Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 02-25-2003, 09:45 PM   #1
speedrkj
Member#: 14482
2002 WRX Sedan
Default Check engine Light Question P1443
Driving home tonight my check engine light came on so I pulled out my scanner and it read code P1443. I cleared the code and all seems ok but just thought I would ask to make sure....
Looked up in code database and it said:
* Evaporative emission control system vent control function problem
Can someone tell me what this is and if I should take it in for service??
Thanks
speedrkj is offline   Reply With Quote
Old 02-25-2003, 10:22 PM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Isn't that the loose gas cap one?
RidinLow is offline   Reply With Quote
Old 02-25-2003, 10:34 PM   #3
vadim
Member#: 31981
2003 WRX Sedan
where did you get the scanner? I want one too.
vadim is offline   Reply With Quote
Old 02-25-2003, 11:15 PM   #4
speedrkj
Member#: 14482
2002 WRX Sedan
I have a palm m105 running pocketlogger software
www.pocketlogger.com
Old 02-26-2003, 12:49 PM   #5
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
you will need a reflash from the dealer for that code
dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 02-26-2003, 05:34 PM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
dave
Why do you say that? It's the code for: "Evaporative emission control system vent control function problem". Go tighten your gas cap and drive around for a few days to a week. It could be a leak in the system or that PCV valve or whatever it's called on the engine, but I doubt it. I get it all the time because the Sunoco guy can't tighten the damn gas cap properly.
garface is offline   Reply With Quote
Old 02-26-2003, 07:08 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the vent control has nothing to do with the gas cap.
Gas cap codes are usually along the lines of "Evap emmissions, small leak deak detected, or gross leak detected''.
This is a malfunction of the evap emmisions purgre valve, or vent solonoid what ever subaru uses.
basically what has happned is the PCM said, yo vent solenoid open up and let all those evap emmissions you've been storing in the charcol canister..back into the engine (usually at highway cruise), but alas the the vent sol wasnt listening..or coudnt open..or didnt get the signal from the pcm....pcm says uh oh something is wrong with my friend the vent solenoid...RED ALERT, trips CEL....hoping someone can fix his friend the vent solenoid.
My guess since M.S.P.T is a subaru dealer, that there is a TSB or special service action, for updating the pcm calibration, if this code is present and no fault can be found with the vent solenoid.
right?
Jay
Old 02-26-2003, 07:30 PM   #8
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
So that's what those voices are when I'm driving.
Oh, and yes, M.S.P.T. = Metric.
Mike~~
N'CTRL is offline   Reply With Quote
Old 02-26-2003, 08:39 PM   #9
garface
Member#: 1581
MY00 RS/STi7
I got that code read 3 times, always comes on right after I get gas and goes off a few days after I tighten up the cap. I've had it happen close to ten times, but only had it checked three. This was after I got the service bulleting reflash performed as well.
check engine light question jlam86 Vancouver Impreza Club Forum -- VIC 7 11-28-2006 07:06 PM
check engine light question - 05 STi STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-16-2006 11:25 PM
2005 STi check engine light question STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 02-27-2006 08:40 PM
Check engine light question.... just one blunt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-26-2004 09:04 PM
[B]Check Engine Light question regarding uppipe/downpipe[/B] Moshpit552 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2004 03:36 AM
