, I was thinking of doing a 4 point roll bar with a horizontal bar behind the seats for the belts, and possibly a "X" going between the diagonal bars in the rear for some additional rigidity. Is there anyway that I could turn the bar into a SCCA legal cage at a later date, when I have the funds?
Thanks,
Seth E.
Old 02-25-2003, 12:34 PM   #6
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
From www.rallispec.com is a picture of their Celica Rally Car when it was under construction. You can see the seam welded areas of the car.
It's alot of work, but a cool project either way.
Paul G.
paultg is offline   Reply With Quote
Old 02-25-2003, 09:02 PM   #7
mch
Member#: 30039
2002 wrx wagon
dirt slvr
You might try the folks at Vt Sports Car. IIRC they ran a subaru rally car last year and had some info on their web site that included seam welding the car before building it up.
They are running an evo this year so don't be put off by the splash page.
http://www.vtrally.com/
mch
mch is offline   Reply With Quote
How is this done? ILSMKU2 Off-Topic 16 09-26-2007 01:13 AM
How is this done? Interactive Advertising Mattr762 Off-Topic 14 02-27-2007 08:10 PM
Thermo wrap for turbo - how is it done? ringmaster Factory 2.0L Turbo Powertrain 12 06-07-2005 02:36 PM
How is this done? Defi control unit V2 below ashtray. tnmn28 Interior & Exterior Modification 16 04-23-2003 10:49 PM
i still dont get it, im not sure..how is it a short shifter? DangeRS Newbies & FAQs 5 09-11-2001 10:52 PM
