Old 03-03-2003, 02:28 PM   #1
TractionCircle
Member#: 19596
Location: The land of fake boobs and fast cars...South FL
Default Blown Turbo????
Hey everyone,
Went out for my lunch break today, started the car and a haze of smoke out the tailpipe. Driving it goes away. Get to the restaurant and I notice same haze of smoke out tailpipe as I rev it (not at idle) and same haze coming through the hood scoop. Pop the hood and there's white/blue smoke coming from underneath the turbine housing area, it looks as if the entire turbine housing is smoking. Let it cool for 20 mins, check the oil, full. No recent changes of ANY kind, maintenance or otherwise. Only run 15psi with the profec, but I watch for PTFB conditions. Car has uppipe, downpipe, catback, profec, and a filter. 15k miles.
All the symptoms are pointing me to a blown turbo, which is fine cause I have another sitting around ready to go on. My question is do any of you with experience think this problem could reappear when I put my new turbo on? There are no leaks visible around the outside of the turbo (or anywhere for that matter).
Any insight would be appreciated.....
Jay
P.S: Yes, I used the search button and searched for blown turbo, and that does seem to be the consensus, however they do not address why with my specific set of mods/conditions.
TractionCircle is offline   Reply With Quote
Old 03-03-2003, 03:17 PM   #2
westy66
Member#: 4329
2005 LGT Wagon 5MT
stock turbo?
westy66 is offline   Reply With Quote
Old 03-03-2003, 03:18 PM   #3
TractionCircle
Member#: 19596
Yes, stock turbo with 15k miles on it.
Jay
Old 03-03-2003, 03:24 PM   #4
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
15k sounds too early for a blown turbo...
could it be a leak from a coolant hose??
but then i'm not an expert...
KIMUTAKU is offline   Reply With Quote
Old 03-05-2003, 02:10 PM   #5
TractionCircle
Member#: 19596
Damned Subaru's.......
It's not doing it anymore. Seems to have been a fluke. Didn't make sense to have smoke coming from the turbine housing AND from the tailpipe. Oh well, musta been a full moon....
Jay
Old 03-05-2003, 02:20 PM   #6
jjunior887
Member#: 16738
2015 WRX Limited
CWP
same thing happend to a buddy of mine. His did it the morning after a few WOT runs the night before. He took it to the dealer and they found nothing wrong. As far as i know it hasn't done it since.
jjunior887 is offline   Reply With Quote
Old 03-05-2003, 06:42 PM   #7
savka
Member#: 12737
MY02 wagon 325/300
MBP
Welcome to the game show called "leaking exhaust-side turbo seals"
First I started noticing whitish smoke coming through the hood scoop at 13K miles, then I stared noticing an occasional 'funny' smell at 15k, then when I got on a AWD dyno at 17K I and everyone else 'noticed' gobs of blue smoke coming out of my exhaust.
Next day pulled the stock turbo off, no oil anywhere, replaced it with another stock turbo and the problem has not been heard from since.
Put in your new turbo, the problem will disappear.
As to me not finding any oil in the turbo, the explanation (as was explained to me) is this. The oil burns off after it leaks through because of the extreme heat in the exhaust. So you will not find any obvious signs of oil, however what you can notice is a slight resin type of residue on the walls of the exhaust side of the turbo. Run your finger around there after you get the turbo off and see if its more then just carbon deposits that gets picked up by your finger tip.
Good luck
sav
check out this THREAD
savka is offline   Reply With Quote
Possible blown turbo? Hit 19psi. Suggestions please. Bunuel Mid Atlantic Impreza Club -- MAIC 14 04-30-2003 03:15 PM
Blown turbo? Something simpler? HELP JimDab Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-21-2003 10:56 PM
Blown Turbo sighting wolf8314 Mid Atlantic Impreza Club -- MAIC 1 04-06-2002 07:10 AM
Pre-turbo cat failure = blown turbo nicd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-24-2001 03:18 PM
