Old 02-25-2003, 04:47 PM   #1
blitz01
Member#: 28566
WR BLUE
Default Are you guys using your heat shields after installing your VF-22, VF-30, VF-34 turbo?
I was just curious to find out if everyone is still using their heat shields after they put on their new turbos such as the vf-34 or whatever?
blitz01 is offline   Reply With Quote
Old 02-25-2003, 05:15 PM   #2
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Nope. Left mine off.
Need4Boost is offline   Reply With Quote
Old 02-25-2003, 05:22 PM   #3
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Yeah!
Unless you like your intercooler to get heatsoaked, put it back on. Or find alternative methods of insulation.
Kevin
Red Rocket is offline   Reply With Quote
Old 02-25-2003, 05:57 PM   #4
CatchME
Member#: 22732
I moddified mine and left it on. I like my intercooler working as efficient as possible. -Zach
CatchME is offline   Reply With Quote
Old 02-25-2003, 06:03 PM   #5
phast
Member#: 7957
Yes. I had to hack it out to fit over my bell mouth downpipe, but it's back on.
phast is offline   Reply With Quote
Old 02-25-2003, 08:28 PM   #6
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
I left mine off and its doin just fine. I got a FMIC though....
I've been thinking of wraping the top of the exhaust side of the turbo with some heat wrap that sticks on. Not sure what to do yet though.
STR8OUT is offline   Reply With Quote
Old 02-25-2003, 09:53 PM   #7
blitz01
Member#: 28566
WR BLUE
Thanks guys, i also have a FMIC but i guess ill just leave it on, there is no reason to take it off then i guess.
Old 02-25-2003, 11:04 PM   #8
Bolster
Member#: 22290
2002 WRB WRX Wagon
I also hacked mine up after my downpipe install. Seems to work fine. I think it's probably a good way to contain heat in the engine compartment.
Bolster is offline   Reply With Quote
what are you guys using for turbo heat shields? IllNastyImpreza Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 05-16-2007 05:37 PM
what are you guys using for turbo heat shields? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 2 05-15-2007 12:52 PM
What map are you guys using, vf39/34/30 with stock fuel stirules AccessPort 8 05-06-2007 10:54 PM
What turbos are you guys using? Azjon Bay Area Impreza Club Forum -- BAIC 10 11-24-2003 02:48 AM
How are you guys running coolant and oil lines to your turbos? BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 0 10-01-2002 09:55 PM
