Old 04-03-2001, 11:45 AM   #1
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
Post Anyone try P1 susp setup from SPD?
If you have tryed this how is it? Is it easy to put in? What kind of brake and wheel setup are you using? Looking to put these on 2001 RS coupe.
Thanks
RS22b is offline   Reply With Quote
Old 04-03-2001, 08:01 PM   #2
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Post
http://www.azscooby.com/mods/AZScooby/Peaty/p1.php
Had mine for a while and love it. I soaked my bolts overnight in WD-40 and didn't have any problems gettning anything off myself. Took me about 4 hrs to do. Not hard I just took my time and was working alone.
Peaty is offline   Reply With Quote
Old 04-03-2001, 08:48 PM   #3
RS22b
Member#: 5413
#15 2-Subaru
Post
What brakes nad wheeels are you ridin on?
Old 04-04-2001, 12:12 AM   #4
JGard
pooptastic
Member#: 1904
2013 Tundra
'02 BMW R1100S
Post
get the V5 setup. It's cheaper (slightly) and stiffer(also slightly).
It's relatively easy to put in, it just takes a while if you've never done it before, or don't have all the right tools.
JGard is offline   Reply With Quote
Old 04-04-2001, 12:21 AM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
get the right tools... namely a LONG breaker bar w/ a 17mm(I think) socket and lots of penetrating grease... Mine weren't rusted or anything, but they were a pain in the 4$$ to get off... got one bolt off, w/ a regular socket wrench, the other I got off w/ a breaker bar and adapter, the next one broke two adapters... the rest came off almost easy w/ the breaker bar and correct socket(no adapter)
also a socket wrench w/ a passthru is nice and will save you ALOT of time, altho I did 3 of mine w/o one... the last I had to take to a shop to get the top nut off.
the small top nuts on the rear are also a pain, because of the tight space, so a SMALL socket wrench(>4" or so) helps there... it's nice to have someone to help you line things back up when you're putting the strut/spring assemblies in the car, but not neccessary. it's really not that hard w/ the right tools. good luck!
mrbell is offline   Reply With Quote
Old 04-04-2001, 08:08 AM   #6
Buffalo Bob
Member#: 4120
2000 Impreza 2.5 RS
Sedona Red Pearl
Smile
I've had the P1 suspension for about 3 months, and I like it quite a bit. Really reduces body roll. I still have the RE92s (hoping to change that soon), and winter just doesn't want to let go, so I can't really comment on the ultimate handling ability. It is stiffer, but not too bad, even with these CRAPPY Michigan roads.
The bottom bolts are 19 mm, same as the lug wrench. I used a 4-ft piece of iron pipe over the lug wrench and didn't have any problems!
Buffalo Bob is offline   Reply With Quote
susp setup for GC8/2.5RS/L etc... STI v5 struts P1 springs camber plates rear mounts Ahut2000 Suspension/Brakes/Handling 5 10-30-2008 05:52 PM
anyone try the prodrive knob from Flat4 on their STi? TRM Interior & Exterior Modification 6 01-21-2004 06:01 PM
UK STI Susp. Diff from JDM STI Susp. ? Zahnster Brakes, Steering & Suspension 10 02-11-2002 10:15 AM
Anyone try the Eibach springs from Subaruparts.com? BrysImpreza Brakes, Steering & Suspension 1 09-20-2001 05:53 PM
Anyone jump P1 susp??? RS22b Brakes, Steering & Suspension 6 05-01-2001 01:51 PM
Message Board Statistics All times are GMT -4. The time now is 06:01 PM.
