Old 03-02-2003, 11:58 PM   #1
RhinoRex
Member#: 29825
2002 WRX Wagon
WR Blue
Question Uneven piston wear in flat fours?
It seems to me that the flat four has the potential for worse engine wear than other engine configurations. As you all know, a good deal of engine wear happens when you first start up. In a flat four, you would always have the pistons' weight resting on the same side of the rubber piston rings. I would think that one side of the ring (the down side) would wear faster than the other sides. In general it seems like gravity would cause problems in flat fours that inline engines don't face and that Vs face much less.
I'm sure there's a way that this is deal with. How do they do it?
For those of you who have rebuilt horizontally opposed engines, do you notice uneven wear on the rings?
RhinoRex is offline   Reply With Quote
Old 03-03-2003, 12:27 AM   #2
Gethin
Member#: 2998
The engine has bee in development for over 30 years and is one of the most reliable designs you will see.
The pistone design is very light and IMHO the gravity effect would be negligable.
http://www.mypersonaldrive.com/Subar...ton-Cranky.asp
I have seen pictures before of engines stripped down and never seen any wear as you describe resulting from the gravity effect on cold start.
Anyone else had hands on experience examining the bores?
Gethin.
Gethin is offline   Reply With Quote
Old 03-03-2003, 01:05 AM   #3
philip_g
Member#: 32906
more like 60+ if you include light airplane engines, which really haven't changed in over 50 years
philip_g is offline   Reply With Quote
Old 03-03-2003, 10:01 AM   #4
RhinoRex
Member#: 29825
2002 WRX Wagon
WR Blue
I am not at all questioning the reliability of the flat four. It's more that this problem occurred to me and I am now curious about how they solved this engineering challenge.
That is, this question is more curiosity than heresy.
Old 03-03-2003, 10:14 AM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
There is more than enough oil in the cylinders at startup to prevent uneven wear.
What are you talking about when yo usay "Rubber piston rings"???
Eric SS is offline   Reply With Quote
Old 03-03-2003, 12:08 PM   #6
RhinoRex
Member#: 29825
2002 WRX Wagon
WR Blue
When I wrote that, I was thinking of the compression rings and the oil control ring. I knew as I wrote it that they aren't made of rubber, but I figured that people would know what I meant.
Thanks to the link that Gethin posted, it seems that the piston skirt is more relevant to what I was thinking of.
That article is pretty interesting.
So is that the answer? There's enough oil left in the cylinders and gravity introduces no special issues? Naively (which is the only way I operate in engineering) if I imagine moving an object back and forth inside a horizontal cylinder by hand and then up and down in a vertical cylinder, it seems like there would be more friction in the horizontal.
Old 03-03-2003, 12:56 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
The parts are light enough for gravity to not have much effect compared to the outward force the rings are putting on the bore.
Old 03-03-2003, 01:21 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Indeed... the pistons weight about a pound with rings.
Brian
http://www.subaruwrxparts.com
http://www.wrxstiparts.com
http://www.subarubajaparts.com
Old 03-03-2003, 10:38 PM   #9
Gethin
Member#: 2998
Talking
Yikes! One pound! The Scooby Engineers did a great job!
Gethin.
Old 03-04-2003, 12:02 AM   #10
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
Also consider that the bore and piston are made to pretty exact tolerances, so the friction cause by weight should be darn near even throughout the circular shape. I could imagine your problem if there was any sort of gap between the top of the piston and the cylinder, but I think they are manufactured tight enough to avoid that problem. For the record, I'm no mechanical engineer, but that's just what I am observing.
gjhsu is offline   Reply With Quote
Help! Uneven Rotor Wear with new rotors (H6 in rear) and pads Saucy7 Brakes, Steering & Suspension 6 10-07-2008 03:23 PM
uneven tire wear - is this normal? driver8 Brakes, Steering & Suspension 5 06-22-2002 05:02 PM
Uneven tire wear question: bad alignment by Subaru? Kaiser Brakes, Steering & Suspension 11 02-27-2002 10:40 AM
Uneven tire wear and AWD... Layman Brakes, Steering & Suspension 7 07-05-2001 06:50 PM
Uneven tire wear... strange... jasony Brakes, Steering & Suspension 7 07-02-2001 01:20 PM
