Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 02-25-2003, 07:49 AM   #1
wRxbeater11
Member#: 12682
Default Re-flashing flashed ECU (ecutek)
Hey there, i plan on swapping ECU with a friend that's putting his wrx to stock though we do plan on swapping ECU's since he wants a stock ECU and his has already been flashed with a ecutek software. my question is since we have the same setup only didn't brands of parts how much would it cost to get it re-flashed to my car? for example i have a vf30 and my friend has a vf34... since they spool differently they would have to be adjusted ... let me know people thanks.
-=melo
wRxbeater11 is offline   Reply With Quote
Old 02-25-2003, 10:26 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
If he got the Ecutek reflash from Vishnu, a reflash should only cost $175 since it's already been flashed once.
Calvin
cnk is offline   Reply With Quote
Old 02-25-2003, 10:57 AM   #3
wRxbeater11
Member#: 12682
Yes it was flashed by Shiv when he came to nj a few weeks ago.. thanks
-=melo
Old 02-25-2003, 12:37 PM   #4
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
The VF30 and VF34 are exactly the same except for being ball bearing. You shouldnt need a reflash it you are setup the same.
STR8OUT is offline   Reply With Quote
Old 02-25-2003, 02:50 PM   #5
zacek
Member#: 19467
02 WRX
WR Blue
i second that!
zacek is offline   Reply With Quote
Old 02-25-2003, 07:58 PM   #6
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
Different brands of parts will give different parameters to tune. Although the VF30 and VF34 are almost identical, the fact that your other parts are different would make me personally go for the reflash.
I think $175 is a good deal for some peace of mind.
-Bob
dookiebob is offline   Reply With Quote
Old 02-25-2003, 10:09 PM   #7
wRxbeater11
Member#: 12682
I figured since both turbos spool at different times the ecu had to be changed.. another thing, who can reflash my ecu? rallispec? im in nj
-melo
Old 02-25-2003, 10:24 PM   #8
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
-melo
Yes, Rallispec can reflash your ECU... they did mine (as well as a full TXS stage 4+ level install) and I am SOOO happy with their work However, I don't know their policy on reflashing an ECU that was initially flashed by someone else. You should contact them for details on that.
About the turbo spool time, I don't know the answer for that for sure... I know the VF34 spools a few hundred RPM sooner, but I do not know if that in itself would require a reflash. On the other hand, your other mods (being from different companies than your friend's pieces) would prompt me to get a reflash.
-Bob
Old 02-27-2003, 01:33 AM   #9
wRxbeater11
Member#: 12682
contacted ralispec, wel sicne it was flashed by a different place they would have to start fresh. so in other words swaping ecus will be pointless when i can get it flashed on mine for $800...might just go with a utec seems to be easier..plus bm can tune it...
Old 02-27-2003, 06:09 PM   #10
SC WRX
Member#: 15258
2012 Non-Subaru
Why don't you just Fed Ex it to Vishnu?
SC WRX is online now   Reply With Quote
Old 02-28-2003, 10:10 AM   #11
wRxbeater11
Member#: 12682
vishnu cant tune a ecu thats has a greddy intake unless its on the dyno. since the intake itself changed the way the sensor reads. Went through the same issue while i still ran the unichip back in the day...
-melo
Old 02-28-2003, 05:21 PM   #12
dookiebob
Member#: 21767
2002 STi wannabe
Midnight Blue Swirl
-melo
I think the simple solution is to take the intake off
Your car will be easily reflashed by Vishnu if you do.
-Bob
Old 03-01-2003, 01:03 AM   #13
wRxbeater11
Member#: 12682
-Bob
would love to but nothing will fit for my greddy fmic =[
-melo
WTT: Ecutek flashed 03 ecu for Stock ecu + $250 D Money Engine/Power/Exhaust 23 01-16-2009 10:00 AM
ECUTEC flashe STi ECU west005 Private 'Wanted' Classifieds 0 07-13-2005 03:02 PM
Prodrive PPP3 We flash the ECU! MastroWRX Engine/Power/Exhaust 2 05-28-2004 09:03 AM
Can anyone in DFW flash my ECU for $$$? Justin962 Texas Impreza Club Forum -- TXIC 14 03-08-2004 11:43 AM
COBB re flash on ECU sonicsub03 Engine Management & Tuning 3 01-04-2004 08:56 PM
