Old 03-14-2001, 09:27 AM   #1
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post Weird clunking from front left tire...
Ok, when driving down the road, I motice that once I turn the wheels to the right, at any speed... there's a kinda soft clunk sound, and I can feel it at my feet.
I installed the V5 suspension a while ago, and haven't had any other problems. Could this be related? I do go out and skid around in snow a lot...could something be stuck in there?
Oh, and left turns, this does not happen.
[This message has been edited by JGard18 (edited March 14, 2001).]
JGard is offline   Reply With Quote
Old 03-14-2001, 09:49 AM   #2
Andrew
Member#: 1170
2005 STi
Post
Did you torque the lugs to the proper setting?
Andrew is offline   Reply With Quote
Old 03-14-2001, 09:57 AM   #3
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
Is it more of a "ticking" sound or a "clunk"?
I get lots of noises from my front brakes. I think it is the floating caliper design that's responsible - it's like the front calipers sort of clunk into place when I get on the brakes when the wheels are turned at all. Only ever happens at low speed...
But I doubt that's what you are experiencing. Kinda hard to tell without driving it and listening.
[This message has been edited by DigDug (edited March 14, 2001).]
DigDug is offline   Reply With Quote
Old 03-14-2001, 10:04 AM   #4
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Check your strut top bolts, the 12-14mm buggers. My rear one was clunking, and they were abit loose. After your car has settled the springs, they do "pop" up a bit, and need to be re-tightened. Check these first.
STiShawn is offline   Reply With Quote
Old 03-14-2001, 10:13 AM   #5
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
yeah, I'll check those strut top bolts, thanks... that sounds like it could be it
as for the other bolts, i didn't use a torque wrench, but the old arm-dyno measured them about the same...
Old 03-14-2001, 10:59 AM   #6
Ethan
Member#: 246
Post
Check to see if the exhaust is hitting anything when it sways around back there. Sounds like the problem I had when I changed out my suspension.
EDIT: Hmm just read you said front, but check the rear anyways
[This message has been edited by Ethan (edited March 14, 2001).]
Ethan is offline   Reply With Quote
Clunk from front passenger on left turns... AWDboostADDICT Brakes, Steering & Suspension 12 07-30-2009 01:34 PM
Loud pop/clunk from front left of car soasti General Community 10 03-20-2006 01:25 PM
Clunk coming from front Left Wheel When in Reverse cloudbrk Outback Forum 0 09-27-2005 03:20 AM
Weird clunking from rear... NeoteriX Texas Impreza Club Forum -- TXIC 9 05-02-2005 10:43 AM
noise from front left tire feiron Tire & Wheel 4 08-10-2004 09:16 PM
