Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 03-02-2003, 04:31 AM   #1
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
Default mbc? which one
hi
i am planning on getting a up pipe, and would like to run a mbc to get a little more speed
which mbc should i get....i dont have a lot of money, but reliability is a issue.
after up pipe, i was thinking downpipe, then catback
after these mods...what else would i consider to gain some more power.
thanks
alex
secretaznboy is offline   Reply With Quote
Old 03-02-2003, 04:33 AM   #2
pbchief2
Member#: 6443
2003 Audi A4
forest green:(
Do you have any gauges yet if so which ones also what city are you in
pbchief2 is offline   Reply With Quote
Old 03-02-2003, 01:58 PM   #3
Egan
Member#: 12670
01 M Coupe,
05 Legacy GT, 05 Titan
I've got the Dawes MBC which came with my Stage Zero kit. My Xede now controls boost through the FBC, so I don't need my MBC. I was going to put it on ebay, but if you're interested, let me know.
Mike
Egan is offline   Reply With Quote
Old 03-02-2003, 04:23 PM   #4
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
im over here in burlingame.(mid-pennisula)
do i need to worry about the boost spiking?
2nd...mabye ill go with a EBC...which one do you recommend.
i do not have any gauges...should that be my next mod?
i am goign to buy an up pipe soon? do i still need gauges with only a up pipe?
thanks
alex
Old 03-02-2003, 05:51 PM   #5
KnightRider
Member#: 28439
Koss Khor
u dont need a boost gauge if you are gonna get only the up-pipe. from what ive read id recommend a flex joint uppipe, if u do get one. u need a gauge if ur getting a mbc. if you wanna get the electronic those run about 500 bucks, on the other hand u can find a boost gauge for 100 and mbc for 45. i have the joe p mbc. works great with no spikes.
KnightRider is offline   Reply With Quote
Old 03-02-2003, 07:36 PM   #6
secretaznboy
Member#: 16666
2002 WRX!
MidNiGhT bLaCk
with a ebc...one can set the amount of boost per gear correct?
with a mbc...how does it work?
i have the factory boost gauge...and i dont really boost all that often.
now...you made a comment about the flex joint up pipe...why is this better than a one piece?
thanks
alex
Old 03-03-2003, 12:31 AM   #7
KnightRider
Member#: 28439
Koss Khor
with the mbc, u set the boost in 3rd gear and its gonna stay round the same for all gears, mine had bout 14.7 in first and second and 3-5 bout a little over 15. as for ebc i would guess u can set it in different gears, also i think they have like 2 modes one where u can just boost say 14psi for regular driving and one mode where u can put say 16 for racing, just by the touch of a button.
the stock up-pipe is a flex joint. they say non flex are more likely to leak because if the engine moves around, the pipe will too. this is based on my readings, i am on a waiting list for a jdm up-pipe from i-speedusa, its jdm, no cat with flex joint for 150, they are used. www.i-speedusa.com check it out.
on the jdm sti hid projectors which one is which??? Mr. SUAVE Electrical & Lighting 1 12-21-2005 09:04 AM
Of that 3 plug bulb connector, which one is high, and which one is for low beam? Kwyjibo Electrical & Lighting 1 10-21-2003 08:07 PM
removing mbc which side does the stock restrictor go on? Eaglesfan2422 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-02-2003 08:42 AM
Need to buy air tools - Which ones/which features? FutureWagon General Community 33 09-16-2002 03:04 AM
MBC hard to install? Which one? jag911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-29-2001 04:15 PM
