Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 02-28-2003, 04:11 PM   #1
Extraze
Member#: 16980
Default Red Line Light !?
I was just wondering how that redline light worked.
is it a PER GEAR light, i mean can you set it for every gear ?
does it BEEP ???
can you set it at any RPM you want... that would be interesing for daily commute, you could set it at 3K to save gas.
thanks
Extraze is offline
Old 02-28-2003, 04:33 PM   #2
kenzo
Member#: 6422
2015 A4 Quattro MT6
Monsoon-like
Yes, gas savings is the main reason I'm buying an STi.
kenzo is offline
Old 02-28-2003, 04:34 PM   #3
kenzo
Member#: 6422
2015 A4 Quattro MT6
Monsoon-like
... but your questions are good ones.
kenzo is offline
Old 02-28-2003, 05:32 PM   #4
jaypride
Member#: 33424
2004 STI
Blue/Gold
It is user selectable.
It is supposed to beep, but I don't know if you can turn the buzzer off or not.
jaypride is offline
Old 03-01-2003, 03:58 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think you can turn it on or off... I dont know exactly though, but I do know that there is a knob like the one for the odometer for the light.
Kostamojen is offline
Old 03-01-2003, 10:56 AM   #6
ScoobyTodd
Member#: 19186
2005 STi
You actually set it once..so let's say 6500..and that is standard for all gears.. Its more crude than say a programmable shift light.
ScoobyTodd is offline
Old 03-02-2003, 11:57 PM   #7
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
If it is like the ones in the previous Sti clusters then you set it to the desired RPM and that is where it goes off in every gear. The beep can be turned off if you wish.. personally I love it.
Basically the way it is set is you turn the dial to the desired RPM, the lcd will display that RPM for a few seconds waiting to see if you change it more, then it beeps and displays on or off which corresponds to the audible beep setting and can be set from the same dial.. after that it beeps again to let you know you're all set.
You also can't play with it while the car is in motion, which is too bad cause then there'd be more salvage Sti parts on the market. j/k
lenyx is offline
Old 03-05-2003, 10:47 PM   #8
fastwrx
Member#: 7398
2004 2004 WRX-STi
Anyone know how loud the beep or buzzer will be? I drive my WRX in PCA track events, and I've bounced off the rev limiter a few times. With the windows down, at speed, you can no longer hear the engine, so careful monitoring of the tach is necessary. However, heading into multiple consecutive turns at high speed, requires focused attention on the road. And, especially with the WRX tach off to the side, it isn't easy to check it while doing laps.
I would love a nice loud buzzer or beep! So, anyone know how loud it is? Thanks!
Mike
fastwrx is offline
Old 03-05-2003, 11:14 PM   #9
lenyx
Member#: 8221
Mike
If you can't even hear the engine.. you'll probably not hear the beep. However the light itself is surprisingly bright.. and hard to miss.
If I had to classify how loud the beep is.. I'd say the level of normal conversation.. or slightly above.
lenyx is offline
Old 03-06-2003, 12:46 AM   #10
fastwrx
Member#: 7398
2004 2004 WRX-STi
Yeah... at 80 - 110 MPH with both front windows open (PCA requirement), the wind noise is pretty loud. So, the beep would have to be pretty darned loud to hear. Plus I'm wearing a helmet, of course.
Hell... even a nice bright light would be a help... especially with a center mounted tach.
Thanks for the info!
Mike
fastwrx is offline
Old 03-22-2003, 04:06 PM   #11
lenyx
Member#: 8221
Just an update to this.. I just put my sti cluster back in after converting it to mph.
With my windows down, at 6200rpm I could barely hear the beep with my full turbo back scoobysport exhaust and vishnu up-pipe.. add a helmet to that and I don't think you'd hear it at all.
Dunno what kind of exhaust you're running though.. stock should be a little better.
lenyx is offline
Old 03-22-2003, 04:59 PM   #12
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
I don't know what color the shift light is; but if you replace it with a high efficiency high intensity blue LED it'll damn near drill a hole in your retinas when it lights up
Corn-Picker is offline
Old 03-23-2003, 02:30 AM   #13
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 03-23-2003, 11:40 AM   #14
Extraze
Member#: 16980
im sure, in time, someone will find someway to wire it up to the speakers inside the car, if your STi is equiped with a sound system that is
Extraze is offline
Old 03-23-2003, 01:42 PM   #15
Corn-Picker
Member#: 8679
2010 The most hated
I just ordered a current limiting (up to 3 amps) adjustable voltage (0-30 volts) two channel power supply today. I plan to do some gauge work (with my Omoris) and other car electrical work.
Ultimately, I'd like to have a unit that plugs into the back of the radio (or somewhere else in the wiring harness) and allows one to hook up gauges without having dimming problems. I'd also like to find out how to get the "switched ground" of some gauges like the Omori to work. A switched ground would mean that when the oil pressure, oil temperature, or EGT reaches a preset limit a red LED comes on and a 100 dB Piezo buzzer goes off.
If I ever get something like this made I'll post all of the instructions and part sources here.
Who's got color matched Red Tail Light film on 04-05 lights? WhiteFox Interior & Exterior Modification 18 01-16-2008 06:56 PM
2qts. Red Line 75w90(NOT NS) + 1qt. Red Line Heavyduty Shockproof in 5MT WRX = ??? mcdrama Service & Maintenance 23 03-05-2007 08:30 PM
DIY red/red tail lights MixeD_MenacE Interior & Exterior Modification 16 01-03-2002 10:16 PM
idiots, 125 mph battle-red lineing in 4th gear! apexwrx Bay Area Impreza Club Forum -- BAIC 14 06-01-2001 05:55 PM
red/red tail lights? MixeD_MenacE Interior & Exterior Modification 5 11-11-2000 11:05 AM
