Old 05-26-2001, 02:37 PM   #1
2.5rsMI
Member#: 3270
2001 Impreza RS
BRP
Post WHY DO I HAVE SO MUCH ROAD NOISE PLEASE HELP
I hate it. I have so much road noise comming from the rear of the car. I went to get a alignment today but they were closed. If that doent fix it I will die from the noise. I have the ver5 struts and 5zigen springs
2.5rsMI is offline   Reply With Quote
Old 05-26-2001, 02:40 PM   #2
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Post
HUH?? DID YOU SAY SOMETHING?!?!
Dr Ken is offline   Reply With Quote
Old 05-26-2001, 02:59 PM   #3
2.5zigen
Member#: 5655
Post
I hate when people post like ******** to questions. Just thought I would back you up 2.5rsMI
2.5zigen is offline   Reply With Quote
Old 05-26-2001, 03:02 PM   #4
KeithRS
Member#: 3436
1987 Rockhopper
Yellow
Post
If it is a loud rumbling kind of sound I would suspect a wheel bearing... I think I have heard of a couple people having that happen. If that is the problem, it should be covered under warranty.
KeithRS is offline   Reply With Quote
Old 05-26-2001, 03:07 PM   #5
Loki
Member#: 4543
2003 WRX
Post
Can you describe the noise a little more? Maybe you have a rock caught in your tread or something ...
~Loki
Loki is offline   Reply With Quote
Old 05-26-2001, 03:09 PM   #6
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
either
rock in brakes
tires
wheel bearing.
an alignment won't make a difference
oh, and read the board rules, no posting in ALL CAPS.
JGard is offline   Reply With Quote
Old 05-26-2001, 03:13 PM   #7
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Post
If you go in the trunk and look behind the black sections on the sides..............youl find,,,nothing!Ive got the version 5 and other susp.parts including somewhat noisey Bridgestone 730s.I installed carpet padding behimd the black pieces and in the spare tire area and i cut a piece to fit under the carpet in the rear also.
Results,,,Quiter Stromung,not any road noise,cheap fix $14 bucks,and my Radio and cd sound more bassy.
Rudy
jagcars26 is offline   Reply With Quote
Old 05-26-2001, 03:27 PM   #8
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
All caps in the subject line = closed post.
Imprezer is offline   Reply With Quote
Old 05-26-2001, 03:33 PM   #9
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
Post
2.5rsMI,
You probably have a wheel bearing going bad. It took me a while to figure it out in my car. I had done a bunch of mods when the bearing started going bad. I thought the noise was coming from low profile tires + STI bushings. After about 10k miles it started getting worse. I noticed a slight shimmy and decided to tear the back drive train apart to find it. Both rear hub bearings were almost completely dry. With no visible evidence of the grease leaking out, I assume they weren't properly greased when installed. I changed out both bearings and all the seals myself. I made sure to completely clean out the new bearings and stuff as much synthetic grease in as possible. Result...absolutely no noise of any kind from the rearend and that was 25k miles ago. Hope this helps.
Regards,
Chris
FletchMY98 is offline   Reply With Quote
Catchcan caught a lot in a month... why do I have so much crap? elitescouter Newbies & FAQs 22 10-30-2009 01:56 AM
why do i have so much disdain for popular music? alacrity024 Off-Topic 44 03-09-2006 06:09 PM
Why do helicopters make so much noise? Christoff Off-Topic 21 09-12-2005 12:16 PM
why or why do the...look so much line every Subaru? Diabolical1 CC General Community 14 11-22-2004 11:19 AM
why do subies rattle so much? Otaku64 Car Audio, Video & Security 10 03-24-2003 11:03 PM
