Old 02-28-2003, 02:43 PM   #1
krillz
Member#: 29874
2002 wrx
mblackp
Default 3 inch downpipe into 2.5 inch exhaust?
I wanna keep a 2.5 inch exhaust becuse i beleive scoobysports theory that it retains quicker spool up capabilities and would only hinder performance in well over 300 flywheel hp applications
but should/can i get a 3 inch downpipe into a 2.5 inch exhaust?
i was looking at fastwrx's buschur exhausts, in which you can build a complete turboback for under $900
or should i just stick with the turboxs becuase although its bigger i can get a similar price.
krillz is offline   Reply With Quote
Old 02-28-2003, 04:17 PM   #2
David Buschur
Member#: 24301
2006 WRX 345hp/345tq
Funny I would be the one to come across this since you are considering our exhaust:0)
Anyway, whatever you do DO NOT run a 3" downpipe into a 2.5" catback. We have done that and dyno tested the results, let's just say IT SUCKS. So if anything stick with the full 2.5" system.
BTW, our full stainless steel 2.5" system with the offroad pipe is only $625 and weighs in at less than 24 pounds for the entire system. If you want the highflow cat just add $150.
Take care,
David Buschur is offline   Reply With Quote
Old 02-28-2003, 04:53 PM   #3
romoranger
Member#: 14701
94 camaro
big cam/heads/slicks
you CAN do it if you want, but then again, i have a 3" downpipe connected to the stock cat back which is something like 2.25"
romoranger is offline   Reply With Quote
Old 02-28-2003, 05:34 PM   #4
krillz
Member#: 29874
2002 wrx
mblackp
David, thanks for the response! Whats the dyno difference between the 2.5 and the 3?
I mean, is the three inch substantially better?
Old 02-28-2003, 05:41 PM   #5
KenpoKev
Member#: 32564
I would also like to see the results of from dyno testing of a 3-2.5 vs. 3-3 even. I currently have a 3-2.5 set-up (not by my choice) and was told by several sources that the effects would be minute unless I did extensive modifications to the motor.
If you have evidence otherwise, I'm all in favor of changing out my cat-back to a 3" and you'll get the first crack at selling me a 3" unit!
Please be sure to provide details of the engine set-up (upgrades) along with the pull charts.
Thanks!
Kev
KenpoKev is offline   Reply With Quote
Old 02-28-2003, 10:55 PM   #6
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
BUMP this because I'm interested in those dyno results as well. Been kicking around the idea of modifying my Apexi WS exhaust. It starts at 2.5" and expands to 3" at the axleback. I may have a shop fab a custom midpipe to where it expands to 3" and have a full 3" system.
atf78 is offline   Reply With Quote
Old 02-28-2003, 11:28 PM   #7
scurry
Member#: 13543
Wow! I guess someone should contact Scoobysport about this, looks like they have no idea on what they are doing....
Shawn
scurry is offline   Reply With Quote
Old 03-01-2003, 12:41 AM   #8
koloumb
Member#: 28268
2002 WRX Sedan
The only disadvantage [ie: Suckage factor] I can think of are the mating surfaces/sizes between the 3" outlet of the DP and the 2.5" inlet of the cat back.
I noticed this problem mating up a Perrin DP with a Tanabe Hyper Super Medalion [2.75"] exhaust. It [Perrin DP] doesn't have the important outlet flang that the stock downpipe has that helps seal the gap between the dp and the catback exhaust. I had to use some McGiver skills to ensure a proper seal using the dp o-ring gasket [which I expect is probably failing more and more each time I lead foot the gas].
_0wen_
koloumb is offline   Reply With Quote
Old 03-01-2003, 01:28 AM   #9
krillz
Member#: 29874
2002 wrx
mblackp
Shawn
i thin k mr buschur is saying that with HIS product it wasnt benefitial. if you want a scooobysport than get a scoobysport, if you wanna try something new from someone you can speak directly with then try out buschur...
and as far as i know, buschur has been tuning turbo allwheel drive vehicles just as long as scoobysport
Old 03-01-2003, 04:16 AM   #10
jsmonet
Member#: 14190
2005 STi
white
seriously, everyone has their own way of doing things. sometimes a pipe isn't just a pipe i guess.
i too would like to know if buschur has done full 3" vs. 3"->2.5" vs. 2.5" dynos.
i'm currently running 3" -> 2.25" (pde -> stock), and about to go to 3"->3+" (pde->blitz nur spec touring)
jsmonet is offline   Reply With Quote
Old 03-01-2003, 12:26 PM   #11
jrexilius
Member#: 21713
2002 wrx sedan
black
Take care,
who is we? you got a url?
jrexilius is offline   Reply With Quote
Old 03-01-2003, 08:41 PM   #12
ChristophWRX
Member#: 19009
2005 M3/WRX by clark
silver/white
Post exhausted
just installed my turbo xs downpipe, 3 inch race pipe with 2.5 inch hks axleback. plan on going full three inch when i get a bigger turbo, i will dyno it soon, should be fine..
oh, PDE up pipe is a great peace..installed all this last night, i love the sound and performance...
chris
ChristophWRX is offline   Reply With Quote
Old 03-03-2003, 12:36 PM   #13
Rally Performance
Vendor
Member#: 16588
Default Hi David
Hi all - noticed this thread
David, let me say that I respect your products, and have followed your tuning ever since we were running a Galant VR-4...
I do have to differ with the statement that 3" into 2.5 sucks. In some cases it may.... but let me explain what we do that is known to be very effective.
Krillz - by what you wrote, I'm guessing that you are assuming our downpipe is 2.5"... it is actually larger, and what you are after may just be our pipe, or one like it.
The ScoobySport is actually a 5.5" wide bellmouth downpipe, tapering down to 3". The system then later tapers to 2.5" to go to the next pipe in line. The beauty of this is that it gives you flexibility... but has developed a pretty legendary reputation for area under the torque curve. It doesn't suck.
Dave, perhaps you dynoed a 3" only downpipe, like the HKS, that doesnt have the same flow properties as ours (or other good bellmouths like TXS).
In any case, I wanted to make the point that we vary the diameter, and that the ScoobySport is not just a 2.5.
Regards,
Ken Cole
Rally Performance /
ScoobySport North Amercia
Rally Performance is offline   Reply With Quote
Old 03-03-2003, 12:41 PM   #14
krillz
Member#: 29874
2002 wrx
mblackp
thanks for the very informative reply! i was directing that at scurry who was comparing burschurs downpipe to yours
Old 03-03-2003, 01:45 PM   #15
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
I'm pretty sure that Buschur was talking about a connecting a 3" system to a 2.5" system without having any kind of tapering going on. Theres going to be a big difference in a system that tapers to 2.5" and one that goes directly from 3" to 2.5". Thats obviously going to be bad for airflow.
driggity is offline   Reply With Quote
Old 03-04-2003, 09:50 AM   #16
Mark B.
Member#: 9848
Platinum Silver
krillz
You can also try this as a way to stay with a 2.5 pipe, I have been very happy with this set-up.
http://www.geocities.com/skoshiracing/Efficient.html
Cheers
Mark B. is offline   Reply With Quote
Tial Exhaust Housing and 2.5 inch Vs 3 inch outlet Jamaal Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 10-27-2009 03:26 AM
fs: WBR 3 inch to 2.5 inch exhaust adapter $40 silverGDB SCIC Private Classifieds 10 04-09-2009 10:44 PM
2.25 Inch exhaust vs 2.5 inch exhaust kghost Normally Aspirated Powertrain 3 02-27-2007 04:51 PM
3 inch downpipe with 2.5 inch catback? Larsony Newbies & FAQs 13 09-22-2005 08:07 PM
Power differences between 3 inch and 2.5 inch exhaust? pha qed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-13-2004 05:14 PM
