Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 02-28-2003, 10:31 PM   #1
subi-blue
Member#: 30443
2002 Impreza WRX
Question TXS Stage 2 Engine Knock Question
I have TXS Stage 2 unichip, Perrin Downpipe with a cat, Air resonator removed and a K&N air filter. I have the ABC turned all the way down. I added a Knock Link with the Bosch knock sensor. The sensor is located in the pre-tapped hole under the intercooler about 4 inches from the stock sensor. When shifting between 2nd and 3rd and from 3rd to 4th gear at WOT, I get a spike on the knock link, sometimes all the way to red. Otherwise, I am not getting any knock (the first green light flickers, but thats it). Is this normal or is there a problem. When I adjust the ABC to get the boost to 16.5 pounds (about 1.5 turns of the ABC), it happens more frequently. This spike does not happen consistently. I would say less than a quarter of the time.
subi-blue is offline   Reply With Quote
Old 03-01-2003, 01:00 AM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I don't understand the part about shifting at WOT?
I don't know how a knocklink works but you may be shifting at high rpm's and the engine noise is making the knocklink go off.
Just a thought.
MAD REX is offline   Reply With Quote
Old 03-01-2003, 04:16 PM   #3
subi-blue
Member#: 30443
2002 Impreza WRX
This knock happens just as I shift (about 6000RPMs) and then go hard back on the gas.
Old 03-01-2003, 06:17 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
If you're engine's gonna knock, your scenario will likely induce it. If it's knock it will go away if you turn down the boost and/or increase your fuel's octane.
Jon [in CT] is offline   Reply With Quote
Old 03-02-2003, 10:03 PM   #5
subi-blue
Member#: 30443
2002 Impreza WRX
TXS says that the correct boost for stage 2 is 16.5 lbs @ 4000RPM in 4th gear. With the ABC all the way closed, I get about 14.5 lbs @4000PRM in 4th. I always use 93 octane fuel.
Old 03-02-2003, 11:20 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
The question remains, does the knock disappear when you reduce the boost and/or increase the octane?
TXS stage 2 boost/ABC questions big_adventure Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-08-2003 04:26 PM
txs stage 2 utec question! Electronsmurf Engine Management & Tuning 4 03-01-2003 01:13 PM
Question about txs stage 2 unichip Carlito2002WGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-25-2003 09:00 PM
TXS stage 2 questions andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-01-2002 11:39 AM
Just installed TXS stage 2 - questions/concerns/comments ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-19-2002 04:13 PM
