Old 02-26-2003, 12:29 PM   #1
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Question Can driving in heavy snow wreck your oxygen sensor?
I will be the first to admit that this could be a coincidence ...
When our 95 Legacy had about 45,000 miles on it I drove it through some deep heavy snow (basically parked it in a snowbank ) and jammed snow into the whole front exhaust etc. About a week later the front oxygen sensor went out. Luckily it was covered by the CA-spec emissions warranty so the dealer fixed it free. Then last week at 165,000 miles my wife ran the car through heavy snow after the storm here. A few days later the oxygen sensor went out again.
Yes, I know 120,000 miles on an oxygen sensor is a lot, but still ... has anybody else had a similar experience?
Mike Wevrick is offline   Reply With Quote
Old 02-26-2003, 01:37 PM   #2
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
Hmmm, last time my o2 sensor went out the mechanic asked if I had driven through deep puddles that would have gotten it wet. Interesting. I wonder if it's related?
Opie is offline   Reply With Quote
Old 02-26-2003, 02:24 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
water doens't ruin them, chemicals will, but if you get hte tip actually filled wit water the O2 won't be able to doit's job since it can no longer sense the difference between outside air and EGO. Techincally it should be okay but chances are it did manage to take it out.
jeremy
Old 02-26-2003, 03:43 PM   #4
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Not sure I follow you ... the tip is inside the exhaust, where it should not be affected by snow or water. What part of it measures the outside air? (and why? outside air is always 21% oxygen)
Old 02-26-2003, 04:08 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
there are 4 holes near the end of the sensor that lets fresh air around the "inside" of the tip of the sensor. why is there only 21% oxygen, because 79% of the air is nitrogen which is why NOx emissions have become such a large concern in the past couple of years
Jeremy
Old 02-26-2003, 04:28 PM   #6
Mike Wevrick
Member#: 24654
1957 Taggart Comet
I meant "why does the sensor need to measure outside oxygen when it is always the same?"
Anyway, I'm surprised a part like this would be so sensitive. People drive their cars in water and snow all the time ...
Old 02-26-2003, 08:17 PM   #7
Brady
Member#: 14838
2005 LGT--Garnet Red
197 Iggpoints
yeah, but how often do they drive in heavy snow as you described? it's happened twice to you. i'm sure you've driven in plenty of snow in between. after 120,000 miles, it's probably just the straw that broke the camel's back.
Brady is offline   Reply With Quote
Old 02-26-2003, 09:04 PM   #8
Mike Wevrick
Member#: 24654
1957 Taggart Comet
yeah, probably ... these were among the few times that the car got dense snow actually packed around the exhaust, though ...
Old 02-27-2003, 12:31 AM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Could it be that the water leaks down into the wire harness and corrodes the insides or something? Seems to me that the oxygen sensor would be fairly robust.
Old 02-27-2003, 01:17 AM   #10
Jon [in CT]
Member#: 2992
02 WRX Sedan
As mentioned earlier, I think, an O2 sensor needs to "breathe" fresh air. Most O2 sensors do this through the gaps between the wires in their pigtail, the set of wires that come from the sensor. If you manage to seal, clog or plug those gaps up, the sensor will not work.
Jon [in CT] is offline   Reply With Quote
Old 02-27-2003, 09:52 AM   #11
Mike Wevrick
Member#: 24654
1957 Taggart Comet
It wasn't corrosion in the wires; they look fine.
I could understand the sensor not working temporarily while it was blocked, but mine failed days later after they were fully dried out.
I was more curious to see if anyone had had a similar experience to mine to see if there was a pattern. So far just Opie ...
Old 03-07-2003, 06:45 PM   #12
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
Default me too.... :(
I'm in the process of swapping my rear o2 sensor right now. I too was parked in a snow bank fairly recently. In my case it was code P0141, rear o2 sensor heater. I think it's possible that the melted snow shorted out the sensor heater.
minix42@ is offline   Reply With Quote
Prove that Subarus can drive on dirt, snow, and.....water. hkl03 Member's Car Gallery 25 08-10-2009 09:47 PM
Can i get a pic of rear oxygen sensor? SubbyPAT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-24-2007 02:32 AM
I committed a sin in the snow....wreck... itWoRX Off-Topic 25 01-06-2003 04:50 AM
Driving in the snow? Drifting? emprezadent General Forum Archive 15 02-23-2001 01:58 AM
Fog lights in heavy snow richeich Legacy Forum 5 12-09-2000 08:52 AM
