Old 03-02-2003, 09:39 AM   #1
AudioFan
Member#: 1380
2005 SRT4
Orange Blast
Default How to check CEL code?
I just got a CEL, I´ll be taking it to thedealer to check, I just want to know how do they scan the code? Do they have to get to the ECU? I need to know because I have a PROecm chip, And I want to know if they will find out, so I shoud take it out or not.
Thanks
AudioFan is offline   Reply With Quote
Old 03-02-2003, 08:59 PM   #2
obyone
Member#: 16523
depends on what code ends up getting pulled. If it's something like a cat efficiency code, they won't be pulling the ECU to fix it. On the other hand, if it's something like "Speed sensor output low" (or something like that) your ProECM may be to blame and sooner or later, they'll know that you have one installed.
(If I got the error code wrong, please correct me. I'm just pulling that from bad memory)
obyone is offline   Reply With Quote
Old 03-02-2003, 11:45 PM   #3
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
autozone does it for free...they have a little electronic device they use.
AustinSTi is offline   Reply With Quote
Old 03-04-2003, 08:17 AM   #4
AudioFan
Member#: 1380
2005 SRT4
Orange Blast
Thanks for your answer, I know it depends on what code it is, But how do they check the code at firts, where´s the scanner plugged to check the code?
Autozone is not an option for me (not in the US), So I have to go to the dealer, but for example where would autozone plug the electronic device to check the code?
Old 03-04-2003, 11:46 AM   #5
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Well, since I just checked a code last night at the repair bays, I'll describe how it was done.
After getting the little scan tool out, and putting the correct plug (OBDII) on the end of it, we plugged it into a similar shaped plug at the bottom of the dash, to the left of the steering column. Granted, this is for a US Spec car, so if you're dealing with a Foreing spec car, I'm not sure the exact location, but it should be down there.
All we did then was enter various numbers from the VIN, the specs of my car, and then pulled the code, reset the code and went from there.
So, you'll be looking for either a male or female plug (not sure which) probably at the bottom of the dash on the driver's side. That is where you'll be plugging the scan tool into.
Hope this helps.
AJ711 is offline   Reply With Quote
Old 03-04-2003, 12:13 PM   #6
AudioFan
Member#: 1380
2005 SRT4
Orange Blast
That was exactly what I wanted to know, They just have to acces a plug under the dash, thanks
Old 03-07-2003, 10:30 PM   #7
ATXImpreza
Member#: 18565
1995 Impreza
Red
Default on MY95
not sure for wrx or 97+ but Under the dash on the side of the steering column, there are two small black connectors that are not connected... turn the car off and connect the two wires.. then put the key in and Turn to ON but NOT ON ... your light should blink and read you out a code... fast ones are 1's and long ones are 10's...
ATXImpreza is offline   Reply With Quote
How to check what code your cel is throwing?? boostinscooby Newbies & FAQs 10 08-12-2005 04:07 PM
How to pull CEL code? PeteDucati Engine Management & Tuning 3 03-18-2004 09:36 PM
Best way to check CEL codes at home? ndw1138 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-19-2003 03:28 PM
how to pull cel codes? no_rex_yet Service & Maintenance 3 01-17-2003 05:55 PM
How to read CEL code? MrZone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-08-2002 03:55 PM
