Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 02-26-2003, 11:49 AM   #1
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
Question What tool do you use to reach/change spark plugs?
After starting to change my plugs this morning and remembering that it was going to take longer than I thought, I got curious -- what tools do you use to change plugs on your Forester?
I use a 3/8" socket extension that's probably 6-9" long, with flex joint on the end that the ratchet is attached to. The difficulty I have is that the spark plug hole is too deep/narrow to try to do any kind of finger tightening of the plug as you'd normally do to check for proper threading.
I also have a flexible metal grabber tool that I use to pull the plugs out (if they don't come out with the socket end itself.
Thanks
Peter
BlueTDimly is offline   Reply With Quote
Old 02-26-2003, 12:12 PM   #2
BossGVR4
Member#: 1541
2001 Lexus GS430
Black Onyx
Default Craftsman
What you need to find is a suitable Craftsman 3/8 drive extension with a knurled section on the shaft (for hand threading the plugs) and a "wobble" head (this eliminates the flex attachment)
DaveC
BossGVR4 is offline   Reply With Quote
Old 02-26-2003, 01:31 PM   #3
momoney627
Guest
Member#:
I used a piece if gas line tubing to stick in the holesto get the plugs out before. I think last time though I used a magnet Forester plugs are easy. WRX plugs I have found are impossible..
MO$
What size socket do you use to tighten a spark plug? codemunky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-14-2010 01:04 PM
To those that do their own alignments, what tools do you use? Tips? Tricks? Sources? mav1c Motorsports 32 06-30-2009 01:38 PM
Guys, What Razor Do You Use To Shave??? xfactor834 Off-Topic 73 04-03-2007 02:26 PM
What browser do you use to view the interweb? crowbar Off-Topic 16 07-15-2004 03:01 PM
What site do you use to DL MP3's? Grap Off-Topic 8 03-19-2004 09:55 AM
