#1 |
Member#: 10268
SCIC
Vehicle:gc8 I ride ride 24s with the top down low. |
i just got my oil pan off and its dripping oil outta that middle thing (looks like a strainer) anyways im supposed to clean the edges where the pan was correct...so i dont have leaks? how do i do that best choice of doing it too please
#2 |
Member#: 2213
South East
Vehicle:1995 Impreza w/EJ257 Brilliant Red |
I used a part that plugs into the drill. You can put differant pads on it a it's about 1 inch in diameter. It does it quick and easy. That being said you can use a razor blade to scrape alot of it off and then some steel wool to clean it up.
Joshua |
#3 |
Member#: 20726
Yep, I just used a razor blade then applied my own healthy helping of sealant when I reinstalled. No leaks thus far...though I did it this morning
#4 |
Member#: 133
Vehicle:2003 Echo-daily car silver |
Yep use the razor blade if thats all you have but make sure you don't dig into the metal and leave any marks in it. Normally you would use a gasket scraper and then a simple wire brush to get any remaining sealant off.
#5 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
I used a rubberized brush connected to my die grinder for mine. Worked great and took just a few minutes.
#6 |
Member#: 1503
South East
Vehicle:2000 Impreza W"RS"X Blue Ridge Pearl |
That middle thing is your Oil Pickup...Keep that mesh clean...
Zee |
#7 |
Moderator Member#: 922
Vehicle:04 FXT Red |
I've had mine off & on a billion times. I usually use a regular screwdriver or whatever is a flat edge and is close to get what is remaining off. The tricky part is getting it off the pan, which I have a small wire wheel that I put in my drill and clean the pan with. They're like $5 at local hardware stores if you already have a drill and make the job REAL easy.
Oh, and I've never used any of the standard sealants, only Hondabond directly from Honda. Stuff works absolutely unbelievably and I've never had a seal issue when using it. |
| Thread Tools | |
| Display Modes | |
| URGENT: Oil pan Removal | fukamoto | Normally Aspirated with bolt-on Forced Induction Powertrain | 9 | 11-01-2004 03:31 AM |
| Oil Pan Removal? | fukamoto | Vancouver Impreza Club Forum -- VIC | 1 | 10-30-2004 12:20 PM |
| oil pan removal | twisty | 'Old School' Subaru Forum | 4 | 08-09-2004 05:45 PM |
| Oil Pan Removal | samtheblur | Outback Forum | 3 | 01-15-2004 06:48 AM |
| Oil Pan Removal | tulit | Normally Aspirated with bolt-on Forced Induction Powertrain | 23 | 05-28-2003 03:20 AM |
