Old 03-01-2003, 10:29 AM   #1
Rubasu
Member#: 1418
MY00 2.5RS
Default need help quick...Where to get......
a 2.25" exhaust donut gasket. I started and would have completed last night installing my borlas and random tech. cat if it was not for the slight oversight on my part of the stock donut gasket not fitting. So where can I get one today to get it done and on the road. thanks in advance
Rubasu
Rubasu is offline   Reply With Quote
Old 03-01-2003, 12:44 PM   #2
Rubasu
Member#: 1418
MY00 2.5RS
is it something that I can just pick up at like a pepboys or a muffler shop........
anyone please
Rubasu
Old 03-01-2003, 12:48 PM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Yes.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 03-02-2003, 02:29 PM   #4
Roo
Member#: 14931
Default Thanks for posting this....
I'm in the same predicament.
I have Borla (WHO SUCK) headers, I have a Random Tech to install, and the wonderfully sweet sound of the Stromung singing harmony from the cat back.
Roo is offline   Reply With Quote
Old 03-03-2003, 12:11 AM   #5
Rubasu
Member#: 1418
MY00 2.5RS
roo you will need a donut gasket that is a hair larger then 2.25". I think the one that I finally ended up with was like 2 3/8". Good luck. The fit and finish of both pieces is excellent. everything lined right up and everything went back together real easily. Get help if you can when reinstalling the damn bolts with springs on them. It is a real bear to compress the spring enough to get the nut started on the other side. good luck
Rubasu
Old 03-03-2003, 09:15 AM   #6
Roo
Member#: 14931
Default Fit??
My mechanic removed those, and replaced them with straight bolts. Since the R.T. Cat has a flange, and it mates up pretty close to the Stromung, he just figured it would be easier to install/remove.
-Roo
Where to get mandrel bend exhaust piping in NYC? RPMK104 Tri-State Area Forum 8 06-04-2009 09:02 AM
Where to get aftermarket dp/exhaust gasket? aspenwhitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-13-2004 07:05 PM
Where to get Greddy/Gracer Exhaust? M3sum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-16-2002 12:02 AM
Where to get an STi exhaust? OsakaGangsta Normally Aspirated Powertrain 12 06-26-2001 12:12 AM
where to get the STI exhaust?? SIRS Normally Aspirated Powertrain 9 10-17-2000 06:02 PM
